nigel99 631 #1 May 2, 2002 A few years back there was some interest in triple risers - to make canapy fly flatter or something? Do they still exist or what happened to them? Quote Share this post Link to post Share on other sites
skreamer 1 #2 May 2, 2002 Hmmm, maybe I should edit that signature to "check which Forum shortcut you just clicked on!" "Look before you jump, don't die until you're dead" Quote Share this post Link to post Share on other sites
SkydiveMonkey 0 #3 May 2, 2002 This is in the G and R forum boobies - the cause of, and solution to, all of lifes problems Quote Share this post Link to post Share on other sites
gus 1 #4 May 2, 2002 D'oh!Right up there with your spotting skills, nice one.Gus"Sex? Once every six seconds. Skydiving? Five times, every six seconds." Quote Share this post Link to post Share on other sites
SkydiveMonkey 0 #5 May 2, 2002 Taken from one of RiggerRob's posts in this forum : Triple risers have extra risers solely for the steering lines. Most of them also have an extra brake locking loop sewn to the middle riser. This extra loop - similar to tandems - helps keep things neat during the deployment sequence. This adds an extra step to the packing process. The extra step in packing is only worth it if you are already extracting 95% of the performance from your canopy. Extracting 95% of the performance requires loosening your chest strap after opening, collapsing your slider, pulling it down to neck level, and using all controls: including front risers, rear risers, toggles and leg straps.Doing all the above allows the canopy to spread from your hips instead of spreading from the slider. This allows the tail to flatten out a bit more, flattening glide, improving roll stability and reducing friction on control lines. boobies - the cause of, and solution to, all of lifes problems Quote Share this post Link to post Share on other sites
