DJL 235 #1 December 27, 2003 Ok, based on the options for the PC105 at CLICK what should I get. This is my first camera and I'll be using it for fun until I get my skills together and can shoot tandems. Case: A)none B) Deluxe $80 C)Regular $50 Battery life: A)2.5 $70 B)5.5 $110 C) 10 $190 AC/DC charger: A)None B)Yes $150 Extra Memory: A)No B)How much memory? $60-$300 Adapter: A)None B)Reg Reader $60 C)6 in 1 $100 Filter: A)No B)Standard UV $40 C)Multi $80 D) Multi Kit $200 E)Get one elsewhere. I'm not set on a PC105 right now, by the way, so this is not imminent."I encourage all awesome dangerous behavior." - Jeffro Fincher Quote Share this post Link to post Share on other sites
quade 4 #2 December 27, 2003 Case = None Battery = it already comes with one. AC/DC Charger = it already comes with one. Extra Memory = none. Adapter = just plug the camera into your computer. Filter = buy a wide angle lens instead and a UV filter for that if you want but generally not needed.quade - The World's Most Boring Skydiver Quote Share this post Link to post Share on other sites
AlvaroCarvalho 0 #3 December 27, 2003 Hey Doug! Just a suggestion: 1. If you're going to use this camera for skydiving only, why would you need a case for? 2. I would go for a FM50...but it depends on the camera box you're going to use. I use a FM50 and it's ok for a full day skydiving. 3. I thought AC/DC chargers would come standard with the camera... I think that's why you found it so cheap. 4. My PC9 came with a 4MB Memory Stick...i don't use it anyway. This goes for the adapter too. 5. Protect your lens is a must. But try Ebay...you can find a set of three filters (UV, FD and PL) for less than $30. Blue skies! __________________________________________________ Hey...ho...let's go! Quote Share this post Link to post Share on other sites
sunman 0 #4 December 27, 2003 Go for the $70 battery upgrade. The battery that comes standard on that camera SUCKS. I have that exact camera and I was too cheap to get the extended life battery and I wish I had. Quote Share this post Link to post Share on other sites
marks 0 #5 December 27, 2003 QuoteGo for the $70 battery upgrade. The battery that comes standard on that camera SUCKS. I have that exact camera and I was too cheap to get the extended life battery and I wish I had. depends on what your useing it for. it doesnt fit in some if not most of the boxes with the extended life battery...... if you useing it for skydiving in a helmet ... there really isnt a need "in my opiniopn".. for the extended battery. is seems to do fine for me.... just hook it to the charger while your dubbing..... Quote Share this post Link to post Share on other sites
AndyMan 7 #6 December 28, 2003 I don't like the bigger battery because of the way it sticks out of the camera. Instead I bought a second battery of the same size, which I swap out when I need to. For the most part, I only need to swap out when I forget to charge the first one before a day of jumping. _Am__ You put the fun in "funnel" - craichead. Quote Share this post Link to post Share on other sites
