davelepka 4 #1 December 10, 2004 So there is a WL never exceed chart in Brian Germains book, and many folks seem to have a problem accepting the info. It's no coincidence, however, that most of the protesters are those who are currently exceeding Brian's reccomendations. Some of the arguments are, "Bif was at 26 to 1 with 14 jumps, and he did fine" or, "Those numbers are so conservative, it's for the 'average' canopy pilot, and I have a freind with 500 jumps who says I'll be fine". The central theme to the argument is that there are too many factors involved for that chart to really apply to everyone ( although actual factors such as field elevation and really light people lightly-loading small canopies are considered). Let's consider the fact that Brian is the ONLY guy who though about this enough, in enough detail to write a failry lengthy book about it. Consdier his education, as well as the fact the he designs and builds canopies, along with his recognized excellence in running canopy control courses, and this shoud be enough to take his word that his numbers are good. BUT NO, every jackass off his chart has a reason why his numbers don't add up (or apply to them). Here's the thing, his numbers don't have to add up. His backround, experience, and reputaion do add up, and they add up to much more than the sum of the individual parts. Anywho. here's my point: If we compare the number of incidents where a jumper deployed thier main too low to complete a reserve deployment, with the number of incidents where a fully functioning canopy was mis-handled in some way, we'll find that the main canopy incidents, far outweigh the low pull incidents. Why, then, are these same people not protesting the 2000ft min. pack opening altitude? 2k ft is just another number somebody came up with (much like Brian's numbers) but nobody is protesting that figure. The stats support that you can dump at 1k all day long and be just fine. I, for example, have no cutaways, and maybe a dozen or so less than ideal deployments in the last 2000 jumps. I could have been dumping a 1k all along, and been just fine; landing off alot, but fine. 2k is not just another number, it's the result of some careful consideration by some informed people. The low inciedence of jumpers running out of altitude to fix a problem supports that. Likewise, Brian's numbers are valid, and the fact that there are protesters, and many more who aren't even aware of the chart, but are exceeding it's values, combined with the (relative to total number of incidents) high occurences of open canopy incidents supports that. WAKE UP PEOPLE. SMART POEPLE ARE TRYING TO HELP YOU. SHUT UP AND LISTEN. Happy holidays. Edit: Once again, if you agree, indicate so by NOT posting. I don't want to hear it, or have it in my inbox. Those who disagree, have at it. Quote Share this post Link to post Share on other sites
jumperconway 0 #2 December 10, 2004 And the chart is? Quote Share this post Link to post Share on other sites
davelepka 4 #3 December 10, 2004 Good point. Wingloading / Number of Jumps 1.0 / <100 1.1 / 100-199 1.2 / 200-299 1.3 / 300-399 1.4 / 400-499 1.5 / 500-599 1.6 / 600-699 1.7 / 700-799 1.8 / 800-899 1.9 / 900-999 2.0 / 1000+ Substract at least one point for every 2000feet of elevation or density altitude above mean see level If you fly in a location that often experiences conditions of low air pressure due to high temperature and humidity, you should reduce the WNE by at least one point. Substract two points for canopies under 150 square feet Quote Share this post Link to post Share on other sites
jumperconway 0 #4 December 10, 2004 Quote Good point. Wingloading / Number of Jumps 1.0 / <100 1.1 / 100-199 1.2 / 200-299 1.3 / 300-399 1.4 / 400-499 1.5 / 500-599 1.6 / 600-699 1.7 / 700-799 1.8 / 800-899 1.9 / 900-999 2.0 / 1000+ Substract at least one point for every 2000feet of elevation or density altitude above mean see level If you fly in a location that often experiences conditions of low air pressure due to high temperature and humidity, you should reduce the WNE by at least one point. Substract two points for canopies under 150 square feet So according to this 1.8+@300 jumps on a 99 Xfire at sea level less than a year in the sport would be deemed as bad? With extreme heat and humidity? Sorry my bad! Quote Share this post Link to post Share on other sites
chopchop 0 #5 December 10, 2004 I think the chart is good. I have been at or around his never to exceed numbers my whole skydiving career.. over by a point or two at times and below at times.. It is a good guideline and I believe anyone exceeding it dramatically is asking for trouble. There is soo much to learn in canopy control that I don't believe anyone can really max out a canopy's potential much quicker than the guideline suggests so if that is true, what is the point of downsizing faster? chopchop gotta go... Plaything needs a spanking.. Lotsa Pictures Quote Share this post Link to post Share on other sites
jerry81 10 #6 December 10, 2004 OK, for the sake of argument; are, in your opinion, the people who survive exceeding those recommendations more talented than most or just extremely lucky? In general, I think strict enforcement of those rules would result in a)a percentage of people, who'd be ok at a certain (higher) wl getting there a couple hundred jumps later (not a big deal, imo) b)a percentage of people who really shouldn't fly at higher wingloadings hurting themselves a few hundred jumps later. c)a percentage of people who would otherwise get hurt on smaller canopies acquiring the neccessary skills on larger ones and surviving the downsizing. So are the numbers worth enforcing because of c? (I don't really disagree and expressing agreement is, as I understand, not necessary) (To save everyone the trouble, my wl has been 1.6 for the last 200+ jumps, but I won't outright claim I'm an exception to the rule...yet. Make what you want of that.) Quote Share this post Link to post Share on other sites
Hooknswoop 19 #7 December 10, 2004 QuoteSo according to this 1.8+@300 jumps on a 99 Xfire at sea level less than a year in the sport would be deemed as bad? With extreme heat and humidity? It might explain some of your landings. Derek Quote Share this post Link to post Share on other sites
jumperconway 0 #8 December 10, 2004 The landings on the crossfire were never a problem for the next 500 jumps, now that damned 129 omega was a different story Quote Share this post Link to post Share on other sites
DrewEckhardt 0 #9 December 10, 2004 QuoteOK, for the sake of argument; are, in your opinion, the people who survive exceeding those recommendations more talented than most or just extremely lucky? Mostly lucky. Flying at 9/10ths your ability isn't an issue when things are going well. The problem is when things go wrong and either the sensory input is too much or you need another 2/10ths to get yourself out. When you're lucky enough to avoid problems you get away with it. In hindsight this had a lot to do with my injury-free start to the sport. The exceptions I'd make for this are - Dropping the -.2 adjustment for canopies under 150 square feet past some experience level. A light person going from a Manta to a small canopy is likely to have problems with control sensitivity. At the other end of the spectrum, you have the muscle memory from hundreds or thousands of jumps and aren't going to over control. This is also design dependant - a small square is a lot less sensitive than a less agressive non-square design, the less-agressive design less sensitive than a more agressive one. I'd be curious what Brian has to say about this. - Maybe people who have a lot more currency than the typical fun jumper with a few hundred a year. I've had a 1.6-1.7 wing loading at 5000 feet MSL for the last ~800 jumps that haven't been on my birdman or BASE rigs. Although I've landed canopies at higher wing loadings up here and had no problems with stall speed this is pretty much the limit of what I want when things aren't ideal (out landings, idiots swooping in from above on final approach, down-wind landings, etc.) Quote Share this post Link to post Share on other sites
DrewEckhardt 0 #10 December 10, 2004 Quote There is soo much to learn in canopy control that I don't believe anyone can really max out a canopy's potential much quicker than the guideline suggests so if that is true, what is the point of downsizing faster? Assuming you only go down one canopy at a size, the jump numbers to get where the canopy is the limit are probably 3-5X what you're allowed to do according to the chart. The point of down-sizing is that smaller canopies are a lot more fun until you need to be too close to perfect on every landing and it starts to become work. Quote Share this post Link to post Share on other sites
SkymonkeyONE 4 #11 December 10, 2004 That chart was around long before Brian put it in his book, believe me. I would have to think long and hard to remember the original source, but I can promise you I have had it hanging up at Raeford since 1998. At any rate, I totally agree with that chart. Chuck Quote Share this post Link to post Share on other sites
chopchop 0 #12 December 10, 2004 Of course, changing by one canopy every hundred jumps would be silly.. if that's what you were saying. But if you fly something at 1.1:1 for your first couple hundred jumps and then something at 1.3 for a few hundred.. and then progress to a 1.5 or 1.6 for another 400 or so, I think people can learn their canopies, stay right around Brian's recommendations, and be ready to deal with higher wingloadings... if they so desire. And, yes, it is fun to fly faster canopies, but as you well know, most people downsize before they find out how fast their canopy can go. chopchop gotta go... Plaything needs a spanking.. Lotsa Pictures Quote Share this post Link to post Share on other sites
PhreeZone 20 #13 December 10, 2004 Yep, it was in the Big Air Sportz Parachute Manual too I think. I know its been talked about many many times before Brian published his book. I have way more luck then skill. Thats why there are no more loading increases in my future. I'm at 1.5 at 850 jumps.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
SkydiveNFlorida 0 #14 December 10, 2004 QuoteMostly lucky. Flying at 9/10ths your ability isn't an issue when things are going well. The problem is when things go wrong and either the sensory input is too much or you need another 2/10ths to get yourself out. That math doesn't work 9/10 + 2/10 = 11/10. -A Quote Share this post Link to post Share on other sites
hookitt 1 #15 December 10, 2004 QuoteQuoteMostly lucky. Flying at 9/10ths your ability isn't an issue when things are going well. The problem is when things go wrong and either the sensory input is too much or you need another 2/10ths to get yourself out. That math doesn't work 9/10 + 2/10 = 11/10. -A Actually it does work... you need 2/10ths to get yourself out but only have 1/10th remainingMy grammar sometimes resembles that of magnetic refrigerator poetry... Ghetto Quote Share this post Link to post Share on other sites
SkydiveNFlorida 0 #16 December 10, 2004 QuoteQuoteQuoteMostly lucky. Flying at 9/10ths your ability isn't an issue when things are going well. The problem is when things go wrong and either the sensory input is too much or you need another 2/10ths to get yourself out. That math doesn't work 9/10 + 2/10 = 11/10. -A Actually it does work... you need 2/10ths to get yourself out but only have 1/10th remaining Oooh... I didn't get it (I'm a little slow sometimes) -A Quote Share this post Link to post Share on other sites
justdumi 0 #17 December 11, 2004 QuoteWingloading / Number of Jumps 1.0 / <100 1.1 / 100-199 1.2 / 200-299 1.3 / 300-399 1.4 / 400-499 1.5 / 500-599 1.6 / 600-699 1.7 / 700-799 1.8 / 800-899 1.9 / 900-999 2.0 / 1000+ Substract at least one point for every 2000feet of elevation or density altitude above mean see level Quote Ok what i have seen here (so far) is higher jump numbers talking. Now enter the lessor numbers. The reason why lesser numbers havent commented so far is probably due to the fact that the majority have exceeded these recommendations and are just like me sitting here shaking their heads (in dispair not disagreement). In my case my profile: Jumps 200+ Main 150 No of jumps on it 150+ Altitude 5000f AGL (b4 coming to UK) Wing loading 1.5 According to the list when i go back to my home dz i should be on like a 250sf canopy. So what happens now? I speak the truth that had these limits been known when i started they would be more stomachable (if such a word exhists) but i didnt. I would also be lying if i said im keen to be going to upsize tmrw and start using student gear again. I started using the canopy because i "thought" i could handle it. I thought i was ok. As time has gone and i have become wiser (not from my flying or what ive seen) i believed my wing loading to be on the aggressive side. Now i see this and it makes me look insane even though my actual flying hasnt changed and i still feel its ok. So what are you saying then now that we have seen these recommendations? The people above 1000 jumps and doing the most talking so far are generally complying with these recommendations because time has allowed them to stop downsizing and the recommendations to catch up...or maybe you actually went along with the programme. I dont know. The problems i recon in that case are lying in the jumpers with less than 500 jumps. I bet many dont comply...but look at the implications. What now? Scrap the main and upsize (obviously this causes alarm and dispondency and most could be disgruntled to do so) or just be more terrified from now onwards? Quote Share this post Link to post Share on other sites SkydiveNFlorida 0 #18 December 11, 2004 QuoteThe reason why lesser numbers havent commented so far is probably due to the fact that the majority have exceeded these recommendations and are just like me sitting here shaking their heads (in dispair not disagreement). I think the reason those with lower #s that exceed the max are not posting is because they don't feel like starting a flame fest, which is exactly what this becomes when anyone with <1000 jumps has an opinion on w/l (unless of course that opinion agrees with the chart.) -A Quote Share this post Link to post Share on other sites jumperconway 0 #19 December 11, 2004 You didn't read mine Quote Share this post Link to post Share on other sites mattjw916 2 #20 December 11, 2004 Quote...every jackass off his chart um yeah... I'd take the time to respond but I have to go figure out how to fit a 260sq ft canopy in my M5 sized Mirage container because the density altitude of the dropzone I am jumping at tomorrow is kinda high. FWIW, I have Brian's book, I bought it shortly after I received my A license and since then have spent a very large percentage of my jumps working solely on "the most important part" of the skydive. I take canopy control very seriously and if any one of the numerous PST caliber jumpers I know even once said, "dude, you are out of control." Believe me, I would listen! But that is simply not the case... The chart is a great guideline IMO but hauling off and calling people who HAVE spent the time, money and sought out the proper training "jackasses" is way off-base. From one jackass to another... happy holidays...NSCR-2376, SCR-15080 Quote Share this post Link to post Share on other sites PhreeZone 20 #21 December 11, 2004 QuoteI know even once said, "dude, you are out of control." Believe me, I would listen! Have you actually made the effort to go talk to one of them about your canopy choice and skills? Have they been sitting there in the landing area looking at how you fly the complete pattern from opening to landing? Lots of people think things but never make the effort to actually address it with the person. I was thought of an an extremely stupid jumper for my first 300 jumps but I did'nt know that till about jump 275 when someone mentioned it in passing. Once I heard it I sat down with one of the more experienced swoopers and had him watch a landing. Sure enough things I thought I was doing right I was doing wrong but no one ever told me.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites Bartje 0 #22 December 11, 2004 It is not easy to make a chart. Once I heard that you have to keep it as simple as possible. This is not an easy subject to make a chart. -How many jumps you're doing in witch period? -What’s the dz altitude? -What’s the difference in between performance with a 2,0 wing load for somebody whose weight is 50kg and 100kg? -How do you put individual skills into a chart? There have to be chart as a guide but please, I do want them as simple as possible. In France and the Netherlands they have quit strictly chart, so strict that the instructors do not have to worry any more for the funjumpers but where is the fun? Charts are good as a guideline but I do think that as instructor you have to look as well to the person skills. Quote“There is soo much to learn in canopy control that I don't believe anyone can really max out a canopy's potential much quicker than the guideline suggests so if that is true, what is the point of downsizing faster?” Why getting your canopy to the performance limit, are you not bringing yourself to the danger zone? This is maybe cliché but are you getting the max performance out your car? I do not think so, why pushing your canopy to the limits as you can fly an other canopy with the performance you want without bringing it to the (safety)limits. The excuse that I hear most is: what are you going to do when you have a problem under your canopy? Well, it is still the canopy pilot who makes the decision and not the canopy. If you have 100 jumps or 10000jumps, it stay’s the same. The proper attitude is the most important thing and you can not put it in a chart. A FreeFly Gypsy Quote Share this post Link to post Share on other sites davelepka 4 #23 December 11, 2004 Talent doesn't exist. Flying a canopy is just moving your arms up and down. The trick is getting your brain to make the right choices. Why try to get people follow the progression? It's like my example, you COULD pull at 1k for years, and not have a problem. If you did have a problem, an extra 1000 ft would really help out. With the possibiblity of a problem out there, the BSR's tell you to get your PC out at 2k, every time. You COULD jump whatever you think is cool, or will fit in your cool looking rig without a problem. If there is a problem, what then? The answer is to pack the proverbial extra 1000 ft in your container (as in a larger canopy). I can't say that followig the chart will ensure ones safety, but I can say that you're better off following it. With that in mind, why the hell would anyone give away an extra dose of safety? Quote Share this post Link to post Share on other sites davelepka 4 #24 December 11, 2004 If you haven't hurt yourself yet, great. What do think the future holds? You admit you feel your Wl is aggresive, why not do something about it? Upsizing is done all the time. Lots of guys upsize AFTER an injury, so tey can ease back into things. Is this really the time to upsize? How about before the injury, and preventing the injury all together? Quote Share this post Link to post Share on other sites davelepka 4 #25 December 11, 2004 Well, in my defence, you are off the chart, and you do have a reason why it doesn't apply to you. Do you think that the jumpers invlovled in open canopy incendents ever thought it COULD happen to them? Did they believe thay were on a one-way street to the ER? Or did they think that they could handle it, and that everyone who didn't was being overly cautious? ONE MORE TIME, FOR THOSE IN THE BACK, you could dump at 1k for years without a problem. If there was a problem, however, that extra 1000ft you'd have if you followed the BSR's would really be handy. Which is why the BSR's say get it out at 2k, and this applies to EVERYONE. Me, you, and Omar (who apparently has 14,500+ jumps, wow). You could jump whatever you want, however you want for a long time, without a problem. BUT, there is a problem, too many people are getting hurt or killed with open canopies. What is the solution? Regulate only those jumpers who aren't going to get hurt? OK, produce an accurate list, and if you're not on it, have fun. Thats not possible. Lets get everyone to slow it down, take it one step at a time, and all be safe. If you are the exception, too bad. Take one for the team, and follow the guidelines. If EVERYONE follows the guidelines, things will be better. Stop thinking that you're an exception. Go with what smart people are roccomending. And soon enough you will have your 1000 jumps, and nobody will question what you do. Quote Share this post Link to post Share on other sites Prev 1 2 3 4 5 Next Page 1 of 5 Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0 Go To Topic Listing
