jacketsdb23 49 #1 June 9, 2014 So its no secret that some of us had to drop our turn initiation point in Florida during the recent FLCPA/Nationals competition. For me it was significant, about 100' lower than I usually turn. My home DZ and Zhills are both roughly 80' - 90' MSL. Water vapor was much higher in Florida, which would suggest less dense air. Temperature was fairly high in FL, but we get 90ºF - 100ºF days frequently here as well. Something else was definitely a factor here and I'm trying to wrap my head around it. There is usually a lot of talk about density altitude tied to temperature and LZ elevation, but I'm wondering what other factors might be in play.Losers make excuses, Winners make it happen God is Good Beer is Great Swoopers are crazy. Quote Share this post Link to post Share on other sites
wildcard451 0 #2 June 9, 2014 jacketsdb23So its no secret that some of us had to drop our turn initiation point in Florida during the recent FLCPA/Nationals competition. For me it was significant, about 100' lower than I usually turn. My home DZ and Zhills are both roughly 80' - 90' MSL. Water vapor was much higher in Florida, which would suggest less dense air. Temperature was fairly high in FL, but we get 90ºF - 100ºF days frequently here as well. Something else was definitely a factor here and I'm trying to wrap my head around it. There is usually a lot of talk about density altitude tied to temperature and LZ elevation, but I'm wondering what other factors might be in play. I was seeing density altitudes of -200 to -250ft consistently during FLCPA and Nationals. I was also turning comfortably 100' lower than normal (VA/NC). Also, we were routinely diving through thermal areas that are unfortunately due to the placement of the pond relative to the hangars and trailers at Zhills. Quote Share this post Link to post Share on other sites
diablopilot 2 #3 June 11, 2014 Humidity usually does not affect DA as much as people tend to think. Pressure and temperature are far bigger influences. Try this on for size.... http://www.boldmethod.com/learn-to-fly/performance/density-altitude/---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites
Divalent 172 #4 June 11, 2014 diablopilotHumidity usually does not affect DA as much as people tend to think. Pressure and temperature are far bigger influences. Try this on for size.... http://www.boldmethod.com/learn-to-fly/performance/density-altitude/ The point that Humidity is only a minor contributor is correct, but that source is clearly not a good place to go to learn about things. Here's a quote from the article: QuoteIn the atmosphere, Nitrogen usually exists as a N2 molecule - which means two Nitrogen atoms are bound together. Since Nitrogen's atomic mass is 7, one Nitrogen molecule weighs 14 units. Oxygen in the atmosphere generally exists as a O2 molecule, which means two Oxygen atoms are bound together. Oxygen's atomic mass is 8, so one O2 molecule weighs 16 units. Water molecules are made up of two Hydrogen atoms, each of which weighs one unit, and one Oxygen atom, which weighs 8 units - so a molecule of water vapor weighs 10 units. That is just incorrect. The author is confused about the difference between atomic number and atomic mass. Quote Share this post Link to post Share on other sites
vision 0 #5 June 11, 2014 I can concur that one must turn lower in humid air than in dry air... Not a lot for me (30 feet or so), but definitely enough for me to drop the initiation or vert the entry. Why? I am not sure. But that is not what is important, what is important is scoring the gates! Quote Share this post Link to post Share on other sites
Polorutz 0 #6 June 11, 2014 visionwhat is important is scoring the gates! And trusting your rears! Quote Share this post Link to post Share on other sites
Pendragon 1 #7 June 12, 2014 Discussed this with Scott Roberts years ago. What we came up with was: You do get a slight increase (as pointed out) in density air altitude as a consequence of moist air being less dense than dry air. This is because the same number of molecules occupy a given volume at a given temperature, and that water molecules (H2O = 18 g/mole) weigh significantly less than the main constituent of dry air (nitrogen, N2 = 28 g/mole). However, this effect would make the turn higher and not lower, but as pointed out, the effect is small. What is overriding is the change in air viscosity. Moist air is more viscous (like treacle) than dry air. As a consequence, the drag on the canopy is increased. Compared to the canopy, the suspended weight (the canopy pilot) has little surface, and so is little impacted by this change when compared to the canopy. After the turn has been initiated, the canopy will decelerate faster in humid conditions, causing a the pilot to travel a sharper arc under the canopy, thereby allowing the wing to recover to level flight faster. I've had similar experiences myself with the difference in turn initiation height this makes; back when I was jumping a Velo 90 or 96, I was doing the same 270 degree turn roughly 80-100' lower in Florida than back in the UK.-- BASE #1182 Muff #3573 PFI #52; UK WSI #13 Quote Share this post Link to post Share on other sites
