bluepill
Where to buy PC101 in UK?
Wait till you visit the states, they're about 1/2 UK price:(, and yes they will sell you a PAL version that can DV in AND out, as long as you tell them thats what you want.
I bought my PC101e in Florida, price in UK duty free £985, price in Florida $795.
Hi PollyX
It depends:(
If your tv or vcr is modern you will probably be able to view the footage. Lots of tvs and vcrs in the UK actually have a label which says NTSC playback. However, that means exactly that, playback only. You cannot record use your NTSC playback vcr to satisfactorily record the NTSC footage from your PC101 onto a VHS tape.:( This is because the vcr uses a special NTSC4.43 output signal standard to fool PAL tvs into displaying an Ok image. But this isn't good enough for recording with.
Ditto if you pop the PC101 (NTSC) tape into a PAL camcorder and use that to playback. While the image will be good enough to view on a tv, it won't be good enough to record onto a vcr.
Why do you want to buy an NTSC camcorder?
If you're shooting in DV, most people put it onto a PC to work with. This eliminates all PAL/NTSC problems as you can simply convert it to whatever format you want or edit it and put it into an MPEG before recording onto VHS or even burn a DVD if you have the drive.
(sorry, too many nomenclatures)
