rocketfeuille
importing to premier from sony MV
Quite simply... you don't.
Well, that's not entirely correct.
It would be possible (not preferable, but possible) to take the composite video output (not digital, but the analog video) from the camera and then digitize that via a video capture device such as http://www2.warehouse.com/product.asp?pf%5Fid=VW80705&cat=pc&blind=.
quade -
I think that I have heard somewhere that you can export the MicroMV camera output to Sony computers, but only Sony computers.
I called the local Sony Store and was advised these cameras export using Mpeg2 rather than DV format. I think this makes it pretty difficult to edit in any of the common software programs, pc or Mac.
Mpeg2 is what is used on DVDs, I believe, so if you can get the MP2 output onto your hard drive I am sure that it would be possible to use the DVD ripping tools out there to get it converted to a usable format.
Sounds like too much work to me !
Murray
Murray
"No tyranny is so irksome as petty tyranny: the officious demands of policemen, government clerks, and electromechanical gadgets." - Edward Abbey
Not many (any?) computers other than the Sony ones that are specifically set up for the MicroDV video capture would have any idea what they're looking at coming down the FireWire and therefore, it's not likily that you'll be able to download the MicroDV stuff anytime soon. Maybe somebody will write a driver at some point, but currently I think it would be a waste of time to do so considering the lack of market saturation of the format.
Second, getting Mpeg2 on a hard drive and being able to edit it are two wildly different things. Because of the way Mpeg2 works, it's not exactly frame accurate and there's all kinds of potential for hiccups and glitches in trying to make it so.
Lastly, the MicroDV format records at a data rate about half of what you're used to in the MiniDV format. It looks pretty good for some consumer/home video uses and it certainly has potential for really tiny stuff, but I don't think it's going to hold up very well if you take the data and up-convert it to something else yet again.
FAR easier (and maybe even better quality) would be the method I outlined for the analog world.
quade -
What Paul says is truth on the MPEG2 stuff...
The dazzle bridge might help, other DV bridges exist too.... also it might be easier to transfer the footage from the Micro DV cam to a Mini Dv via the analogue connections. Then import / edit from there.
Or find someone with a good quality analogue capture card such as a DC30+...;):) buy them lots of beer, and ask very kindly.
He who receives an idea from me, receives instruction himself without lessening mine; as he who lights his taper at mine, receives light without darkening me. Thomas Jefferson
This is a curious change from Sony. The microMV firewire interface only seems compatible with other cameras with microMV. The possibly misinformed people at Best Buy say none of the Sony computers recognize the microMV devices on firewire, but can capture from the composite input of the desktop editing computers. Of course, they also insisted the image quality was "the same" as miniDV, and the new 2MP microMV Sony was even better. I can seem to find reference on the Sony website to specific compatibility to microMV of any of their computers, or the associated software.
As far as MPEG editing, I do editing directly on MPEG files (only when the final destination is VCD/DVD) without any difficulty. It is faster to capture in MPEG (hardware compressed by my DVD1000) and produce to media, than to capture, edit, render in MPEG (very time consuming), and produce.
As an additional note, my DVD1000 has input and output for firewire, S-Video, and composite. Asking with a six-pack of Newcastle is a very polite way to get your microMV footage captured.
The laws of physics are strictly enforced.
"As an additional note, my DVD1000 has input and output for firewire, S-Video, and composite."
Ah yes however you and I both know that the card you mention is a 'high end' card'. Therefore probably not very common with run of the mill camera geeks.
"Asking with a six-pack of Newcastle is a very polite way to get your microMV footage captured. "
Its the international going rate...;)
