mcrawford 0 #1 October 17, 2002 Ok guys, what is the best method for removing a grommet? Quote Share this post Link to post Share on other sites
bmcd308 0 #2 October 17, 2002 Pay someone who knows how to do it for you. ---------------------------------- www.jumpelvis.com Quote Share this post Link to post Share on other sites
Craig 0 #3 October 17, 2002 Might not be the Best way but I imagine you could pry the two halves apart on the flat side of the grommet. I am not talking prying the two halves apart from the sides, but on the backside. It would likely require a small flat screwdriver working a little at a time. Actually I just took this pic, see below... Quote Share this post Link to post Share on other sites
mcrawford 0 #4 October 17, 2002 Thanks Dude! what great advice... However that wont really help someone who wants to learn how... Quote Share this post Link to post Share on other sites
mcrawford 0 #5 October 17, 2002 Thanks, that is how I have been doing it. It just takes some time. I've heard that you can also take a dremel with a small cutting wheel and score the flat side then bent it out and remove. I haven't tried that but it sounds like it would work as long as you don't slip. Thanks again Quote Share this post Link to post Share on other sites
PhreeZone 20 #6 October 17, 2002 Look in Poitners Manual Vol 1 for a nice break down of how to do this.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
riggermick 7 #7 October 17, 2002 Go to bomber manufacturings' home page and look up SB1005 on grommet removal. I wrote this procedure for removing stainless steel size zero grommets on the Reflex. It will work on any rig and any size grommet. Properly done it will cause no damage. Hope this helps. Mick Cottle. Quote Share this post Link to post Share on other sites
skymedic 0 #8 October 17, 2002 Quotewww.tridenthc.com Marc otherwise known as Mr.Fallinwoman.... Quote Share this post Link to post Share on other sites
Spy38W 0 #9 October 17, 2002 http://www.tridenthc.com/sb1005.htm -- Hook high, flare on time Quote Share this post Link to post Share on other sites
riggermick 7 #10 October 18, 2002 Thank you guys. Can anyone tell me how to paste a hyperlink? i'd sure appreciate the solution. E mail me @ riggermick@eartklink.net. Thanks. Mick. Quote Share this post Link to post Share on other sites
PhreeZone 20 #11 October 18, 2002 Mick, just under the text box you type in there is a button labeled url. Click this before you type the address that you want to link to. The box will turn to /url. Click this box to end the hyperlink.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
SkymonkeyONE 4 #12 October 18, 2002 I use diagonal side cutters and a pair of pliers. Quote Share this post Link to post Share on other sites
riggerrob 643 #13 October 20, 2002 I preferr skymonkey's technique with a set of diagonal sidecutters and a skilled wrist. Start cutting on the washer side. As soon as you have cut through the cylinder, shift to using the sidecutter blade to start levering up the edge of the washer. If you keep one blade under the outer edge and the other in the center, you can use the pliers movement to raise the edge of the washer. Hint, when you do first cut on stainless steel grommets, lean one handle on the table and put all of your weight on the other handle. Removing grommets is definitely an art form that takes hundreds of tries to master. Quote Share this post Link to post Share on other sites
