raymod2 1 #1 August 28, 2014 I see that Mirage ($100) and Sunpath ($80) are both selling removable belly bands. However, they seem to be designed for attachment to hip rings. Is anybody using these with a rig that does not have hip rings? Quote Share this post Link to post Share on other sites
rwieder 0 #2 August 28, 2014 QuoteI see that Mirage ($100) and Sunpath ($80) are both selling removable belly bands. However, they seem to be designed for attachment to hip rings. Is anybody using these with a rig that does not have hip rings? Have your container retro-fitted with articulating hip rings. I don't know any other way to utilize a belly band. I just had one installed on my Odyssey at Sun Path, it's pretty cool.-Richard- "You're Holding The Rope And I'm Taking The Fall" Quote Share this post Link to post Share on other sites
skow 6 #3 August 29, 2014 you could make your own by threading a (thin) climbing sling around the webbing point where the straps are sewn together. Just be creative :) A lot of people are doing this in BASE when repelling Quote Share this post Link to post Share on other sites
diablopilot 2 #4 August 31, 2014 Just remember to be extra vigilant in checking your harness for wear with such straps installed as chafing will occur. You all do check your harnesses for wear on a regular basis, don't you?---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites
raymod2 1 #5 September 6, 2014 Chuting Star just started selling a belly band for $85 that attaches easily to a harness without hip rings: http://www.chutingstar.com/skydive/volitant-padded-adjustable-belly-band It has loops on each end and it comprises two parts so that you can girth hitch each side to your harness. Then it operates just like a chest strap. See the attached photos. Quote Share this post Link to post Share on other sites
SkymonkeyONE 4 #6 September 15, 2014 diablopilotJust remember to be extra vigilant in checking your harness for wear with such straps installed as chafing will occur. You all do check your harnesses for wear on a regular basis, don't you? So very true. Quote Share this post Link to post Share on other sites
