Geronimo509
converting pal to ntsc
I don't know what's in your area, but you might look for an A/V company that provides dubbing services. There is one that the company I work for uses just down the street, but that's in buffalo, NY. Having a company make you a dub in NTSC may be a lot cheaper then buying/finding the equipment neccessary.
I've heard that some DV cameras can switch there output between NTSC and PAL. So if it's on the format you have try playing it out of there with the output switched.
good luck and please post how things work out.
Hi,
I have done a bit of research on this subject. Whilst some NTSC cameras have a PAL playback feature and visa versa this does not mean that they convert but rather will play back a DV tape shot in the ' other format ' ...i.e it has to be shot using a PAL DV Cam etc.
To buy a converter is a bit of a risk , ok if you work on a DX with a lot of visiting jumpers you might turn a small profit. For anybody thats interested here is the link to an equipment site
>http://www.threedoubleyou.com/converters.htm
Otherwise as the suggestions go , pop it into a high street vendor .
Blue Skies,
David Cowman
email dcowman@eircom.net
tel +353 86 3822297
See my pics at
http://homepage.eircom.net/~mercurytechnologies/
