frost 1 #1 December 1, 2011 http://www.youtube.com/watch?v=c0GcJxwM_pw#t=03m19s I did not like what i saw there.... I hope this is not a sign of bad trim/canopy issues similar to the original Crossfire... Quote Share this post Link to post Share on other sites
Calvin19 0 #2 December 1, 2011 did you even watch the video? air gremlin. Quote Share this post Link to post Share on other sites
ianmdrennan 2 #3 December 1, 2011 That's a little more than an "air gremlin" That's an extremely violent loss of airflow. Scary stuff, glad the pilot is ok - good reaction time and good promo for the skyhook. Ian Performance Designs Factory Team Quote Share this post Link to post Share on other sites
Calvin19 0 #4 December 1, 2011 Quote That's a little more than an "air gremlin" That's an extremely violent loss of airflow. Scary stuff, glad the pilot is ok - good reaction time and good promo for the skyhook. Ian No doubt! I'm no swooper but that wants me to get a skyhook pretty badly. deflations on small wings is really scary. -SPACE- Quote Share this post Link to post Share on other sites
wildcard451 0 #5 December 1, 2011 Quotedid you even watch the video? air gremlin. Someone got it wet, then exposed it to sunlight, and fed it after midnight. Quote Share this post Link to post Share on other sites
AggieDave 6 #6 December 2, 2011 Quote http://www.youtube.com/watch?v=c0GcJxwM_pw#t=03m19s I did not like what i saw there.... I hope this is not a sign of bad trim/canopy issues similar to the original Crossfire... Sweet jebus! That was so sudden and violent that it looked like a line broke. Since the perspective doesn't show it, is there anything that would roll a rotor like that out there or were the conditions right for dust devils? Were any other canopies bouncing? Remember when the JVX came out every few months a new version was released? It always made me wonder about what level of R&D was conducted before something was released. PD has made some flops, but you can't say that they test the snot out of their product before it is let loose in the wild.--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
jtiflyer 0 #7 December 2, 2011 Quote Sweet jebus! That was so sudden and violent that it looked like a line broke. Since the perspective doesn't show it, is there anything that would roll a rotor like that out there or were the conditions right for dust devils? Were any other canopies bouncing? Wind was off the water and the direction put them downwind on distance and quartering cross on speed runs. These were all practice rounds. Temp was about low 80's winds were gusty at times but always from the same direction. FS teams were landing on the palm and wind seemed consistent there, at least when we were landing. Quote Share this post Link to post Share on other sites
pchapman 280 #8 December 2, 2011 From looking at a download of the video of what I guess is a Petra collapse in Dubai: In the turn, it is the leading edge of the wing on the outside of the turn that folds under. In paragliding parlance, it would be a frontal collapse - asymmetric at first but leading to a full frontal. It doesn't take long until the whole wing folds under and is inverted before things go crazier. It isn't a case of hauling down too fast on a front riser, as that would normally be on the inside side of the turn. The turn initiation isn't sudden, and indeed the turn seems to slow shortly before the collapse. One does of course wonder about the trim design on that canopy and what kind of turbulence may have been about. More likely thermals in that area than rollers off obstacles? I dunno. Whatever the cause, the angle of attack at that part of the wing got too low... Attached is a zoomed video capture series, with time stamps added in seconds. Edit: Start of canopy distortion @ 2.6 sec, start of sudden movement of the pilot @ 2.9 s, first sign of cutaway @ 5.4 sec (2.5 s later), full reserve inflation (still with a twist) approx @ 7.4 s (2.0 s later). Quote Share this post Link to post Share on other sites
Martini 0 #9 December 2, 2011 PG wingovers require some outside brake to keep that from happening. Fortunately the result of an asym on a PG isn't quite so violent. Holy crap.Sometimes you eat the bear.............. Quote Share this post Link to post Share on other sites
mchamp 1 #10 December 2, 2011 Quote That's an extremely violent loss of airflow. Scary stuff, glad the pilot is ok - good reaction time and good promo for the skyhook. Ian Good promo for PD canopies as well since he stated: "Needless to say, I will be using my VC 79 for the DIPC an not the petra... Thanks to UPT for the epic gear... Skyhook saved me today for sure".For info regarding lift ticket prices all around the world check out http://www.jumpticketprices.com/dropzones.asp Quote Share this post Link to post Share on other sites
Calvin19 0 #11 December 2, 2011 Quote PG wingovers require some outside brake to keep that from happening. Fortunately the result of an asym on a PG isn't quite so violent. Holy crap. collapses on small stuff get nasty really fast for sure. no way out of that one so low without a chop. in PG it really depends on what wing you are flying, some wings will flip you over and eat you, not just spin up. and it's more than just "outside brake" to do coordinated wingovers. Quote Share this post Link to post Share on other sites
LetsGoOutside 0 #12 December 2, 2011 Seems way too high for a blue devil, but the way it spun up looked like one. Quote Share this post Link to post Share on other sites
jtiflyer 0 #13 December 2, 2011 QuoteSeems way too high for a blue devil, but the way it spun up looked like one. As I stated earlier winds were varying I would say between 5mph on the lulls to maybe 10-12 on the gusts. All the turns were made over light colored sand, and temps were in the 80's. Over 100 other competitors made practice jumps with no problems. Quote Share this post Link to post Share on other sites
Helmut 0 #14 December 2, 2011 Anyone spoke to the pilot to get his point of view. Would be interesting to hear from him. Quote Share this post Link to post Share on other sites
voilsb 1 #15 December 3, 2011 What I'm curious about ... ... ... ... ... Did he make the gates with his Optimum? What did he score? Brian Quote Share this post Link to post Share on other sites
trigger 0 #16 December 3, 2011 I've seen this happen with a stardard Velo so don't kid yourself, canopy collapse for whatever reason happens..CHOP WOOD COLLECT WATER. Quote Share this post Link to post Share on other sites
Skydivesg 7 #17 December 3, 2011 QuoteI've seen this happen with a stardard Velo so don't kid yourself, canopy collapse for whatever reason happens. Just curious. When and where did you see this? How long ago? A production Velo or comp? Did it happen during a competition? What were the conditions? Thermals? Winds? Turbulence? Is it on video? Details please.Be the canopy pilot you want that other guy to be. Quote Share this post Link to post Share on other sites
Sangi 0 #18 December 3, 2011 There's no decent details on this issue, so judging it by being an R&D failure is too soon "Dream as you'll live forever, live as you'll die today." James Dean Quote Share this post Link to post Share on other sites
ianmdrennan 2 #19 December 3, 2011 Quote There's no decent details on this issue, so judging it by being an R&D failure is too soon Agreed. I'd hardly call any issue with a R&D canopy a failure. That's the purpose, to iron out all the kinks or to learn about what does and doesn't work. I think, what is most alarming about the collapse is how sudden and violent it was. It reminded me of the "Foxy" revision (I think it was that one).Performance Designs Factory Team Quote Share this post Link to post Share on other sites
trigger 0 #20 December 3, 2011 One of the Babylon guys(Fred or Kuri but a while ago so can't be sure) 2002/2003 Hot day in August. The collapse happened at altitude above 2000'. Flying normally then it just folded and spun up. Stardard Velo i believe as the comp Velo hadn't been conceived then. Happened at Empuriabrava Spain which does suffer with some funky winds from time to time..CHOP WOOD COLLECT WATER. Quote Share this post Link to post Share on other sites
chuckakers 426 #21 December 3, 2011 QuoteQuote That was so sudden and violent that it looked like a line broke. That was my first thought, but in the vid caps a few posts down it looks more like the nose rolled under and it swallowed itself. One thing's for sure. I'd want to do a sh*tload of research before jumping it again. If that happened a bit lower there would have been a lot of paperwork.Chuck Akers D-10855 Houston, TX Quote Share this post Link to post Share on other sites flytrybe 0 #22 December 5, 2011 http://youtu.be/Q0SKOlfnJ3c Quote Share this post Link to post Share on other sites flytrybe 0 #23 December 5, 2011 Quote Share this post Link to post Share on other sites AggieDave 6 #24 December 5, 2011 QuoteQuoteQuote That was so sudden and violent that it looked like a line broke. That was my first thought, but in the vid caps a few posts down it looks more like the nose rolled under and it swallowed itself. Yeah, I know, I was saying that the canopy collapse was just that violent when the nose of the canopy folded. I've seen Velos do some odd stuff before, but never anything that violent and sudden. Also in each of the times I've seen a Velo do something really odd, there were bad wind conditions or the canopy had serious trim issues from an old lineset.--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites mmm_peanuts 0 #25 December 5, 2011 At 3:50 and 5:59, is that Jay jumping a Petra, or a new PD R&D canopy? Quote Share this post Link to post Share on other sites Prev 1 2 3 Next Page 1 of 3 Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0 Go To Topic Listing
