cameramonkey 0 #1 March 15, 2002 found a cool company that makes cases that can be used for camera helmets. http://www.odysseygear.com/products/Specifically the "krom" cases. the KLP080 LP cases seem to be the perfect size for most topmounts, and the KMIC1212 might work well for side mounts. Mars music sells the 080 for about $70. I am currently researching another site that sells another LP case that is a bit wider that might work better for sidemounts, and also seeing if they can cut down the 1212 so it isnt as tall(depth (front to back) was the problem I was having) Quote Share this post Link to post Share on other sites
