twnsnd 1
-We are the Swoophaters. We have travelled back in time to hate on your swoops.-
PhreeZone 20
I threw 3 straight toggle hooks Sunday since the pattern was not letting me do one any higher then about 300 feet so a nice 180 toggle from 200 feet or so was a nice compromise.
And tomorrow is a mystery
Parachutemanuals.com
QuoteHarness sensitivity does increase with wing loading, but using nothing but the harness for your turn seems stupid. It seems like you could get a better result with a more direct input (front riser),
Depends on the design, and trim of the canopy.
I'm playing with a newer design right now that seems to react beter with a hard harness turn, than a hard riser turn. Could be the loading, or could be the design.
Did you bring enough for the rest of the class?
Nice skill to know but becoming dependent on snapping a 270 or 180 in front of on coming traffic doesn't show skill to me...
Looks more like someone doesn't know how to hang out up top in half brakes until the pattern has loosened up...
Knowing your canopy is a required skill in this sport, I am just asking to see a general opinion of the population what they use on their final...
I have had great results with front riser input, I recently had someone tell me that harness turns would be better both for the over all swoop and that the canopy would perform better due to the canopy does not distort from the input given from the shifting of the harness...
I wanted to see if others out there in our community had the same impression or if they even cared how the canopy changed as long as it performed...
"The edge ... there is no honest way to explain it because the only people who know where it is are those that have gone over"
PhreeZone 20
Hehe.. it was more like that I had the option of flying the normal pattern and landing downwind of some buildings known to throw massive rotors or do a clean 180 s toggle carve and be clear. With 10 people on the load and 7 of them on the ground already.. its not traffic thats was an issue. It was a choice to fly the pattern that was the safest for me to land. Plus with neoprene gloves on it makes it really hard to get the hands in the risers and release at the right time with out getting pinched
An effective pilot can use all the inputs to thair max. For the longest time toggle whippers were getting nice long swoops, it came from knowing their canopies.
Most effective form of feed back to how much it effects the canopy other then getting out and flying it a lot is to get a belly cam and look at the canopy as you throw different inputs at altitude and as you land.
Nice idea, I have checked out what the canopy does when you do different types of input, but off course there is no way to do that while on approach for the landing...
Nice rebuttal, I have seen numerous pilots beat down the group only to show off how well they can "chow"...
Luckily we only have water, tree, roads, and mountains for hazards...
And the occasional newbie who seems to like doing S turns on the final base leg...
It seems now that people are changing up canopies for performance before they completely know the canopy they have.
I have seen this from the strong influence and eye brow raising of canopy pilots today. People figure they simply need to get a better canopy instead of learning all they can from their 190 or 170. Instead they figure on learning on a 120 cross brace.
I figure you need better weather there, that way you won't have to wear neoprene gloves thus allowing you to initiate your safer landing procedure...
Or just do your toggle regardless...
Just because toggle hookers had good swoops, it doesnt mean it was efficient/safe.
Johnny
--"This ain't no book club, we're all gonna die!"
Mike Rome
PhreeZone 20
People treat toggles with either too much fear, or not enough respect anymore it seems. You've got your people that will still toggle whip landings and then you've got your people that are terrorfied of using toggle inputs down low. Somewhere between those extremes is where you can really expand canopy knowledge and increase your options.
Toggles can be used for more then just flat turns under 150 feet and landing too
Using Rear risers to do HP landing turns is worse then toggles. Throwing large inputs on the rear risers can cause the canopy to stall easy down low.
Johnny
Mike Rome
jimoke 0
QuoteProperly done toggle carves provide the same options as riser carves.
Toggles can be used for more then just flat turns under 150 feet and landing tooGround carves are nothing more then a toggle turn while about 2 feet off the ground and planned out.
very nicely put.
I see lots of newer swoopers bad mouthing "toggle monkies"
If you are making a toggle turn on your final approach and you are swinging out from under your parachute......DO NOT apply so much input, you will eventually bounce off the ground. of course it is not a safe manuver. neither is holding your front riser till your in the corner.
using your toggles to land is not taboo. done properly you can still make a safe carving swoop.
land soft,
oke
murps2000 87
QuoteBut my experiences with my swoops all come from a Xfire 2 loaded 1.6:1, is it possible that higher wing loading increases the harness turn response?
Yes, definitely. But higher airspeed under what you have will increase it as well. Sometime when you're up high, try a hard 270 front riser hook, and as you're coming out of the dive and you're really zipping along, lean one way or the other in the harness. I don't know if you've tried something like this before, but an experienced swooper I know suggested it to me once, and it really opened my eyes to what a harness turn could do.
QuoteI see lots of newer swoopers bad mouthing "toggle monkies"
I've used the term toggle monkey to describe someone who spirals in the pattern, makes S turns and basically flies their canopy by whipping it around inconsiderately.
That is the only context I've heard it used in as well.
Additionally while I don't believe there's anything majorly wrong with doing a toggle turn for a performance landing, techniques have improved and shown that front riser turns are generally a better idea for HP landings. So I believe that regular use of them (toggle HP landings) should be reevaluated.
Blue skies
Ian
When I do use this I like to incorporate some nice carving with toggle input, but I am still new to this as well...
Harness sensitivity does increase with wing loading, but using nothing but the harness for your turn seems stupid. It seems like you could get a better result with a more direct input (front riser), and be able to get that result faster, taking up less time and space in the pattern. While this might not be a consideration during a swoop comp., on the everyday landing, traffic considerations play a huge role in your swooping.
A toggle is just another control input. Just like a Velocity is just another canopy. Yes it requires more skill to use properly, and the risks involved may be higher than other options, but it's just another way of doing things.
