dancy 0 #1 October 13, 2011 My exit weight is about 154 lbs (I'm a thin, tall woman). I want to do RW with a guy who is 215 lbs. How much lead should I wear? Is it preferable to put on a belt or a west? Quote Share this post Link to post Share on other sites
StreetScooby 5 #2 October 13, 2011 I've been wearing lead for years, sometimes 20+ lbs. Without a doubt, the belt is the better way to go. Using a vest caused my neck to be quite sore by the end of the day. Never had any issues like that with the belt. Wearing that much weight with a belt is going to put the weight right on top of your hip "pointer". That can get uncomfortable during the course of the day. Try and find a weight belt that will let you skip those pouches right on top of the hip. If you need more weight, and need to use a vest in addition, max out the weight on the belt. Re: amount of weight, you're looking at minimum 20 lbs, IMO. Also, pack your main to open slower rather than faster The 200+ lb guy could look into using a fabric jump suit, instead of the "slick" ones. They'll grab a little more air, since they're porous, and slow him down. Whatever you do, don't arch too much. To do good 4-way, you really need a solid box position. Otherwise, you'll end up changing body positions when taking compressed grips, etc. That's going to cause issues with having a steady fall rate (i.e., you'll put "burbles" into the formation). We are all engines of karma Quote Share this post Link to post Share on other sites
Remster 30 #3 October 13, 2011 Starting with 20 is pretty aggressive IMO. My wife _sometimes_ wears that much, but when we do 4 way, and us 2 centers are in the 220-230 lb range (she's 120 and 5'5), but she normally wears between 14 and 18. To the OP: start with what you are comfortable wearing (remember it will significantly change your canopy wing load) and see from there. he may need to wear sleeves or a baggier suit, and you may need to add more.Remster Quote Share this post Link to post Share on other sites
dancy 0 #4 October 14, 2011 Thank you for the advise. I have a larger canopy than I could fly safely (168 Pilot) so the wingload doesn't bother me. Anyway I think I'll start with less lead and put on more if necessary. 20 lb seems a lot Quote Share this post Link to post Share on other sites
StreetScooby 5 #5 October 14, 2011 Quote Starting with 20 is pretty aggressive IMO. Good point. That was based on my personal experience, and that may not be valid for everyone. I'm 6'1", and typically have weighed around 160. The guys I like to do 4-way with are fast fallers, and in general, I like to fall fast.We are all engines of karma Quote Share this post Link to post Share on other sites
StreetScooby 5 #6 October 14, 2011 Quote I'll start with less lead and put on more if necessary Just remember to keep a good box. If you can't keep your hands below the plane of your chin, you should probably put on more weight.We are all engines of karma Quote Share this post Link to post Share on other sites
Baksteen 84 #7 October 14, 2011 Quote Thank you for the advise. I have a larger canopy than I could fly safely (168 Pilot) so the wingload doesn't bother me. Anyway I think I'll start with less lead and put on more if necessary. 20 lb seems a lot As Dragon2 once pointed out to me: Remember that you'll be loading your reserve that much heavier too. Sound advice."That formation-stuff in freefall is just fun and games but with an open parachute it's starting to sound like, you know, an extreme sport." ~mom Quote Share this post Link to post Share on other sites
dragon2 2 #8 October 14, 2011 Quote Quote Thank you for the advise. I have a larger canopy than I could fly safely (168 Pilot) so the wingload doesn't bother me. Anyway I think I'll start with less lead and put on more if necessary. 20 lb seems a lot As Dragon2 once pointed out to me: Remember that you'll be loading your reserve that much heavier too. Sound advice. Ah, yeah. . As I should have remembered when loading up on lead thereby loading my Techno 115 @ 1.7 last year, and coming in hot. ciel bleu, Saskia Quote Share this post Link to post Share on other sites
rehmwa 2 #9 October 14, 2011 Faster fall rate techniques help a lot too. From a boxman, your only option is to arch harder which doesn't do a damn thing in making your cross section seen by the relative wind any smaller. Take a mantis camp - fast fall rate - equals narrow and small and you get a LOT more range from just flying your body. You get the small benefit from the rounder arch, PLUS you have more options in making yourself smaller to the wind. That said, that's a big difference in weight and form for flying with your friend. Just work your way up to the higher lead. vests suck, they pitch you down. a good belt is a great. ... Driving is a one dimensional activity - a monkey can do it - being proud of your driving abilities is like being proud of being able to put on pants Quote Share this post Link to post Share on other sites
Ron 10 #10 October 14, 2011 Whatever you do... Start slowly and add slowly. You do not want to strap on 10-20 pounds for your first jumps. Start with ~4 then add slowly. And as others have said, consider WL's Bill's point about body position is valid.... As is the person who suggested the bigger person wear lead."No free man shall ever be debarred the use of arms." -- Thomas Jefferson, Thomas Jefferson Papers, 334 Quote Share this post Link to post Share on other sites
Remster 30 #11 October 14, 2011 Quote I'm 6'1", and typically have weighed around 160. Skinny fucker... A friend of mine back in Alberta used to wear 2 belts, with about 30-35 lbs total for 4way. He was about 6'2 or 6'3 and was pretty skinny too. That being said, to the OP: sound slike you have a good plan. Start with less weight (what you feel confy with in freefall and under canopy) and look into adjusting your position, getting the others to slow down, and possible add more lead if needed. But in the end, dont be afraid of lead, and dont see it as a failure (some do). We just have so many body types out there, that us heavies add drag, and you lightweights add lead. Remster Quote Share this post Link to post Share on other sites
StreetScooby 5 #12 October 14, 2011 Quote Skinny fucker... Be careful... I started lifting weights last January and I'm now up to 175 We are all engines of karma Quote Share this post Link to post Share on other sites
Rugby82 0 #13 October 24, 2011 Try contacting Frank van Gelder from LookMa (www.lookma.de). He makes a new type of lead vest which is much more comfortable than most current belts and vests (and with a cutaway). When you wear one it doesn't feel like a belt with the same amount of lead, it's much more comfortable. He also takes in account your height and weight to place the lead in the position that will help you the most for controlling you fallrate.Blue skies! Quote Share this post Link to post Share on other sites
rehmwa 2 #14 October 24, 2011 Frank's look pretty overdesigned for the use, but at least he looks like he's trying to get there. He should do a search and find the ones that Velocity used to make with the permanent wieght in the lumbar shape in the back - with pockets on the side to add more. Simpler, but the end goal is similar. I don't thank anyone is making ones like those any more. They were about the best design out there for comfort. My wife was going to start trying to build a similar design, but we just don't make belts any more except for close friends. The cost of shot is just all over the place lately. other options to the OP - some rigs can also be ordered with weight pouch in the back pad... to no one in particular - the newer belts I've seen lately have been pretty disappointing, little reinforcement sewn in straps rather than straps that run the length of the belt,,,, the weights have actually come in plastic bags that are STAPLED shut. seriously? ... Driving is a one dimensional activity - a monkey can do it - being proud of your driving abilities is like being proud of being able to put on pants Quote Share this post Link to post Share on other sites
Ron 10 #15 October 24, 2011 QuoteHe should do a search and find the ones that Velocity used to make with the permanent wieght in the lumbar shape in the back - with pockets on the side to add more. Simpler, but the end goal is similar. I don't thank anyone is making ones like those any more. They were about the best design out there for comfort. John Storrie, Storrie Parachute Works in Denton, TX. He still makes them."No free man shall ever be debarred the use of arms." -- Thomas Jefferson, Thomas Jefferson Papers, 334 Quote Share this post Link to post Share on other sites
FastRon 0 #16 October 24, 2011 Best deal on shot I know- Consider visiting a trap range for "reclaimed" lead shot. Some pellets get a little deformed but ought to work fine. Last time I bought some for boat ballast, it was well under half the cost of unfired. Quote Share this post Link to post Share on other sites
rehmwa 2 #17 October 24, 2011 Quote I don't thank anyone is making ones like those any more. They were about the best design out there for comfort. John Storrie, Storrie Parachute Works in Denton, TX. He still makes them. John's a good guy, I'll send people his way. I'm still trying to convince Skimmer to just make a couple for us (once she has her pattern made, then I slyly have her add it to her offerings ..) see you this coming weekend ... Driving is a one dimensional activity - a monkey can do it - being proud of your driving abilities is like being proud of being able to put on pants Quote Share this post Link to post Share on other sites
freefallfrom10k 0 #18 November 5, 2011 I usually wear 16 lbs worth of weight. I weigh 136lbs and have a slick suit and still fall on average at 109mph. So id recommend around 16lbs Maytown Sport Parachute Club Never turn your back on a charging turtle. Quote Share this post Link to post Share on other sites
riggerrob 644 #19 February 2, 2012 QuoteBest deal on shot I know- Consider visiting a trap range for "reclaimed" lead shot. Some pellets get a little deformed but ought to work fine. Last time I bought some for boat ballast, it was well under half the cost of un-fired. ....................................................................... Try asking your rigger if he saves old lead seals from reserves. I have made several weight pouches from old lead seals. Back then I used to pack 200 reserves per year. Quote Share this post Link to post Share on other sites
riggerrob 644 #20 February 2, 2012 Weight belts have one major advantage: you can discard them - under canopy - if you open over water. That might prevent the whole "drowning" hassle. Quote Share this post Link to post Share on other sites
riggerrob 644 #21 February 2, 2012 "Quote... vests suck, they pitch you down. a good belt is a great." ........................................................................... This gets us in to thread drift about using weights to change balance. If you only need to adjust fall rate, stick with weights near your center of gravity: belt or inside your main container. Balance weights are a far more complex subject and usually start with a senior coach analysing video of you in formations. Some women have such a "low center of gravity" that they need to fully extend their legs and retract their arms to approach formations. These people might be helped by "balance weights." Balance weights are usually worn high on the torso. If you need balance weights, start by experimenting with a vest that has pockets at chest/shoulder blade level. Once you have determined how much weight and how high, contact a Master Rigger or container manufacturer and ask about the cost of sewing weight pockets into your back-pad or reserve container. Weight pockets in the back-pad are easy to change between jumps. Weight pockets inside the reserve container are rarely worn by any but the hardest-core competitors. Back in the mid-1990s I even sewed a few weight pockets onto the front of harnesses. Talons made between 1994 and 1997 had extra-long "mud flaps" (aka. 3-Ring covers) that could accomodate 3 to 5 pounds of lead per side. Quote Share this post Link to post Share on other sites
rehmwa 2 #22 February 2, 2012 one of our locals wears about half her weights in her rig - it looks very convenient and like it saves her a bunch of hassle ... Driving is a one dimensional activity - a monkey can do it - being proud of your driving abilities is like being proud of being able to put on pants Quote Share this post Link to post Share on other sites
BillyVance 35 #23 February 2, 2012 I have seen a few rigs that had pockets for weights sewn on the side that rests on the back. Sure, you feel the weight when you put the rig on all the way until you exit, then once you deploy, the weight is off of you. "Mediocre people don't like high achievers, and high achievers don't like mediocre people." - SIX TIME National Champion coach Nick Saban Quote Share this post Link to post Share on other sites
dragon2 2 #24 February 14, 2012 Quote I have seen a few rigs that had pockets for weights sewn on the side that rests on the back. Sure, you feel the weight when you put the rig on all the way until you exit, then once you deploy, the weight is off of you. I've seen a couple of javelins like that. I likes. Just wouldn't be smart to wear lead in your rig while jumping near water - you can't ditch it like you can a weightbelt. I'm not actually sure you can use it in a swoop competition, for that reason. ciel bleu, Saskia Quote Share this post Link to post Share on other sites
Ron 10 #25 February 14, 2012 QuoteJust wouldn't be smart to wear lead in your rig while jumping near water - you can't ditch it like you can a weightbelt. I plan on ditching the whole rig if I land in the water.... So, I don't see the weights as part fo the rig being that big of a deal. In fact, it is one less piece of kit to ditch in the event of an emergency."No free man shall ever be debarred the use of arms." -- Thomas Jefferson, Thomas Jefferson Papers, 334 Quote Share this post Link to post Share on other sites
