skydiverek 63 #1 January 21, 2003 I know Dacron lines stretch more during opening than Spectra/Microline (thus lowering the opening shock a little bit). My question is: how much does a Dacron line attached to canopy stretch during opening? One inch, 1/10th of an inch? How much? Bart Quote Share this post Link to post Share on other sites
riggerrob 643 #2 January 21, 2003 Look in Poynter's Manual for Dacron stretch rates. I suspect that the main reason Dacron-lined canopies open softer is that thicker, stiffer Dacron lines take a fraction of a second longer to slip through slider grommets. This logic is similar to the notion that a thicker rope equals slower rappelling. This is highly un-scientific, because slider performance is very difficult to measure. Quote Share this post Link to post Share on other sites
rigging65 0 #3 January 21, 2003 Bart- Mil Spec. cord is tested for elongation under Federal Standard 191, using test method 6016. The test method (in a nut shell) says you load a cord to 75% of it's rated strength, then measure elongation. For Dacron cord tested under this method (which is what you would find on most canopies) you can have no more than 12% elongation. Spectra is 6% max. Now, seeing as how you would rarely load a line to 75% of it's rated strength, you need to figure out line loads first, then extrapolate the elongation from it. Suffice it to say, Dacron stretches twice as much as Spectra. "...and once you had tasted flight, you will walk the earth with your eyes turned skyward. For there you have been, and there you long to return..." Quote Share this post Link to post Share on other sites
skydiverek 63 #4 January 21, 2003 QuoteBart- Mil Spec. cord is tested for elongation under Federal Standard 191, using test method 6016. The test method (in a nut shell) says you load a cord to 75% of it's rated strength, then measure elongation. For Dacron cord tested under this method (which is what you would find on most canopies) you can have no more than 12% elongation. Spectra is 6% max. Now, seeing as how you would rarely load a line to 75% of it's rated strength, you need to figure out line loads first, then extrapolate the elongation from it. Suffice it to say, Dacron stretches twice as much as Spectra. Thank you for this great information! Quote Share this post Link to post Share on other sites
skydived19006 4 #5 February 16, 2005 I did a search on this subject and found this thread. Now Vectran is supposed to basically not stretch at all, but in reality compared to Dacron and or Spectra how much does it really stretch. Also the big advantage of Vectran as I understand is that it doesn’t distort. How does Spectra compare to Dacron with regard to distortion? If bulk and drag are out of the equation is there an advantage to Spectra over Dacron? QuoteBart- Mil Spec. cord is tested for elongation under Federal Standard 191, using test method 6016. The test method (in a nut shell) says you load a cord to 75% of it's rated strength, then measure elongation. For Dacron cord tested under this method (which is what you would find on most canopies) you can have no more than 12% elongation. Spectra is 6% max. Now, seeing as how you would rarely load a line to 75% of it's rated strength, you need to figure out line loads first, then extrapolate the elongation from it. Suffice it to say, Dacron stretches twice as much as Spectra.Experience is what you get when you thought you were going to get something else. AC DZ Quote Share this post Link to post Share on other sites
mark 107 #6 February 16, 2005 QuoteFor Dacron cord ... you can have no more than 12% elongation. Spectra is 6% max. ... Dacron stretches twice as much as Spectra. 12 = 2 x 6, but 112 <> 2 x 106. The A-lines on a Sabre2 150 are 124" plus a little. With mil-spec Dacron they could stretch to 139," with Spectra to between 131" and 132." That's IF they're loaded to 75% of rated strength, which might happen in a really hard rogue (Bill Von spells "rouge" which is French for "red" which is weirdly appropriate) opening, but consider you've got 20 lines to spread the load to the links. After the canopy is open and you are in straight, unaccelerated flight, the load on each line is something less than 20 pounds, a fraction of the rated strength of Dacron or Spectra. Elongation (or lack) is a deployment issue, but otherwise not a performance issue for either material. For Spectra, the problem is shrinking from grommet friction during opening. If it weren't for the bulk and drag, I think we'd all prefer Dacron because of its dimensional stability -- hence the continuing search for alternatives that's taken us past Kevlar to Vectran, HMA, and beyond. Mark Quote Share this post Link to post Share on other sites
skydiverek 63 #7 February 17, 2005 QuoteI suspect that the main reason Dacron-lined canopies open softer is that thicker, stiffer Dacron lines take a fraction of a second longer to slip through slider grommets. That, plus as it was pointed they stretch more, and also provide more friction for the slider grommets (as compared to Microline). Do you think that having thicker Dacron lines increases the chances of having tension knots or slider hang-ups (since the bunch of thicker lines will be trying to fit in the same size slider grommets, which are used with Microline)? Quote Share this post Link to post Share on other sites
mjosparky 4 #8 February 17, 2005 Quote(since the bunch of thicker lines will be trying to fit in the same size slider grommets, which are used with Microline)? The Microline is trying to fit in the same grommets that they have always used for sliders, #8. My Sharpchuter has 750 Dacron, no problems. SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
skydiverek 63 #9 February 17, 2005 QuoteThe Microline is trying to fit in the same grommets that they have always used for sliders, #8. Both Dacron and Microline can try fitting in #8 brass grommets OR #25 stainless steel grommets. BTW, #8 brass grommets are 2 mm wider when it comes to inside diameter (at least the ones PD is using), so maybe they are better for bulkier Dacron lines? Quote Share this post Link to post Share on other sites
mjosparky 4 #10 February 17, 2005 QuoteQuoteThe Microline is trying to fit in the same grommets that they have always used for sliders, #8. Both Dacron and Microline can try fitting in #8 brass grommets OR #25 stainless steel grommets. BTW, #8 brass grommets are 2 mm wider when it comes to inside diameter (at least the ones PD is using), so maybe they are better for bulkier Dacron lines? Are they SS or plated brass?My idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
riggerrob 643 #11 February 17, 2005 For tension knots, the worst combination is old, fuzzy, dusty Dacron lines packed sloppily. If you do not get every single twist and kink out of old Dacron lines, they tend to knot. Desert dust just makes Dacron stiffer and more difficult to straighten. In the Southern California desert, only the best of packers could make Dacron-lined Strong tandem canopies open reliably. Quote Share this post Link to post Share on other sites
beezyshaw 0 #12 February 17, 2005 I think people are not making the proper distinction between "stretch" and "elongation". Stretch is the elasticity of a line, and the line returns to original length after deployment forces are reduced. Elongation is the more permanent lengthening over time from loads being imposed on the line. Big difference here. Dacron has the most stretch during deployment, and Spectra stretches virtually none. Spectra in skydiving applications will shrink due to friction heat, but in other applications (like sailing)Spectra is bad about "creep" or elongation when tightened with a wench. Quote Share this post Link to post Share on other sites
ryoder 1,590 #13 February 17, 2005 QuoteFor tension knots, the worst combination is old, fuzzy, dusty Dacron lines packed sloppily. If you do not get every single twist and kink out of old Dacron lines, they tend to knot. Desert dust just makes Dacron stiffer and more difficult to straighten. In the Southern California desert, only the best of packers could make Dacron-lined Strong tandem canopies open reliably. Going from memory here; I believe I saw a posting from Booth where he stated the field statistics he gathered from the RWS tandem program indicated Dacron-lined tandems with >300 jumps on the lines had 2X the malfunction rate of identical canopies with <300 jumps on the lines."There are only three things of value: younger women, faster airplanes, and bigger crocodiles" - Arthur Jones. Quote Share this post Link to post Share on other sites
billbooth 10 #14 February 17, 2005 That number is true. Quote Share this post Link to post Share on other sites
skydiverek 63 #15 February 18, 2005 QuoteI believe I saw a posting from Booth where he stated the field statistics he gathered from the RWS tandem program indicated Dacron-lined tandems with >300 jumps on the lines had 2X the malfunction rate of identical canopies with <300 jumps on the lines. Would this apply also to sport canopies? Quote Share this post Link to post Share on other sites
beezyshaw 0 #16 February 18, 2005 QuoteWould this apply also to sport canopies? Bill can jump in and correct me if I'm wrong, but I would say it does not apply to sport mains. One of things about tandem canopies with dacron lines is the fact that (on PD tandems at least) 900 lb line is used. That large line barely fits in the slider grommet, so when it becomes worn, and thus larger than when new, it lends itself to a higher malfunction rate. Sport canopies would usually be lined with 525 lb dacron, so the much smaller line wouldn't have the same consequences. Quote Share this post Link to post Share on other sites
billbooth 10 #17 February 18, 2005 I have no data about malfunction rates vs. age of Dacron lines on sport canopies. Quote Share this post Link to post Share on other sites
mjosparky 4 #18 February 18, 2005 QuoteI have no data about malfunction rates vs. age of Dacron lines on sport canopies. I guess that means tandem jumping is not sport? I've got hundreds of jumps on canopies with dacron lines without having a malfunction caused by the lines. But then, I pack my own rig. SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
skydived19006 4 #19 June 2, 2005 So, what type of line do the different manufacturers use on their tandem canopies as “standard”? I still have one Icarus tandem canopy with Vectran, and had decided to go with Dacron when I get it relined. Now I see that Dacron tends to get bulky with wear (even more bulky than it is new), which may lead to a slider hanging up. The pack volume and drag are not a deciding issue for me on my tandem canopies. What I would like is something that will stretch on opening, but not distort much, which lead me back to Dacron. What I’m really not interested in is increasing my malfunction rate (over 600 tandems and no malfunctions)! What line do you prefer on your tandem canopies, and why? Martin Air Capital Drop ZoneExperience is what you get when you thought you were going to get something else. AC DZ Quote Share this post Link to post Share on other sites
ryoder 1,590 #20 June 2, 2005 I think you may have intended to post your followup to BillBooth rather than me. I do know RWS/Booth use Dacron on their tandems. I don't know what the other mfgrs are using."There are only three things of value: younger women, faster airplanes, and bigger crocodiles" - Arthur Jones. Quote Share this post Link to post Share on other sites
skydived19006 4 #21 June 2, 2005 I basically just picked a post to reply to. Generally, I think Bill Booth knows a little more about skydiving gear than I do!!! If his preference if Dacron on his tandem rigs, that’s good enough for me! MartinExperience is what you get when you thought you were going to get something else. AC DZ Quote Share this post Link to post Share on other sites
billbooth 10 #22 June 3, 2005 Tandem canopies are public transportation. Little old ladies and parapelgics jump tandem. Dacron lines give lower opening shocks. It's that simple. This might not matter much on a "normal" opening, but if someone make a small mistake packing which results in a super fast opening, the Dacron lines could save somebody's grandmothers life. I know Dacron is bulkier, but I've seen no evidence that Dacron lined canopies have more malfunctions. In fact, I believe the opposite may be true. Quote Share this post Link to post Share on other sites
skydived19006 4 #23 June 3, 2005 QuoteTandem canopies are public transportation. Little old ladies and parapelgics jump tandem. Dacron lines give lower opening shocks. It's that simple. This might not matter much on a "normal" opening, but if someone make a small mistake packing which results in a super fast opening, the Dacron lines could save somebody's grandmothers life. I know Dacron is bulkier, but I've seen no evidence that Dacron lined canopies have more malfunctions. In fact, I believe the opposite may be true. Thanks Bill! That’s good enough for me. I had decided to go with Dacron, but the reference in this thread to a two fold increase in malfunction rate with worn Dacron lined tandem canopies concerned me a bit. I don’t have a problem with replacing line sets every 500 jumps or so, for us that’s only one line set a year. Besides, my neck isn’t as young as it used to be either! Martin AC DZExperience is what you get when you thought you were going to get something else. AC DZ Quote Share this post Link to post Share on other sites
riggerrob 643 #24 June 3, 2005 QuoteSo, what type of line do the different manufacturers use on their tandem canopies as “standard”? >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Strong used Dacron lines on their F-111 tandem mains. We had Vectran lines on a SET-400, but eventually replaced them with Spectra when they got "too ugly, too quick." Vectran was fashionable circa 2000, but has been replaced on sport canopies by HMA 2. Now all of our SET-400s have factory-supplied Spectra lines. Opening and landing performance on all Strong tandem mains deteriorate rapidly after 300 jumps on a line set. Has anyone tried HMA lines on tandems? Quote Share this post Link to post Share on other sites masterrigger1 2 #25 June 4, 2005 Rob, What in the world is HMA 2. I have never heard of it??? Also Vectran is still fashionable. We still put 500 + jumps on line sets even in the desert. HMA has been put on tandems.. Strong is looking at it now. MELSkyworks Parachute Service, LLC www.Skyworksparachuteservice.com Quote Share this post Link to post Share on other sites Prev 1 2 Next Page 1 of 2 Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
