jerry81
First rig (freefly safe?)
Hi all. I'm a low-time jumper (nevertheless, a complete addict since jump #10) and intending to buy a used rig sometime soon (in a month or two). I'm currently jumping a student skymaster 270 with a naro container (a bit like having a large suitcase strapped to your back, the whole thing weighs about 25lbs) so I guess I'm in for some major downsizing.
I got my eyes set on two available complete rigs, a cruiselite215 main with a racer container or a teardrop with a pd190 nine-cell. I can't say which canopy would suit me better until i've demoed them both (and I can't do that because I don't have my license papers just yet), although I suspect I might like the smaller one better ;).
The thing I'd really like to know is the freefly-safety of both container systems (both have BOC throw-out pilot chutes). I intend to do mostly freefly/freestyle jumps (belly-falling is just not as fun) and I know some systems are less suitable for that (although I did learn to sit/stand with the aforementioned suitcase which I don't believe was ever intended to go vertical in freefall :ph34r:).
So I'd be very grateful for any advice/experience anyone may have on these two rigs. Also, since this is my first post on these forums, virtual beers all around!!!:)
The older racers and teardrops aren't really that FF friendly. Things to look for - is there any exposed bridle? Do the riser covers have tuck tabs (or at least SOLID velcro)? Are the flaps very secure? The only teardrop that is truely FF friendly is the superfly (i got one and quite like it).
It's like something out of that twilighty show about that zone
Just be careful when you jump the canopies to demo them. It is a HUGE change going from your 270 to a PD190.
I will also express concerns about freefly friendliness. Older gear is almost always not very FF friendly. Have a rigger look any candidate rigs over and perhaps suggest modifications to make them more friendly.
-- Jeff
My Skydiving History
OK, so the things to watch out for are bridle exposure, secure riser covers, tight flaps...anything else? How important is a butt strap and what material should be used for it?
As for the canopy choices; currently, these are the only two available. If I find a ZP main in my price/size range I'll definitely try it out, too. Just how much does the material affect the flight characteristics -are zp canopies more responsive, do they glide better, offer longer swoops? (Not that I'm planning on trying to swoop with my future parachute immediately, but I'd like to get some surf out of it once I know how it handles)
my guess is that judging from the canopies in them, those are older containers, and therefore don't offer some of the protective features of todays containers. The "F-111" material degrades fairly quickly from a porosity standpoint, and some point, they pretty much won't flare well, and you'll start pounding in. My first rig was old gutter gear, but I didn't do any on-purpose free-flight with it;).
You also need the spandex pocket to be tight.
F111 canopies wear out quicker than ZP and then they start to dump you the last few feet (so you may need strong knees). ZP canopies tend to glide better than F111 and the material will last much longer so you normally only need to replace the lines every several hundred jumps.
Damn! Knees are the weakest point of my otherwise quite strong legs- I actually needed surgery after a minor windsurfing accident and my landing #5 (flare too high, drop 5 feet, make a crater, you know how it goes ;)) had me limping for a week (didn't stop me from jumping, though. very foolish, I know). I guess I'll have to start searching for an affordable zp main.
I think if you're doing a lot of sit etc it's a good idea to have the leg straps tied together with on of these. Mine are just held together with a pull up B|
Don't think you want the cruiselite, otherwise known as a cruisefright.:o For the time, it flew fast but didn't flare anybetter than anyother 7 cell F-111 type. They were popular with some folks but are certainly not something I'd recommend, even if you were buying a F-111. Nothing wrong with the PD 190 for a first canopy. Especially if the price is right, it isn't worn out, and you realize you won't be surfing. Probably do need to find a newer rig for freefly.
Terry
I'm old for my age.
Terry Urban
D-8631
FAA DPRE
I've put a number of jumps on the PD190 at my DZ. It's the only student canopy they have that hasn't got a lot of jumps on it, and as such is a pleasure to fly and land. I'd say that if it has relatively few jumps and is a screaming bargain, then it would be a decent first canopy. You will outgrow it before you wear it out. However, don't expect to sell it for much later on. What is your exit weight?
Well, the rig IS a screaming bargain- in fact it's so cheap I'd be quite suspicious if I didn't know the guy selling it- he wouldn't try to sell me (or anyone, for that matter) a worn-out canopy. However, I don't know the exact number of jumps this canopy has (the cruiselite I mentioned has 150)- will have to ask him.
Oh, and my exit weight? With my current gear I'd say about 190lbs- that's 160lbs of me, 5lbs of clothes and the rig amounts to the rest.
