12bhi 0 #1 March 9, 2003 Do the newer javelins come standard with hard cutaway housings?If so what year did they start this? Quote Share this post Link to post Share on other sites
PhreeZone 20 #2 March 9, 2003 They come with hard housings, getting soft housings takes jumping through a lot of hoops, and even then its a very slight chance of getting them. We have a guy at my DZ that perfers to jump soft housings and he's having issues fining a manufactor for a new rig. I know my 99 Jav has them.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
Squeak 17 #4 March 10, 2003 My 93 J1 has Benix housings but I'm not sure if they were retro fitted, (i dont think so though)You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
riggerrob 643 #5 March 10, 2003 Soft release housings were only manufactured for a few years (circa 1991 to 1995). They were only available on a few rigs like: Flexon, '94 Talon, Javelin and Teardrop. After that the better manufacturers standardized on hard housings. Most rigs manufactured with soft housings have long since been up-dated with hard housings. Quote Share this post Link to post Share on other sites
AndyMan 7 #6 March 10, 2003 I think he's refering to the upper housing on his risers.... _Am__ You put the fun in "funnel" - craichead. Quote Share this post Link to post Share on other sites
voodew1 0 #7 March 11, 2003 I may be wrong but I think javelins come with plastic housings in the risers not metal as metal can be pinched if for instance slammed in a car door making them not work. I think javelin only uses plastic housings, they could still be considered hard housings but they are not metal. The pimp hand is powdered up ... say something stupid Quote Share this post Link to post Share on other sites
skycat 0 #8 March 11, 2003 Quote as metal can be pinched if for instance slammed in a car door making them not work. I've heard this argument several times as why to not get metal riser housing. Can someone please tell me who is slamming their risers in their car doors? I can't beleive there is someone out there who cares so little about their gear. On wait nevermind, *shake head* I see way to much gear come threw our loft that looks like someone ran over it with a truck. Fly it like you stole it! Quote Share this post Link to post Share on other sites
Kris 0 #9 March 11, 2003 Quote...as metal can be pinched if for instance slammed in a car door making them not work. WTF? That falls under the heading of "Maintain Thy Gear". While your example, though really farfetched, is possible, it's not a good enough argument for plastic housings. Now, the G-load tests that have been done on standard risers, risers with plastic inserts, and risers with metal inserts is a pretty good argument for metal. Does anyone know what type of plastic they are using and what it ages like? Some plastics don't age well and can become brittle over time or with exposure to different substances / environments. KrisSky, Muff Bro, Rodriguez Bro, and Bastion of Purity and Innocence!™ Quote Share this post Link to post Share on other sites
Hooknswoop 19 #10 March 11, 2003 Quoteas metal can be pinched if for instance slammed in a car door making them not work Do you have metal housings for your reserve rip cord and cutaway housings (in the harness/container)? By your argument, these same metal housings can be slammed in a car door,pinching the cable, causing an impossible cutaway/reserve pull. Would you want plastic housings for your reserve ripcord and cutaway housings? If you subject your lifesaving gear to that much abuse, then jump it without insepction, you deserve what you get....... Metal inserts are the way to go. Hook Quote Share this post Link to post Share on other sites
voodew1 0 #11 March 11, 2003 Damn man I did the research and got the example off of Sun Paths web site. Just trying to help someone answer a question and everyone flames me. I say everyone use those arguements and call Javelin and have them use metal housings. And as for the plastic housings aging factor, plastic doesn't age well in UV light ie the sun, but not much sun will hit the housing as it is inclosed in the riser--now this is my take on the plastic aging so if someone wants to argue this one it is just what I think from what I know. The pimp hand is powdered up ... say something stupid Quote Share this post Link to post Share on other sites
billbooth 10 #12 March 11, 2003 It's been 25 years since I started using the current metal housings for my 3-ring release, and never, not even once, has anyone ever sent me back a crushed housing for repair. This same crushed housing argument was used 25 years ago, only then it was against the 3-ring release itself. Metal housing inserts in your risers are the best way to go. But please make sure the upper end of the riser housings are capped off. If they are not, it is worse than using no housing inserts at all. Quote Share this post Link to post Share on other sites
