sducoach
Sony - Sonic DVD Problem
About one out of every three DVD's will not complete.
Using Sonic MyDVDit and Sony 510A.
Here's the message:
"Could not complete the last command because devise error- sense cond (37304) program memory area/rma update failure - sequential write (dvderr,226052)"
Any help, please PM me.
Blues,
J.E.
James 4:8
Here's the message:
Blues,
J.E.
What brand/type of blank DVDs are you using?
I use Sonic MyDVD and a Sony burner. I've had problems similar to yours and corrected it by separating the process of creating of the DVD files from the actual burning process.
When running Sonic MyDVD, when you're ready to burn your DVD, don't click the BURN button. Instead, select TOOLS, then MAKE DVD FOLDER. This will create your DVD files on your hard drive.
When its done, you should find these folders on your hard drive:
AUDIO_TS
JACKET_P
OpenDVD
VIDEO_TS
Now exit Sonic MyDVD. Use another program to copy those folders to a blank DVD, as if you were just creating a data disk. I use RecordNOW DX which I believe comes with most Sony DVD burners. This also makes it easy to burn multiple copies of the same DVD. The burning process usually takes around 10 to 15 minutes.
Lastly, if your DVD burner is external, make certain your not powering the burner on and off without first using the SAFELY REMOVE HARDWARE feature. If running windows, you should find an icon in your system tray called SAFELY REMOVE HARDWARE. Click this and follow the direction until it tells you that it is safe to turn off your burner. I had several bad burns before I discovered this
Hope this helps you.
Doc
http://www.manifestmaster.com/video
Kallend,
Solved part of the problem. I'm using TDK. Seems that Sonic has problems with multiple copies and Premier.
I have to shut the program down between copies. Sonic knows of the problem, admits it's a problem and suggest using another program to do multiple copies.
Go figure. Great public relations!
Blues,
J.E.
James 4:8
