freeflyswc 0 #1 September 11, 2002 Does it void the TSO if you put a larger reserve in a container that was built for a smaller one? Quote Share this post Link to post Share on other sites
skybytch 273 #2 September 11, 2002 I don't know about voiding the TSO, but I do know it would likely piss off your rigger... Quote Share this post Link to post Share on other sites
Hooknswoop 19 #3 September 11, 2002 No, it is the responsibility of the assembling rigger to determine compatibility of components. From Poynter’s manual: “The assembly or mating of approved parachute components from different manufacturers may be made by a certificated and appropriately rated parachute rigger or parachute loft without further authorization by the manufacturer or the FAA. Each component of the resulting assembly must function properly and may not interfere with the operation of the other components.” “The rigger is also still charged by FAR part 65.129 not to pack a certificated parachute that is not safe for emergency use.” Hook Quote Share this post Link to post Share on other sites
skygod7777 0 #4 September 11, 2002 now vern, why don't you ask someone at the dz???? like jonny, dad steve, rogger, greg, YOUR DAD, or brue??? and the way i look at it, no it wouldn't because if you get a javelin NJ, you can put a pd 113, raven 120, or a tempo 120, or a pdr 126(tight), and they are all different sizes(ecept for raven and tempo) right. just like for a voodoo, you dad has a V0, and he has a dash-m 109, but it was built for a 120, now he has never said that the tso is voided on his rig right. you just have to think vern, think!!! later blue sky's and long swoops kelly "hook low, flare late.........dirt, tumble, dirt......ouch" Quote Share this post Link to post Share on other sites
drenaline 0 #5 September 12, 2002 QuoteI do know it would likely piss off your rigger... I second that motion. HISPA 21 www.panamafreefall.com Quote Share this post Link to post Share on other sites
riggerrob 644 #6 September 12, 2002 I third that motion! Quote Share this post Link to post Share on other sites
