TCMRigging
Pylon Races
I used 88 ft long crete paper (black) and yes the color does effect fall rate for some reason. The white and black paper were a different texture and the white fell faster.
I used 4 AA batteries for the weight.
To set up the course we flew past each other and then dropped the streamers.
We would then get close together on the course (one behind the other) and start racing. To make the turns you roll your wing up on its side then go into a full flare to make a tight turn. Basically like carving your wing on the ground. It is really wild to be right behind another canopy and try to make a pass. I may get a few people to do this over the weekend and post a video.
Chris
