shadowswoop97
Question on using smoke while swooping water?
Has anyone swooped a pond with smoke on their feet, if so, what happens when smoke gets wet? Does the water put out the smoke, or does the canister stay smoking with a little water contact? with alot of water contact? with water splashes? or fully submerged? Should you jump with two canisters on one foot or one canister on each foot if you would like to use two? What are the best toe drags on water for wearing smoke? Thanks all all the info guys,
What type of smoke are you talking about? Military M-18(hot) smoke canisters will not be affected by getting them wet while swooping. Fully submerging them will create a weird bubbling with a faint smoke plume coming off of the water but they continue to burn. Civillian smoke canisters usually don't work as well and some have cardboard bodies which water can affect. If your worried about the smoke not showing up during the swoop, put it on the foot you don't drag in the water. Either way, the amount of water the canister is going to be subjected to during a swoop shouldn't be an issue, unless you chow.
SKYMONKEY PUBLISHING
