Plucky
Removing embroidery on harness
Hi all
I've recently bought a second-hand vortex II, but it was owned by an ex-competitor and has a flag embroidered on the shoulder (on the material that covers the shoulder D-ring and reserve riser attachment). I don't mind it too much, but would prefer to get rid of it ... any suggestions? Anything I should be careful of?
Thanks a lot
Why not just attack the mudflap with a stich-ripper?
It's not like the mudflap is of any structural significance. It should be legal too, cause I doubt very much that the embroydery is part of the TSO, nor do I think removing it would be considered a modification to the rig...
thoughts?
_Am
__
Its still going to have the fade mark on the material from where the material under the stitching was never exposed to the sun. If you are going to take the time to rip out a few hundred stitches... might as well do it right.
Yesterday is history
And tomorrow is a mystery
Parachutemanuals.com
Easy guide to removing embroidery if you are reasonably careful.
Use a small diameter hand sewing needle (1mm or less) slide it under the stitches but over the material, use a razor blade and shave the threads over the needle using the needle as a guard for the material, repeat as needed, take your time...
take care,
space
