PhreeZone
Cleaning White canopies
Does anyone have any ideas on the best way to clean a white canopy? I've recently acquired a mostly white canopy that easly passes all porsity test, but its looking really grimey and I'd love to have it bright white like the inside and bottom of the canopy is.
Yesterday is history
And tomorrow is a mystery
Parachutemanuals.com
leave it as it is or just pass a dry cloth to remove the excess of dirt. Remember that the canopy has a silicone (i think its silicone) coating to reduce the porosity, but if you use any kind of liquid to clean it you can easily remove some of the coating.
HISPA 21
www.panamafreefall.com
To keep the problem from getting worse, it might be good to get one of those cheap blue foldable floor excersize mats at the sporting goods store... just be sure to pick a side that you never expose to the floor and always stays clean. Plus: makes a good sleeping mat when you crash at the DZ and there aren't any bunks left. :)
I've seen packing mats for rigs as well to keep the container from scuffing when you drag it across the floor.
____________________________________________________________
I'm RICK JAMES! Fo shizzle.
What brand of canopy is it? I know Performance Designs, washes canopies. You can call them and see how much they charge. But I would reccomend them doing it. Attatchment tape if not dried evenly will shrink at different levels causing your canopy to go out of trim. After a was PD inspect's the canopies before sending them back. They might even wash competators canopies also but I dont know.
Ray
Ray
Small and fast what every girl dreams of!
Its a Jedei. I took a damp cloth and whiped the top skin down and that seemed to help get rid of some of it, I had to change the water 4 times in the bowl I was wetting the cloth with.
Its liveable now, before you could see the grainage of the fabric thanks to the dirt sitting on top.
