Staso 0 #1 July 16, 2002 hi! i have a friend who flies original crossfire-119 loaded approximately at 1.25. she complains that at that wing load the canopy doesn't want to make front riser turn even if she hangs on it with all her weight. it does turn but so slowly that she doesn't even bother doing any riser turns. she does toggle hook turns instead which really worries me. she tried crossfire-87 and didn't have any problem with riser turns on that canopy, but she still flies her 119. can anybody flying crossfire at ~1.25 wing load comment on that ? thanks, stan. -- it's not about defying gravity; it's how hard you can abuse it. speed skydiving it is ... Speed Skydiving Forum Quote Share this post Link to post Share on other sites
PhreeZone 20 #2 July 16, 2002 Hey Stan... is this a post fix Crossfire or one that was not recalled? If its a post fix the theme I kept hearing at the DZ was the pressure went WAY up from before and they were having trouble finding the sweet spot and holding it there again.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
Staso 0 #3 July 16, 2002 QuoteHey Stan... is this a post fix Crossfire or one that was not recalled? If its a post fix the theme I kept hearing at the DZ was the pressure went WAY up from before and they were having trouble finding the sweet spot and holding it there again. i think it wasn't recalled. i'm not quite sure though. thanks for info. stan. -- it's not about defying gravity; it's how hard you can abuse it. speed skydiving it is ... Speed Skydiving Forum Quote Share this post Link to post Share on other sites
AggieDave 6 #4 July 16, 2002 Learning my front riser approaches with coaching help and was trying to do double fronts to find out that the brake lines were too short. According to the rigger/canopy coach the brake lines on the stilletto were too short, the pressure was very high. I could do left and right dives, no more then just over 180, though. Trying to do a double front, I would do a pull-up on the dive loops. Note, I am a fairly big, very strong guy and I was doing pull-ups on the front risers with the canopy doing damn near nothing. Now that's high pressure! I'm no expert by any stretch of the imagination, but you may want to check that, you never know.--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
Hooknswoop 19 #5 July 16, 2002 Have her try a front riser turn )at altitude and in clear airspace) w/o the toggle in her hands. If the front risers are easier to pull down, then her steering lines are too short on the 119. The 87 may have have had the steering lines set up for front riser turns. Hook Quote Share this post Link to post Share on other sites
Staso 0 #6 July 16, 2002 QuoteHave her try a front riser turn )at altitude and in clear airspace) w/o the toggle in her hands. If the front risers are easier to pull down, then her steering lines are too short on the 119. The 87 may have have had the steering lines set up for front riser turns. Hook it doesn't hard for her to pull front riser, she can pull it, but he canopy response seems to be to slugish. stan. -- it's not about defying gravity; it's how hard you can abuse it. speed skydiving it is ... Speed Skydiving Forum Quote Share this post Link to post Share on other sites
Jimbo 0 #7 July 16, 2002 Sluggish compared to what? It's certainly going to be sluggish compared to the 87, maybe someone with a bit more experience should jump the canopy and evaluate it for her. - Jim"Like" - The modern day comma Good bye, my friends. You are missed. Quote Share this post Link to post Share on other sites
