SniperCJ
Sony error message E61:10
E61:10
Zoom operations fault (Cannot initialize zoom lens.)
Inspect the lens block zoom MR sensor (Pin 2,3 of CN171 of CD-234 board) when zooming is performed when the zoom lens is operated and the zoom motor drive circuit (IC401 of VC-227 board when zooming is not performed.
E61:10
........... I have an early model sony
mini-dv,,,, TrV 7
which has the wide/tele zoom button hitch on it every once in a while .. I take it to a service place locally,,, and he goes inside it,, and apparently there is a linkage,, which can disconnect,,,rendering the switch ineffective...... it has happened a few times.... the problem is,,, (unless you have a back -up camera,,,) you are out of commision til it is repaired..[:/]>:(B|...... not sure if other cams,, are susceptible to this,,, I hope not...
