Stumpy 284
(Canopies were a stilletto and an original sabre)
I don't believe that the rest of the line stows make much difference apart from keeping things tidy. Like others have said, focus on the slider and the locking stows.
QuoteI don't believe that the rest of the line stows make much difference apart from keeping things tidy.
They should be tidy.
There could be tension knots e.g. if they are not tidy.
jheadley 0
billbooth 10
Ditto! Always stow all but the last 12-18" of your lines.QuoteI admit I've done that too a few times and had great openings from it, but I definitely would never do it again. With all that loose line, it'd be easy for it to wrap around a flap and cause an entanglement. At least with freebags the pouch contains it.
sundevil777 102
QuoteThis isn't exactly what you're looking for but it's still a good picture and it makes you think.
That is exactly why I think locking stow bands should NOT be easy to break.
riggerrob 643
Can we agree on MIL SPEC rubber bands that are rated for 40 pounds?
riggerrob 643
CSPA even published Technical Bulletins discouraging free-stowing.
Hint: Para-Flite gave away hundreds of main deployment bags during the 1980s.
But skydivers are a stubborn lot, so somebody re-learned the lesson last year ... knotting suspension lines around a side flap.
Ho hum!
Same malfunction ... different year.
KellyF 16
QuoteI am still looking for video of a canopy out of the d-bag before line stretch. I would constantly hear that 'line dump' "caused my hard opening", but I have never seen video of a modern canopy out of the bag before line stretch or what I would call 'bag strip'. I believe that bag strip would cause a catostrophically hard opening with canopy damage and/or injury to the jumper.
I've seen video of a tandem canopy that was packed with broken locking stows that were "half-hitched" (basically tied around the lines) to allow them to be used. On deployment, they ALL came undone, and the canopy came out of the bag maybe 3 feet out of the container. All of the rest of the lines remained stowed on the bag and came unstowed in the normal manner. The opening was perfectly fine!
Standard "line dump" typically won't cause a catastrophically hard opening. It may cause a bit higher snatch force, but for things to get really nasty, the canopy has to get out of the bag, and for this to happen, the locking stows will generally need to break. During the initial moment of the pilot chute lifting the bag out of the container (like the pic posted earlier), the canopy is trying to fall out of the bag. This puts more pressure on the locking stows and holds the line bites tighter. If the locking rubber bands remain intact, the only way those line stows are going to com undone is by getting pulled out by the remaining lines between them and the risers. The only way thats going to happen is for that amount on line to get pulled taught. You may hear some people say something along the lines of "the weight of the dumped lines will pull the locking stows out", well, that can only hold water if those lines are straight, meaning the bag is at the end of the lines
Wow, I hope that helps some people- I need to go build rigs
sundevil777 102
QuoteThat is exactly why I think locking stow bands should NOT be easy to break.
Is that the specification? Sounds great in theory. Do you think many stows that are actually installed on rigs would withstand that?
It seems that most people really need to make their locking stows stretch when closing the bag. This often results in the bands tearing, but not breaking. I've found that sometimes I can't even install a band without tearing it. There is no way a pre-torn band can withstand 40 pounds. Such rigs with tight d-bags usually break their locking stows quite often, which means they might be breaking before line stretch (very bad). I think most people do not replace their locking stows because of such tears.
You have almost got my message. He has stated that line stows are not so important. I think they are. They seem to be quite foul proof for us , lousy packers...
