freebird
cypress
I just picked up my complete rig. As soon as I got home I turned on the cypress ( to make sure it worked) I know you turn it off the same way you turn it on. But every time I try to turn it off the light will not come on....or it comes on...... I start with the four presses and still......I can not get it off....I had no trouble getting it on it is still on 0.
" ah geez" "The two of you's dummy up" !
Archie Bunker
Leave it, after a few hours (14 I think) it will turn off on its own. You *can* actually turn it off, but it is easier on the batteries if you just leave it. No worries, that's what it is supposed to do. :)Aerials
So up high
When you free your lives (the) eternal prize
Tap only once to start the process. Here is where it gets tricky: As soon as you see the LED flash, tap the button quickly (jab it with the tip of your finger). You will need to do that part three times.
They can be hard to turn off until you get the rythm down but then again, you don't want it to be easy to turn off, do you?
As Dave stated, it is easier on the battery to just let it turn itself off after 14 hours. That's not 14-hours of inactivity, it's 14 hours. If you turn on your CYPRES at 8:00pm to do a jump, it will turn itself off at 10:00AM the next day, even if you are in freefall.
Kris
Yeah, that's what happens. However, (and this comes from personal experience) if you leave it on, then drive home from the DZ with it on, it will wear out the battery -much- faster than if you turn it off before leaving.
Seems that if the Cypres senses a 50 foot elevation change, it switches from 'stand-by' to 'full activation' and the battery is drained at a higher rate.
Personal expereince gained from when my Cypres battery went 'dead' (noticed by the number cycling down to '8998') within the first year and way before the 500 jumps. My drive home is 45 minutes and an elevation change from the DZ of 1,500 feet.
Just FYI,
ltdiver
____________________________________________
LightDiverCam
Sort of. It's easier on the batteries to leave it on, rather then turn it off and turn it back on if you're going to jump it any time soon. It's kind of like starting a diesel truck. It takes more energy to start it then it does to leave it running. If you're going to use the rig in the current day, leave it on.
It is not easier on the batteries to leave it on if you won't be using it. If you're done for the day, turn it off.
This is especially true if you'll be putting it in your car and driving home on roads that change elevation. The elevation changes will arm it, causing it to burn even more power.
_Am
ICQ: 5578907
MSN Messenger: andrewdmetcalfe at hotmail dot com
AIM: andrewdmetcalfe
Yahoo IM: ametcalf_1999
Yeah...I thought you had to actually program the cypress for a different elevation. In the instructions it tells you how to set it so that the place you're landing is a different elevation than where you take off from. I don't think just turning it off and back on at the landing area will take care of that.
cielos azules y cerveza fría
-Kevin
It's actually quite handy if you know how to shut down Cypres,
example: you go on a jumping holliday and decide to makeone more jump a few hours before you take a plane back home.
You'll never pass customs with it switched on, and who knows what it 'll do once in the luggage department...
All is well that climbs well
:P Tom
Sorry but you are wrong
Read the manual and you will know why.
Ok...direct quote from the manual
When the airfield and dropzone are in different locations and at different elevations,
CYPRES must be switched on at the departure airfield and adjusted to the elevation of
the dropzone (see pages 21 and 22 for full instructions). This is extremely important
when making demonstration/display jumps. On return to the airfield from the dropzone it
must be re-set before jumping again.
Important: It is necessary to do an altitude adjustment before every individual
jump, whenever the airfield and the dropzone where you intend to land
are at different elevations.
-Kevin
hey girl, I think it's normal for it to be hard to turn off. I turned mine off before I left the DZ sunday night and it took quite a few pushes for the little light to come on so I could turn it off. Normally I would have let it turn itself off, but I was going to be driving in the mountians an the last thing I needed was my cypress to arm and maybe fire while I was speeding along. Doubt it would happen, but it was one of those better to be safe than sorry, especially since my pro-track did log a jump cause I forgot to turn it off. ;)
Fly it like you stole it!
