jumper03 0 #1 November 15, 2006 I'm jumping a Diablo 190 that right now I am loading at 1.05. I have about 150 jumps on it and decided to start playing around with riser approaches. However, my first pulls on the risers up high were suprising. First, I have to do a pull up on the riser to get a response - very heavy pressure - and when it does start to turn, it 'bucks'. Coming off the riser is kind of ugly too - nothing smooth about it. I'm not so sure I want to be doing that near the ground Is that characteristic of the Diablo or because of the loading? Any other Diablo jumpers notice this? JumpScars remind us that the past is real Quote Share this post Link to post Share on other sites
wmw999 2,638 #2 November 15, 2006 There've been some posts in the past about this. I haven't noticed, but then I use my toggles for turning. I'm a big wimp who doesn't really want to swoop or get scared close to the ground Wendy W.There is nothing more dangerous than breaking a basic safety rule and getting away with it. It removes fear of the consequences and builds false confidence. (tbrown) Quote Share this post Link to post Share on other sites
Sabre1Lucke 0 #3 November 15, 2006 If your canopy start to 'bucks', check your steering-lines. It seems to be, according to your explanation, that they are too short. When you are in full flight, pull down both risers and check if the tail of your canopy is beeing pulled down by the steering-lines. If it is, then they are to short. Start from flying in brakes, this makes the riser pressure less heavy. You can find enough information if you use the Search function on this forum. Hope this helps Quote Share this post Link to post Share on other sites
dragon2 2 #4 November 15, 2006 My diablo is awfully LIGHT on the frontrisers, much lighter than both the spectre and the vengeance I flew before. I can EASILY hold 360 and I'm a wimp, didn't get past 270 on the vengeance... My WL is 1.3 or so. Checking your brakelines might indeed be in order! Bucking is a sure sign of braking ciel bleu, Saskia Quote Share this post Link to post Share on other sites
icevideot 0 #5 November 15, 2006 The advice about the steering lines is good. Steering lines often shrink the most because of having the most friction/heat applied by the slider. I have seen several canopies that the tail deflects just by reaching with the toggles to grab the front dive loops."... this ain't a Nerf world." Quote Share this post Link to post Share on other sites
piisfish 140 #6 November 15, 2006 QuoteThe advice about the steering lines is good. Steering lines often shrink the most because of having the most friction/heat applied by the slider. I have seen several canopies that the tail deflects just by reaching with the toggles to grab the front dive loops.wouldn't a senior rigger know that ? scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
Chris-Ottawa 0 #7 November 15, 2006 I have a very similar problem with my Spectre. I'll pay attention to see if the back is getting pulled when I do a front riser turn. I have no intentions of doing this low, but I love doing it up high. The more spins I can do the better. Usually toggles are enough fo me though since I'm still pretty amateur under my 135. Thanks I was going to start my own post, but I wasn't sure what it was realy called. Chris"When once you have tasted flight..." Quote Share this post Link to post Share on other sites
jumper03 0 #8 November 15, 2006 QuoteQuoteThe advice about the steering lines is good. Steering lines often shrink the most because of having the most friction/heat applied by the slider. I have seen several canopies that the tail deflects just by reaching with the toggles to grab the front dive loops.wouldn't a senior rigger know that ? I guess I should add, that the brake lines are fine. Slight slack in full flight - that was the first thing I checked. I was hoping to see if the was characteristic of the diablo.Scars remind us that the past is real Quote Share this post Link to post Share on other sites
Elisha 1 #9 November 15, 2006 QuoteQuoteQuoteThe advice about the steering lines is good. Steering lines often shrink the most because of having the most friction/heat applied by the slider. I have seen several canopies that the tail deflects just by reaching with the toggles to grab the front dive loops.wouldn't a senior rigger know that ? I guess I should add, that the brake lines are fine. Slight slack in full flight - that was the first thing I checked. I was hoping to see if the was characteristic of the diablo. What about line trim? Could they be reasonably out of trim? Quote Share this post Link to post Share on other sites
jumper03 0 #10 November 15, 2006 QuoteQuoteQuoteQuoteThe advice about the steering lines is good. Steering lines often shrink the most because of having the most friction/heat applied by the slider. I have seen several canopies that the tail deflects just by reaching with the toggles to grab the front dive loops.wouldn't a senior rigger know that ? I guess I should add, that the brake lines are fine. Slight slack in full flight - that was the first thing I checked. I was hoping to see if the was characteristic of the diablo. What about line trim? Could they be reasonably out of trim? I check that too - trim is fine. got me buffaloed...Scars remind us that the past is real Quote Share this post Link to post Share on other sites
ntacfreefly 0 #11 November 15, 2006 QuoteSlight slack in full flight - that was the first thing I checked. Hey Steve, I know you'd have checked the above but what about when you are in 'front riser' flight? If you pull them down is all the slack getting eaten up or is there still slack? Blues, IanTo the mind that is still, the whole universe surrenders. ~ Lao-Tzu It's all good, they're my brothers ~ Mariann Kramer Quote Share this post Link to post Share on other sites
jumper03 0 #12 November 15, 2006 QuoteQuoteSlight slack in full flight - that was the first thing I checked. Hey Steve, I know you'd have checked the above but what about when you are in 'front riser' flight? If you pull them down is all the slack getting eaten up or is there still slack? Blues, Ian AH!!! I see what you're saying. That I will have to check. I'm not a swoopy swooper so I didn't think about that. *DOH* I'll see if that is it. If it is though - I like where my brakes are at...damn. I'll have to adjust a lot of flying before I get back on risers then. This shit is complicated.....Scars remind us that the past is real Quote Share this post Link to post Share on other sites
MrBrant 0 #13 November 15, 2006 I had this problem on my Samura once. I believe the problem was my chest strap was too tight, bowing the canopy. (I had forgotten to loosen it on that jump) Try loosening your chest strap after opening, so it's nice and loose, and your canopy can expand. That may not be it, but its an easy thing to check. have fun Quote Share this post Link to post Share on other sites jheadley 0 #14 November 15, 2006 When I double front dive my Sabre 2 150 on landing, I do get "bumpy" dives some times. Brake lines are plenty long and lineset is new. I think the lower angle of attack makes it more susceptible to turbulence that you wouldn't otherwise feel going straight in? Front riser turns are fine though. Quote Share this post Link to post Share on other sites icevideot 0 #15 November 16, 2006 How far do you pull the fronts down? I have seen enthusiastic (and strong) guys pull their dive loops almost to their chest. That distorts the wing's profile to the point that all kind of weird stuff can happen. Too much of a good thing is still too much. Just a thought."... this ain't a Nerf world." Quote Share this post Link to post Share on other sites jumper03 0 #16 November 19, 2006 Quote Hey Steve, I know you'd have checked the above but what about when you are in 'front riser' flight? If you pull them down is all the slack getting eaten up or is there still slack? Blues, Ian ALL the slack is gone on the front riser turn....the brake lines are tiiiiight. So now I need to entertain the question - do I stay with my Diablo 190 which is getting kind of ragged out - lengthen the brake lines and relearn to fly it... -or- Start looking for a Sabre 2 170 which is what I was planning on doing soon anyway. decisions decisions. I need to win the lottery. Scars remind us that the past is real Quote Share this post Link to post Share on other sites marks 0 #17 November 20, 2006 your not going to have to relearn to fly it when you loosen your brake settings. especially if there was slack before when you were not pulling the risers. after you loosen the brakes, everything will just seem smoother. Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
