spidermonky
Line over-cutaway?
I agree with the above .. chop. Unless you're super experienced and have had a number of lineovers or something to that degree, chop and don't waste valuable time.
What's the cost to fix a cut line anyways? Would it be about the same to get a reserve repack anyways???
Trailer 11/12 was the best. Thanks for the memories ... you guys rocked!
I have experience under a highly loaded, zippy canopy, spinning mal... trust me when I say you would not have time, nor vision, nor strength to locate the offending line, get the knife and give it a cut. of course, then, you'd be dealing with a fairly unstable canopy (depending on design I suppose), that would require chopping anyway. basically, my MO is -- open canopy, is it ok?, if not chop it, there is no need to waste time. I figure my altitude loss was about 600 feet bewteen having an open spinning canopy till a good reserve. it wasn't a long drawn out event. ( I wouldn't mind viewing that one on the jump track software)
Personal decision tree: if my main canopy isn't landable then I chop it. A problem with the reserve? That's another thread. My approach has worked since 1994 and I'm sticking to it.
D. James Nahikian
CHICAGO
And with an avatar like that I would definately concur!!! :o
____________________________________________________________
I'm RICK JAMES! Fo shizzle.
jumptrack wouldn't show much. i had a cutaway two weeks ago. i opened at 2500, had stuck brake
line and was under reserve around 1500. protrack didn't know anything about the chop.
see attachment.
stan.
it's not about defying gravity; it's how hard you can abuse it. speed skydiving it is ...
Speed Skydiving Forum
