JayhawkJumper
Flat top Narrow or Pro?
I jump both currently (personal setup is a narrow, work set up is a pro). There isn't very much difference other than the platform size. The narrow is about a half pound lighter with identical setups. I do like the smaller profile of the narrow (the platform width anyway) because I use my personal setup out of a 206, while the pro I use out of a twotter.
As far as flying goes I notice no difference, they both seem to fly the same.
Hope this helps!
Miami
Depends on what you want to shoot and how you want to set up your cameras...
I have a narrow, which is nice, i wanted it for the lighter weight. But after some thought about my set-up, Video on top, stills on Front, I think it might have been better to put stills vertically mounted side by side on top, in which case I think my narrow is too narrow for that and would create snag points if I hung part of each camera over the edge of the platform.
Also, if you start to consider using a flash, you'll need room for it.
peace
http://www.exitshot.com
I think the Flat-Top Pro might make a slightly better long term investment as the Narrow could be somewhat limiting.
Exactly, plus if you like to change setups often (I do) the Pro comes with a changeable top, while the narow is fixed. When you have drilled so many holes in the Pro's top that it looks like swiss cheese, you can just replace it.
They both are by far the most comfrotable helment i have ever had a camera on. The main differance is do you want to fly two cameras or one on top. For tandem flying one camera is enough, but if shooting 4-way at a national level then two cameras would be sufficent. Each one has one of the best escapes on them too. No other helment has this escape feature that i believe is a nessecity for camera flying. Main point due some research first from the internet and talking with people whom have done it for a while but only take advise make your own mind up.
