morris 0
			"...even when your toggle is set long enough so that you can´t ever stall em???"
How long?
How far "out of reach" is the stallpoint?
As always the answer to your question depends on many things (type of canopy, WL, blablabla) but if you want me to keep it as simple as possible I´d have to say "yes, you can!"
Depending on how far "out of reach" your togglestallpoint is and - in the first place - how aggressive your input is, you will very likely be able to stall it. If you are going for the most extrem possible input ("trying to break the brakelines") the stallpoint will very likely being "within reach". If you are giving it at try and it doesn´t stall, ask yourself if you´ve really been shooting for the most aggressive ("I-wanna-break-the line") type of input. Most people don´t dare to give that much of an input (or sometimes aren´t even able to for physical reasons) in a "training-szenario" - something that can be different if they are about impacting the ground...
However - now it gets important - I DON`T RECOMMEND to achieve this kind of stall to anyone. As this might sound opposite to what I´ve written above (somewhere), let me explain:
I have persons experimenting with aggressive inputs, doing this the goal is not to create this kind of result, we´re not going that far. The goal is to get familiar with way more aggressive inputs than what persons are usually used to, to have them applying an input aggressive enough to safe them, if the time comes they need it.
(Hopefully never,"stay out" comes first, see Dave above!)
Once in a while someone is "obeying too much" to what I´m telling him and skipping a step (or three or four, many...) on the way towards more and more aggressive inputs (the last one was a soldier) and those are the once coming down "Holy ____!"
If you go for it, don´t blame me for ANY outcome, including being "scared as hell/to death" (chutes don´t like it at all!!), cut-aways (by the way, Optimums rock!) or worse!
Don´t be scared to experiment with "reasonabel inputs" as it really takes something to "get in trouble", but keep this in mind!
I don´t wanna say anything more detailed as anything I´m able to do here is "written only" and as I mentioned, I´m not even a native speaker.
Of course the internet is better than "by trial and error only" but this - as anything that might be dangerous - is something that belongs under the supervision of a qualified coach with a reasonable reputation.
Problem is:
How does someone know if something can "result in trouble" or worse??
See, always a good idea to see a good canopycoach!
Hope this answered your question well enough...
	How long?
Problem is:
