pchapman 280 #1 May 4, 2009 Someone at the DZ had an odd little snag issue yesterday. It's not about a big snag point, but is an example of how little things (including design issues) can cause problems in unexpected ways -- Murphy's Law type stuff. So Kyle was climbing out 2nd from the 182 for an RW jump. He presumably tilted his head to the left as he ducked out the door. He gets out on the step, and finds that he can't straighten his head up; his head is somehow stuck to his rig at the shoulder. Shannon behind him sees what's happening and decides to pull Kyle back inside to sort things out, while the outside hang jumper decides to drop off. Shannon and Kyle get back inside OK, sort things out, and jump after a go around. I didn't look closely at the helmet but at the Rawa's left side chin strap ratcheting attachment buckle, there's a bit of stiff steel wire that sticks out just a few millimetres on the bottom of the ratchet mechanism, forming a small hook facing I think towards the jumper's chin. There's nothing to protect the end of the wire. I think it is strong spring steel, part of the spring loaded function of the ratchet mechanism. (I don't know the age of the helmet, or if anything is different on older or newer ones.) As the jumper climbed out, that wire at the bottom of the ratchet hooked right into the fabric of the riser cover. The steel wire being quite stiff wasn't about to let go easily if the jumper tried to pull his head away from his shoulder straps, which would be anyone's natural inclination. The incident could also have happened at some other time, in freefall or under canopy. Granted, some head shaking in different directions, despite not knowing what the hell was going on, would likely have found the right direction to unhook the wire. Still, the RW group could well have jumped, with one guy not too happy about having his head pinned sideways to his rig! It's a small snag point on the helmet but it's still a snag point. Quote Share this post Link to post Share on other sites
Scrumpot 1 #2 May 4, 2009 Picture(s) might also be helpful here.coitus non circum - Moab Stone Quote Share this post Link to post Share on other sites
pchapman 280 #3 May 4, 2009 I didn't get a photo of the actual helmet involved. But online I found the attached Rawa pic. This is of a more recent version with a tab to quick release the chin cup. But one can still see the metal hook at the bottom of the adjuster. Seems that it might have been slightly longer on the one in the incident. P.S. - yet the metal is very small, and hard to see even on the closeup of the chin cup area Quote Share this post Link to post Share on other sites
humbled1 0 #4 May 4, 2009 actually since I had an idea what to look for, I saw it right away looking at that photo. I just checked my FF3 and nothing like that exists. Yesterday I just watched the 1st DVD from VAAST Aerial Camera with Norman Kent and he emphasized that ANY alteration or addition to our equipment has unintended consequences, even safety features. This is a perfect example of that, though I think this risk could be mitigated by the manfacturer, it doesnt take much to cause a big problem in the air. Good to hear it was noticed before it became a real problem!"Tell ya the truth, I don't think this is a brains kind of operation." Quote Share this post Link to post Share on other sites
pilotdave 0 #5 May 4, 2009 QuoteI just checked my FF3 and nothing like that exists. You sure? The FF2 has a similar metal spring on the ratchet strap hardware. No snagginess on mine though. Dave Quote Share this post Link to post Share on other sites
Scrumpot 1 #6 May 4, 2009 Would a small dalb of epoxy (or similar) over that, interfere with its function? Would seem a reasonable solution to alleviate the snag hazard I can now see - that seems to have. coitus non circum - Moab Stone Quote Share this post Link to post Share on other sites
pchapman 280 #7 May 4, 2009 As for comparing helmets, I just checked the chin strap on my camera helmet -- It happens to look reasonably good, for the spring is recessed into a groove on the ratchet. The chin cup assembly is from Sky Systems. It is starting to look like the spring design is similar on various ratchet mechanisms, but there are differences in how exposed they are. It is still a ridiculously small snag hazard compared to other things... Quote Share this post Link to post Share on other sites
humbled1 0 #8 May 5, 2009 Dave, yeah your right. I had just looked in the part where I saw it on the Rawa, where the strap goes into the chin cup. After looking more closely I saw the metal hook but at least it is set in a recessed notch and even sits flush with the metal. Thanks for the heads up dave edit: pchapman, actually my ff3 looks alot like your pic as far as the "little hook" goes "Tell ya the truth, I don't think this is a brains kind of operation." Quote Share this post Link to post Share on other sites
JohnRich 4 #9 May 5, 2009 QuoteIt's a small snag point on the helmet but it's still a snag point. Good analysis, and good work bringing this to everyone's attention. Until a better fix arrives, cover that wire end up with some gaffers tape to smooth it out. Quote Share this post Link to post Share on other sites
VerticalRush 0 #10 May 6, 2009 Same thing happened to me, It was hooking on the webbing wrapping the middle ring on my left riser. It grabbed immediately after exit. It was impossible to free until I deployed. I ordered a new chin cup and helmet quick release that night. Aaron. Quote Share this post Link to post Share on other sites
ZZTopless 0 #11 May 26, 2009 I had a similar thing happen to me at about 6000ft. The metal hook caught on the fabric loop for my RSL (not in use). I put hot glue over it that night on both sides and haven't had an issue since. Quote Share this post Link to post Share on other sites
brettski74 0 #12 May 27, 2009 QuoteI didn't look closely at the helmet but at the Rawa's left side chin strap ratcheting attachment buckle, there's a bit of stiff steel wire that sticks out just a few millimetres on the bottom of the ratchet mechanism, forming a small hook facing I think towards the jumper's chin. There's nothing to protect the end of the wire. I think it is strong spring steel, part of the spring loaded function of the ratchet mechanism. (I don't know the age of the helmet, or if anything is different on older or newer ones.) As the jumper climbed out, that wire at the bottom of the ratchet hooked right into the fabric of the riser cover. The steel wire being quite stiff wasn't about to let go easily if the jumper tried to pull his head away from his shoulder straps, which would be anyone's natural inclination. The incident could also have happened at some other time, in freefall or under canopy. This exact thing happened to me not long after I started jumping my Rawa last year, only my incident happened upon opening, which was quite disconcerting at the time. After a few failed attempts trying to pull my head away, I managed the presence of mind to grab the harness at the shoulder, lift it up and get the slack required to free my head. In my case, I'm guessing that the spring snagged the edge of the covering over the 3D foam on my Vector 3. As soon as I was back on the ground, I covered the clips and spring with duct tape. The clips are still perfectly useable this way, but not everything is smoothed over and no snag points. Quote Share this post Link to post Share on other sites
pchapman 280 #13 March 2, 2012 Yes I'm bringing back a 3 year old thread. It's about the snaggable end of a hard metal spring in the chin cup adjustment for Rawa helmets. I just found it interesting to hear that among jumpers at the DZ where I jump, someone else (on vacation in Florida) had their Rawa chin cup snag their rig recently -- and after people got talking, 3 more local jumpers said they had had it happen in the air, and 1 more on the ground. It's not like it has been hurting anyone directly, although it is a distraction on a jump that at worst could have further consequences. Sounds like the metal end should be covered over. (Tape, epoxy, hot glue, ?) Quote Share this post Link to post Share on other sites
hcsvader 1 #14 March 2, 2012 I've had it happen on mine a couple of times as well.Have you seen my pants? it"s a rough life, Livin' the dream >:) Quote Share this post Link to post Share on other sites
andreeb77 0 #15 March 2, 2012 Happened to me a few times. Not a very nice feeling having your chin attached to your riser in a track short before pull time I put on some tape as a not very optimal work around. Quote Share this post Link to post Share on other sites
Abedy 0 #16 March 2, 2012 QuoteSounds like the metal end should be covered over. (Tape, epoxy, hot glue, ?) Been jumping a Rawa camera helmet for several hundreds of jumps (FS video, TD video, FF video), never had an issue with snagging.The sky is not the limit. The ground is. The Society of Skydiving Ducks Quote Share this post Link to post Share on other sites
coticj 0 #17 March 22, 2012 The same thing happended to me two times on exit. It really isn't a great feeling, being snagged like that. But now I have a new problem. The chincup keeps opening on FF jumps. Anyone had the same problems? Or any idea on how to fix it?http://www.prostipad.si Quote Share this post Link to post Share on other sites
BenediktDE 2 #18 March 31, 2012 This problem was posted here before (but can't find it now) I have these metal hooks taped since then.For every complex problem there is an answer that is clear, simple, and wrong. Quote Share this post Link to post Share on other sites
