bluntscull
which PC style is best?
Which ever one you decide on, make sure it has the 37mm lens and not the 32mm. Bigger optics is better for more light gathering. If you want it for stills as well, one with the highest megapixels is best. The 120 has the highest so far at 1.5. The 120 also has bluetooth, all other PC's dont. Pop up flash is nice and 110, 115 and 120 all have it. Im pretty sure all the ones quoted here have the same ccd, so that is not an issue. Go to a store that stocks them and play around with them for a while. Good luck
I definitely prefer the PC115/120 (115 is the 120 without Bluetooth). The bonehead d-box fits very nicely. Picture quality is excellent (as close to 3-chip as we've come, so far), and low-light qualities are respectable. It is heavier, and bulkier than the PC101 (and more expensive), but great quality images for the extra $$$. The PC101 is no slouch, either. It is smaller and lighter, with a slightly better image than even larger predecessors. The 101 would be my choice if you want to save a few bucks, and a bit of weight on your neck (and smaller = less likely to get smacked/snagged, generally).
The laws of physics are strictly enforced.
