Faber 0 #1 March 18, 2004 Any who has experience whith theese? Any good ideas for setups(most BASE) which lenss is recomended.. Thanks Stay safe Stefan Faber Quote Share this post Link to post Share on other sites
Gadget 0 #2 March 18, 2004 Ask Cato.She is jumping on and is in the forums quit alotIf people from Poland are called Poles, why aren't people from Holland called Holes??? My logbook Quote Share this post Link to post Share on other sites
didone 0 #3 March 18, 2004 I use a 21CWS-HRX. It's a Sony EXVIEW HAD CCD High resolution 480 TVL - 438k real pixels in the PAL version. The quality is somewhat similar to the early DCR-PCx serie of camcorders. I paid 150 GBP for it. I pierced an oval hole on top of my helmet to accomodate it, and used 2 clamps to mount it. The leads run inside the helmet. I connect the camera to a camcorder through a 4-pin connector (V+, V-, audio, video). Some soldering is required. I use a 2.9 mm lens, which gives 130 degrees of viewing angle (the maximum I was able to find, but IMH ok to do nice shots). So far, I am very happy with the quality. The problems are: - cables running from the helmet to the camcorder (I carry it in the pocket). To do base I suggest you might even think about a small 2.4 Ghz radio A/V transmitter. - batteries: a 9v alkaline lasts 10 mins max. I am working to fit a 12V flat Li-ion battery inside the helmet. 'hope this helps Diego Quote Share this post Link to post Share on other sites
DBCOOPER 5 #4 March 19, 2004 QuoteI use a 21CWS-HRX Me too with this.Replying to: Re: Stall On Jump Run Emergency Procedure? by billvon If the plane is unrecoverable then exiting is a very very good idea. Quote Share this post Link to post Share on other sites
CaTo 0 #5 March 19, 2004 QuoteAsk Cato.She is jumping on and is in the forums quit alot yep, and I am enyoing it (the bulletcam I mean , no more neck-stress :-) I am also jumping the 21CWSHR with Sony ccd in it, bought at rfconcepts.co.uk Since I already had a flat top pro which fitted very very well, I used that helmet again for the bulletcam. see pictures. The camera is attached via a wire with a trv33 closely strapped on my belly, using a cameye sport to start and stop. see more on my webpage, the about sections tells you more about the setupCaren Quote Share this post Link to post Share on other sites
klund 0 #6 March 19, 2004 I've also got the 21CWSHR bullet cam bought at rfconcepts.co.uk. So far I have used it as a helmet camera for mountainbiking, skiing and other "fast" activities. I'm very satisfied with the quality. Haven't done any direct comparison to the recordings with the cam's onboard lens, but even if it has slightly lower quality, it gives me unique shots that I would not have got otherwise. As for skydiving/BASE, my intention is to use a regular setup for helmet camera, and use the bullet camera for experimental camera angles from other bodyparts than the head. - Kristian Quote Share this post Link to post Share on other sites
Faber 0 #7 March 20, 2004 which lenses do you guys use? Any ideas on how to secure the camcorder(belly belt?) thanks Stay safe Stefan Faber Quote Share this post Link to post Share on other sites
Faber 0 #8 March 20, 2004 okay i just did a better recearch,and i even think it were said here before.. it should be the 2.9mm lens(only wideangel)that i should use. a 4.3mm lens will follow whith the pack,i must expect that that is a regular lenss. Stay safe Stefan Faber Quote Share this post Link to post Share on other sites
CaTo 0 #9 March 20, 2004 Quote.. it should be the 2.9mm lens(only wideangel)that i should use. a 4.3mm lens will follow whith the pack,i must expect that that is a regular lenss. I ordered by bullet cam wit three lenses: the 2.9 already on the camera, and the 3.6 and 4.3 After some testing, it turned out that the 2.9 is far too much wide-angle for my purpose (mainly CRW) The 3.6 turned out to be almost equal to my 28mm lens on my still-cam, so I decided to switch. Note that you need some special appliance to un-screw the lens and put the new one on the camerawith regards to your other question: I bought a rather standard (digital-)camera bag in which the TRV33 fitted almost perfectly. To this bag, my friend-the-rigger (thanks Kees) sowed a belt (2 inch wide) with a snap. I wear the belt below the harnas, so first put on the belt, then put on the harnas. it fits very well, I do not feel it when jmping, or sitting in the plane. The weight is minimal (compared o the weight I had on my head before )if you need more info, just ask.Caren Quote Share this post Link to post Share on other sites
piisfish 140 #10 March 21, 2004 and what does that cost/where can you order these bullet cams ??scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
Faber 0 #11 March 21, 2004 from 100UK£ and up http://www.rfconcepts.co.uk/helmet_cameras.htm Stay safe Stefan Faber Quote Share this post Link to post Share on other sites
piisfish 140 #12 March 21, 2004 thanks for the info Stefan, I think I know what I'll get for my birthday scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
skydog 2 #13 March 29, 2004 Is this setup (PAL version) suitable for a FTP? http://helmetcamera.com/products.htm Any thoughts? BrynJourney not destination..... Quote Share this post Link to post Share on other sites
Faber 0 #14 March 29, 2004 what do you mean by suitable for FTP? you will edit your video anyway which means you will compress it to avi mepg mov or somthing,which dont care about pal or ntsc... sorry if i dont understand your Q correct.. Stay safe Stefan Faber Quote Share this post Link to post Share on other sites
skydog 2 #15 March 29, 2004 Quotewhat do you mean by suitable for FTP? you will edit your video anyway which means you will compress it to avi mepg mov or somthing,which dont care about pal or ntsc... sorry if i dont understand your Q correct.. My fault for not being specific. I would like to fit it to my FTP like Cato has on his(ie fitted inside the shell of the helmet). However, I am not sure of the dimensions of the camera etc. Also, is it suitable to use, given I have no experience of bulletcams. I just know that my neck would appreciate it!!!!!! BrynJourney not destination..... Quote Share this post Link to post Share on other sites
dragon2 2 #16 March 29, 2004 LOL for a computer nerd, FTP means File Transfer Protocol, but Flat Top Pro works as well BTW Cato's a girl too ciel bleu, Saskia Quote Share this post Link to post Share on other sites
skydog 2 #17 March 29, 2004 QuoteLOL for a computer nerd, FTP means File Transfer Protocol, but Flat Top Pro works as well BTW Cato's a girl too OOOOPs, so used to acronyms in skydiving forget about ones in the real world. Apologies to Cato. BrynJourney not destination..... Quote Share this post Link to post Share on other sites
CaTo 0 #18 March 30, 2004 [reply BTW Cato's a girl too Apologies to Cato. no problem by the way, I did have a look at the helmetcamera.com page, an although I could not find the exact dimensions of the camera, it surely looks the same size as mine. So that should fit. But notice that I had to remove some of the inner shell to make it fit, and it is not easy to drill the hole at the exact place :-) you can only do that from the outside, and you can not mark the spot exactly.... hold your breath and drill by the way, my page has now some pictures made with the bullet cam on it, look at the NL-page and follow the links at the left. byeCaren Quote Share this post Link to post Share on other sites
