hchunter614 0 #51 January 3, 2012 Glad to see this in this forum and not the incidents Kelly. Curtis Quote Share this post Link to post Share on other sites
missbrz 0 #52 January 3, 2012 QuoteQuotedid the cutter cut the loop, my guess is no. Nope. My closing loop was not cut. Then I'm slightly confused. From what I understand, that would mean it was NOT a Cypres fire. Am I correct in that? Or can a Cypres fire w/o cutting the loop? (not specifically asking for an answer from the OP just happen to be using her quote so I can learn) Quote Share this post Link to post Share on other sites
labrys 0 #53 January 3, 2012 QuoteOr can a Cypres fire w/o cutting the loop? Under a very narrow set of circumstances, yes. On my rig, the cutter is located directly under the reserve flap very close to the reserve pin. If the reserve pin is pulled and the loop is pulled through the cutter and there's still enough airspeed to cause the AAD to activate then the CYPRES will have fired without cutting the loop. That's completely normal... just pretty hard timing. Some containers have the cutter mounted at the base of the closing loop. In that case, it's hard (impossible?) to tell if the reserve pin was pulled before or after the CYPRES fire. Make sense?Owned by Remi #? Quote Share this post Link to post Share on other sites
pchapman 280 #54 January 3, 2012 Quote Then I'm slightly confused. From what I understand, that would mean it was NOT a Cypres fire. Am I correct in that? Depends on the rig. In some brands the cutter is at the base of the loop so when the reserve is out, the loop is still in the cutter. In other rigs, the cutter is on one of the flaps, so the flap moves off the loop when the pilot chute jumps out or the freebag is pulled out. Then the cutter would close and cut nothing. Have a rigger show you some day if you can, to understand the internal parts of rigs better. Quote Share this post Link to post Share on other sites
monkycndo 0 #55 January 3, 2012 If the cutter is above the freebag, once the reserve is out of the container, the cutter is off the loop. The cutter will fire, but the loop will be intact.50 donations so far. Give it a try. You know you want to spank it Jump an Infinity Quote Share this post Link to post Share on other sites
mirage62 0 #56 January 3, 2012 What she is saying (I believe) is that she "Beat the cypress" pulling after it had started it's count down but the cypress didn't cut the loop(?). So she in effect "saved herself". For myself it didn't matter one bit if I beat it or not, it did activate and thats to fucking low. But other thoughts on that may vary.Kevin Keenan is my hero, a double FUP, he does so much with so little Quote Share this post Link to post Share on other sites
missbrz 0 #57 January 3, 2012 QuoteQuote Then I'm slightly confused. From what I understand, that would mean it was NOT a Cypres fire. Am I correct in that? Depends on the rig. In some brands the cutter is at the base of the loop so when the reserve is out, the loop is still in the cutter. In other rigs, the cutter is on one of the flaps, so the flap moves off the loop when the pilot chute jumps out or the freebag is pulled out. Then the cutter would close and cut nothing. Have a rigger show you some day if you can, to understand the internal parts of rigs better. ah gotcha. Everybody's response makes sense. I'll try to find a way to see the difference. Is it the same for Vigils as well? Quote Share this post Link to post Share on other sites
labrys 0 #58 January 3, 2012 Quote For myself it didn't matter one bit if I beat it or not, it did activate and thats to fucking low. I'm just trying to drag one little scrap of dignity out of all the other incredibly stupid things I did. Owned by Remi #? Quote Share this post Link to post Share on other sites
InfiniteSky 0 #59 January 3, 2012 Quote ah gotcha. Everybody's response makes sense. I'll try to find a way to see the difference. Is it the same for Vigils as well? Yes. The brand of AAD doesn't matter in this situation. What matters is the location of the cutter. Quote Share this post Link to post Share on other sites
missbrz 0 #60 January 3, 2012 Quote Quote ah gotcha. Everybody's response makes sense. I'll try to find a way to see the difference. Is it the same for Vigils as well? Yes. The brand of AAD doesn't matter in this situation. What matters is the location of the cutter. Gotcha. Thanks for the knowledge everyone Quote Share this post Link to post Share on other sites
monkycndo 0 #61 January 3, 2012 Quote I'm just trying to drag one little scrap of dignity out of all the other incredibly stupid things I did. Kelly, I spooked my Cypres at jump 58. Ended up landing with two out. That was an expensive jump counting the repack and replacement cutter. But it was invaluable considering the lessons learned and I can guarantee you that it has made me a more aware skydiver because of it. Props to you for posting it on here and taking all the well meaning ribbing, the jabs, and the unwarranted stupid shit slinging so that others might learn from your experience. And yes, that ground gets real big, real fast when you are dirty low.50 donations so far. Give it a try. You know you want to spank it Jump an Infinity Quote Share this post Link to post Share on other sites
d123 4 #62 January 3, 2012 dude, I really like your ideas. Stay youself.Lock, Dock and Two Smoking Barrelrolls! Quote Share this post Link to post Share on other sites
hookitt 1 #63 January 3, 2012 Quote Quote For myself it didn't matter one bit if I beat it or not, it did activate and thats to fucking low. I'm just trying to drag one little scrap of dignity out of all the other incredibly stupid things I did. It was high enough. It may have sucked, but you were still high enough. You'd have been lower if the AAD was what put you under canopy. You got what you needed out of this experience, just move forward. Good luck. It was kind of you to share this.My grammar sometimes resembles that of magnetic refrigerator poetry... Ghetto Quote Share this post Link to post Share on other sites
Divalent 169 #64 January 3, 2012 Quote I'm just trying to drag one little scrap of dignity out of all the other incredibly stupid things I did. Great save on the reserve closing loop! Quote Share this post Link to post Share on other sites
labrys 0 #65 January 3, 2012 Hahaha! Thanks. Those are expensive.Owned by Remi #? Quote Share this post Link to post Share on other sites
DaVinciflies 0 #66 January 3, 2012 Quote I'm just trying to drag one little scrap of dignity out of all the other incredibly stupid things I did. Swallowing your pride and posting here so that others might benefit from the learning experienced is a very dignified thing to do. Glad you're ok. That video scared me. Quote Share this post Link to post Share on other sites
Austintxflight 0 #67 January 3, 2012 You can clearly see right at the 28 second mark the cutaway handle in your hand, but to the larger point. I don't really see the problem with this video, you set yourself up for a perfect swoop, you just didn't finish it. But serious congrats on the save. Plus you are now the new inspiration for the audioslave song "Cochiese" Quote Share this post Link to post Share on other sites
CrazyL 0 #68 January 4, 2012 Way to go get'n the chain of events to sway back in your favor to survive. Having issues with each deployment handle sheesh! Sounds like you used 2 of your 3 options in getting a parachute to deploy in time. Your dignity should still be in tact. I had a high speed mal before jumping a freefly unfriendly rig, time went by fast in a slow motion sort of way. The odds were stacking against me quick, one deadly surprise after another wasting time. Was not as easy as look reach pull. I fought and won the battle like you. Humbling, for sure. Could've done things differently, so I learned even more. Things were different in a good way the jumps thereafter. Hope yours are too. Quote Share this post Link to post Share on other sites
Andy9o8 3 #69 January 4, 2012 QuoteThank you for posting this, for it reinforces one of the most basic rules of keeping yourself alive on a skydive: "Once, twice; go to silver". I'll add that your emergency is also yet another a good advertisement for jumping an AAD, even on "lower-risk" jumps. You didn't get knocked out from an impact; you didn't get G-LOC from a flat spin; you didn't have a heart attack or a seizure; you didn't just "lose altitude awareness"; your hard pull wasn't gear-related; you're young and healthy - and yet a cascade of factors led to you taking it really low. Fortunately you found your floating reserve handle, but what if you hadn't? In the pre-AAD days (which I lived through; I also survived a [gear-related] total mal when I was 19 and in great shape) "going in with no handles pulled", without apparent cause or explanation, was a lot more common than it is today. AADs (and, to a lesser extent, audibles and higher pull altitudes) are the reason why. Quote Share this post Link to post Share on other sites
theonlyski 8 #70 January 4, 2012 QuoteQuoteQuote Then I'm slightly confused. From what I understand, that would mean it was NOT a Cypres fire. Am I correct in that? Depends on the rig. In some brands the cutter is at the base of the loop so when the reserve is out, the loop is still in the cutter. In other rigs, the cutter is on one of the flaps, so the flap moves off the loop when the pilot chute jumps out or the freebag is pulled out. Then the cutter would close and cut nothing. Have a rigger show you some day if you can, to understand the internal parts of rigs better. ah gotcha. Everybody's response makes sense. I'll try to find a way to see the difference. Is it the same for Vigils as well? Remind me to show you all of this when you come pick up your rig tonight. I'll show you exactly what happened. Maybe I'll even pop mine so I can show you where the cutter on the V3 (like she has) is and how it could happen."I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
labrys 0 #71 January 5, 2012 QuoteI'll add that your emergency is also yet another a good advertisement for jumping an AAD, even on "lower-risk" jumps. You didn't get knocked out from an impact; you didn't get G-LOC from a flat spin; you didn't have a heart attack or a seizure; you didn't just "lose altitude awareness"; your hard pull wasn't gear-related; you're young and healthy - and yet a cascade of factors led to you taking it really low. This is one of the most astute things I've taken away from this experience, Andy. I feel that I'm a reasonably capable and competent person. Certainly not a young, fit athlete, but capable enough. I've taught hundreds of students to try twice and go to silver. I'll give myself a pass for trying 3 times because I started out pretty high... But the attempt to shift my rig was completely unplanned. I'd never considered doing such a thing and I'd have told anyone who suggested trying it that low that they were a fool. And yet there I was, CYPRES aside, about 4 seconds from cratering in with nothing out for no reason at all. No reason.Owned by Remi #? Quote Share this post Link to post Share on other sites
ufk22 33 #72 January 5, 2012 QuoteQuoteI'll add that your emergency is also yet another a good advertisement for jumping an AAD, even on "lower-risk" jumps. You didn't get knocked out from an impact; you didn't get G-LOC from a flat spin; you didn't have a heart attack or a seizure; you didn't just "lose altitude awareness"; your hard pull wasn't gear-related; you're young and healthy - and yet a cascade of factors led to you taking it really low. This is one of the most astute things I've taken away from this experience, Andy. I feel that I'm a reasonably capable and competent person. Certainly not a young, fit athlete, but capable enough. I've taught hundreds of students to try twice and go to silver. I'll give myself a pass for trying 3 times because I started out pretty high... But the attempt to shift my rig was completely unplanned. I'd never considered doing such a thing and I'd have told anyone who suggested trying it that low that they were a fool. And yet there I was, CYPRES aside, about 4 seconds from cratering in with nothing out for no reason at all. No reason. I'd say you SHOULDN'T take a pass on the "try 2, go to silver". If you had followed this you'd been in the saddle plenty high. The rules we teach to students aren't just for students. I also learned this with a very low pull.This is the paradox of skydiving. We do something very dangerous, expose ourselves to a totally unnecesary risk, and then spend our time trying to make it safer. Quote Share this post Link to post Share on other sites
Kipu 0 #73 January 21, 2012 a few times? That's a horrible place to land. How did that happen? Quote Share this post Link to post Share on other sites
bodypilot90 0 #74 January 21, 2012 One was a reserve ride, one was getting out first, first load of the day. I chose both times to sink it in and had no problems, other than a long walk back. and I had a good tale to tell. heck I waited till my 3rd jump to land at the dz. Tandem landed out and my 1st aff I landed out, that was all my fault. Canopy control is important, You life may depend on it. (it does) Quote Share this post Link to post Share on other sites
Amazon 7 #75 January 21, 2012 Quote I have a couple of jumps from the NRGB. 800 feet on Bridge Day is definitely not the same visual as 800 feet at terminal. I'm not from the area, but it's hard to imaging that much swampy ground doesn't have some gators and snakes living in it. Dont forget... Swamp Thing is out there too... Quote Share this post Link to post Share on other sites
