StevePhelps 0 #1 May 25, 2004 I have premiere 6 and when I place a title in timeline 2 or higher over a video in 1 it appears as a little white box with an X in the upper left corner. The title is in a superimpose line (2 or higher) It is marked "transparent" In fact when you first click transparency it appears, but when you scrub or play all you see is the white box with an X. Any clues? Quote Share this post Link to post Share on other sites
jdhill 0 #2 May 25, 2004 Render it. JAll that is necessary for the triumph of evil is that good men do nothing. - Edmund Burke Quote Share this post Link to post Share on other sites
turtlespeed 226 #3 May 25, 2004 Yep - easiest way for me - right click the little yellow bar and click on render work area - make sure the clip is in your work area though.I'm not usually into the whole 3-way thing, but you got me a little excited with that. - Skymama BTR #1 / OTB^5 Official #2 / Hellfish #408 / VSCR #108/Tortuga/Orfun Quote Share this post Link to post Share on other sites
StevePhelps 0 #4 May 25, 2004 I rendered it -- same problem. When it first appears its okay, but as soon as you scrub it the little box shows up again. and it never appears right again. Quote Share this post Link to post Share on other sites
jdhill 0 #5 May 25, 2004 Have you been able to make titles work before? JAll that is necessary for the triumph of evil is that good men do nothing. - Edmund Burke Quote Share this post Link to post Share on other sites
StevePhelps 0 #7 May 26, 2004 I finally got the titles to work -- I THINK I wasn't rendering the whole work area (if that is possible) Thanks guys! Quote Share this post Link to post Share on other sites
