billvon 3,169 #1 July 11, 2006 Have noticed something interesting on my Nitro. When I fly back, I often find myself holding one brake to make the thing go straight. Didn't think much of it; I then loaded that side with my legs, the problem went away, and I could continue back in with very little "body input" and it would fly straight. Over the past few weeks I've been experimenting to see what's really going on. And I've noticed the following: When I add a very small amount of right toggle, the canopy turns left. This is interesting because it's how aircraft turn - drop the right aileron to turn left. Aircraft have a rudder partly to counteract "adverse yaw" - when you drop the aileron on the right, drag increases on that side, so you need the rudder to counteract the tail's desire to slide to one side. Canopies, of course, depend on that adverse yaw to turn - that's why pulling the right toggle makes you turn right (usually.) So initially, I'd pull just slightly on the right toggle, the canopy would turn left, I'd add a little more toggle, and it would stop. There's a point at which a moderate deflection of the tail produces straight-ahead flight, I assume at the point that roll balances yaw. It makes sense, but I am suprised I haven't seen this before on other canopies. Maybe I haven't been paying enough attention, or the Nitro is unusually sensitive to this. Quote Share this post Link to post Share on other sites
dharma1976 0 #2 July 11, 2006 or maybe your brakes are set wrong causeing your rudders to fly above the canopy more than expected in design... so that when you pull down on the right toggle you are actually returning that brake to the neutral setting and the other side is set in a negative setting causeing the turn. Davehttp://www.skyjunky.com CSpenceFLY - I can't believe the number of people willing to bet their life on someone else doing the right thing. Quote Share this post Link to post Share on other sites
marks 0 #3 July 11, 2006 QuoteSo initially, I'd pull just slightly on the right toggle, the canopy would turn left, I'd add a little more toggle, and it would stop. There's a point at which a moderate deflection of the tail produces straight-ahead flight, I assume at the point that roll balances yaw. It makes sense, but I am suprised I haven't seen this before on other canopies. Maybe I haven't been paying enough attention, or the Nitro is unusually sensitive to this. that is odd, I have never noticed that either. I think I will see beezy this weekend, I will ask him if he has seen this. but im sure he will see this post also. is it obvious it is a turn? or does it seem more like a slip? Quote Share this post Link to post Share on other sites
billvon 3,169 #4 July 11, 2006 >or maybe your brakes are set wrong causeing your rudders to fly >above the canopy more than expected in design... Perhaps, but I doubt it. I have about 6" of slack in the lines and the canopy flies normally other than that. Quote Share this post Link to post Share on other sites
dharma1976 0 #5 July 11, 2006 did you add the six inches from stock? or is it just six in ches of slack before you notice tail deflection? Davehttp://www.skyjunky.com CSpenceFLY - I can't believe the number of people willing to bet their life on someone else doing the right thing. Quote Share this post Link to post Share on other sites
The111 1 #6 July 11, 2006 QuoteIt makes sense, but I am suprised I haven't seen this before on other canopies. Maybe I haven't been paying enough attention, or the Nitro is unusually sensitive to this. Think it has something to do with the little winglets which are unique to the Nitro, AFAIK?www.WingsuitPhotos.com Quote Share this post Link to post Share on other sites
yardhippie 0 #7 July 11, 2006 Ive got around 650 jumps on a Nitro 120 and havent noticed anthing like that. My first line set I did have to extend the brake lines about 6" to get the tail flutter out of it when I did my front riser turns. I'll have to try it on my next jump though. Im interested to see if I can repeat the a similar reaction on a different size wing. What are you loading yours at? But truthfully, I dont use the toggles much for anything other than holding in brakes and flairing. the rest is mostly harness and front risers.Goddam dirty hippies piss me off! ~GFD "What do I get for closing your rig?" ~ me "Anything you want." ~ female skydiver Mohoso Rodriguez #865 Quote Share this post Link to post Share on other sites
Pendragon 1 #8 July 12, 2006 All canopies will do this; it's just that pilots don't generally notice as the effect is often subtle. Don't CReW jumpers use this as a technique though? The reason is simple: trim and brake lines are adjusted such that "toggles up" on a parachute is way faster than maximum glide (which actually requires brake/riser input to achieve). This is to have the right characteristics for a good opening. When you use a small amount of toggle, it converts some of that excess speed and actually generates lift on that side, inducing bank and causing the canopy to turn in the opposite direction. More brake input will degrade wing performance on that side, losing lift - but also slow it down - so the canopy both banks and yaws in the direction of the toggle input. The question as to why it is quite pronounced in your Nitro (as compared to other canopies you've flown) isn't obvious. Might it have something to do with the way it is trimmed?-- BASE #1182 Muff #3573 PFI #52; UK WSI #13 Quote Share this post Link to post Share on other sites
billvon 3,169 #9 July 12, 2006 >did you add the six inches from stock? I replaced the lower brake lines with Dacron a while back. I trimmed them so it took about 6" to get tail deflection. >What are you loading yours at? 1.9 to 1. Quote Share this post Link to post Share on other sites
mgattini 0 #10 July 12, 2006 Had the same thing happen to me Vx 69 at 2.7 and Vx 55 at +3.0. Quote Share this post Link to post Share on other sites
