stilettodude 0 #1 March 18, 2003 CAN YOU TURN CYPRESS OFF OR DO YOU HAVE TO WAIT FOR IT TO TURN ITSELF OFF, AFTER THE 12HRS. ( I THINK) WITH NO PRESSURE CHANGE??? Philip "HOW LOW CAN YOU GO?" Quote Share this post Link to post Share on other sites
Jib 0 #2 March 18, 2003 It's the same as turning it on. http://www.pia.com/SSK/cypres/english_users.pdf see page 19 -------------------------------------------------- the depth of his depravity sickens me. -- Jerry Falwell, People v. Larry Flynt Quote Share this post Link to post Share on other sites
Hooknswoop 19 #3 March 18, 2003 Same process to turn it off as to turn it on. Unless you are changing a good bit of elevation on the way home, enough that it thinks you are climbing in an aircraft, let it turn itself off (after 14 hours, regardless of pressure change). Quote Share this post Link to post Share on other sites
eddytheeagle 0 #4 March 18, 2003 You can turn a cypress off in exactly the same way as you turn it on. It will switch itself of 14 hours after you turned it on.Don't underestimate your ability to screw up! Quote Share this post Link to post Share on other sites
stilettodude 0 #5 March 18, 2003 Thanks Dudes! Philip "HOW LOW CAN YOU GO?" Quote Share this post Link to post Share on other sites
cheneyneel 0 #6 March 18, 2003 it takes more battery power to turn it off than it does letting it turn off by itself... Something to think about... Quote Share this post Link to post Share on other sites
freakyflyr11 0 #7 March 18, 2003 i agree unless you are changing altitude alot going home you may want to just leave it on and let its self turn off youll save battery life that way Quote Share this post Link to post Share on other sites
grasshopper 0 #8 March 18, 2003 Quote youll save battery life that way is anyone actually having their batteries not last 2 years or 500 jumps? we have seen this debate many times and it looks to me like one thing that just doesn't matter either way. we are talking about wear by shutting it off, but some people have to cycle their cypres off and on every jump (lz not on airport like at monterey). Quote Share this post Link to post Share on other sites
Hooknswoop 19 #9 March 18, 2003 Quoteis anyone actually having their batteries not last 2 years or 500 jumps? Yes, I have had a set Cypres batteries not last two years. I have also seen others have batteries not last the 2 years. Hook Quote Share this post Link to post Share on other sites
weid14 0 #10 March 18, 2003 QuoteIt's the same as turning it on. http://www.pia.com/SSK/cypres/english_users.pdf see page 19 it is, but it's a little more touchy turning it off.... Quote Share this post Link to post Share on other sites
Hooknswoop 19 #11 March 18, 2003 http://www.pia.com/SSK/cypres/cyp16.htm Contains tips on turning the Cypres off. Hook Quote Share this post Link to post Share on other sites
stilettodude 0 #12 March 18, 2003 Read the tips and found out i'm pushing the button to hard. Thanks Philip "HOW LOW CAN YOU GO?" Quote Share this post Link to post Share on other sites
grasshopper 0 #13 March 18, 2003 QuoteQuoteis anyone actually having their batteries not last 2 years or 500 jumps? Quote Yes, I have had a set Cypres batteries not last two years. I have also seen others have batteries not last the 2 years. but is that also with less than 500 jumps on the batteries? Quote Share this post Link to post Share on other sites councilman24 37 #14 March 18, 2003 In my case yes. I have seen batteries not last 2 years OR 500 jumps. There was a batch of batteries a few years ago that were substandard. Airtec recognized it and provided prorated replacements if they died substantially early. The French company that made the batteries never admitted they were bad. I've also seen other batteries, not in the time frame of the bad batteries, die early. TerryI'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites kallend 2,196 #15 March 18, 2003 Quoteit takes more battery power to turn it off than it does letting it turn off by itself... Something to think about...... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites diverdriver 7 #16 March 18, 2003 John, since you can't receive PMs I can't tell you that your post had nothing new on it. Quote Share this post Link to post Share on other sites Hooknswoop 19 #17 March 18, 2003 Quotebut is that also with less than 500 jumps on the batteries? Some were. Hook Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
