Rookeskydiver
how much does it cost for a rigger to install a cypress?
OK.. if the rig is packed, it's cypress ready, and I was the rigger, then you get charged for a repack. So far there are no exeptions.
Some shops may charge a nominal fee.
What kind of rig do you have?
My grammar sometimes resembles that of magnetic refrigerator poetry... Ghetto
No... you may not give it a go your self. Thats in violation of the FAR's. That is strictly rigger or rigger supervised area. There is a method to the madness of installing a Cypres and you need to follow it as to not damage the unit.
I'd do it for free and so does my teaching rigger as long as the rig is cypres ready, but I know a few riggers that charge less then $10 so that they can inspect the unit more, and stuff.
Yesterday is history
And tomorrow is a mystery
Parachutemanuals.com
My understanding is that it is master rigger territory due to it being a modification to the reserve deployment system
A senior rigger can assemble an AAD, if the container is set-up for it, i.e. "Cypres Ready". If it isn't, then it is Master Rigger territory.
Hook
IIRC it's master rigger territory if the container did not come Cypres ready from the factory, senior rigger if the container did come Cypres ready from the factory. Which made sense to me - installing the Cypres is technically a modification if the container was not originally Cypres ready; the pockets and channels have to be sewn into the reserve container. Installing a Cypres in a new rig that already has the pockets and channels is simply a matter of following instructions and is not a modification.
Phree,
My understanding is that it is master rigger territory due to it being a modification to the reserve deployment system....(which I think is crap)
According to the Parachute Rigging Course, 2000 revision, original installation is a master rigger job. With the manufacturer's authorization, installation of an AAD in an AAD-ready rig is a senior rigger job. Removal and reinstallation of any AAD for service or cleaning is a senior rigger job.
My Vector 3 manual says, "A Master Rigger rating is still required even if the system is already prepared by the Relative Workshop to accept the AAD." I believe this is the latest manual (bought a month ago), and I can't find any updates or service bulletins on RWS' web site.
On the other hand, the reserve assembly and packing instruction's on Mirage's website seem to indicate that the entire process (including Cypres installation) can be done by a senior rigger.
I think this one was successfully argued many times to the FAA and it was decided Senior riggers could install them.
It depends upon whether there is any sewing involved. If the rig leaves the factory "Cypres/Astra-ready" and it is a simple slide-in installation with maybe a little hand tacking, then a Senior Rigger can do it. If there is any machine sewing involved, then the FAA considers it an "alteration" to a reserve container and you have to call in a Master Rigger.
This would be a Mfg. requirement not the FAA. If this were true only a Master Rigger could remove and install a Cypress sent off for 4 and 8 year checks or battery changes. In fact a Senior Rigger could not even check the dates since it would require removing the main unit for inspection.
On this topic precise word choice is important. We went over this several times at DeWolf's course because a few people were confused.
"Install an AAD" means to make an alteration to the container to accept the use of an AAD. Master rigger teritory.
"Assembly of an AAD" means to place an AAD in a manufacturer approved cypres ready container. Senior rigger territory. See AC105-2C
God love the legalease of the FAR's
Ken
"Buttons aren't toys." - Trillian
Ken
OK.. if the rig is packed, it's cypress ready, and I was the rigger, then you get charged for a repack. So far there are no exeptions.reply]
I took my new cypres and rig to the same rigger who packed my reserve last. He charged me a fiver (about $8 US ) to install it, as it was aleady cypres-ready (had one in previously).
Blue skies, high dives (does anyone sayt hat anymore?)
