MrHixxx 0 #1 April 30, 2002 I would like to hear some opinions on the following...If a manufacturer will not build a soft loop reserve handle for a rig, can one be built by another manufacturer or master rigger? Does it invalidate the TSO? Do the circumstances change any if the rig owner is a senior or master rigger?thanks, Jon"Sous ma tub, Dr. Suess ma tub" Quote Share this post Link to post Share on other sites
polarbear 1 #2 April 30, 2002 The reserve ripcord (including handle) is part of the TSO'd section of the rig. Putting a different handle on it will count as an alteration; alterations require master riggers. Alterations to TSO'd components (including the ripcord) further require authorization. This authorization could come from the manufacturer(the one who built the rig, not a different one) or the FAA.I'm guessing it won't happen, but maybe it will. In any case, it will require showing that the new handle meets TSO requirements. Quote Share this post Link to post Share on other sites
skydiverek 63 #3 April 30, 2002 What would be an advantage of having soft loop reserve (and cutaway) handle?Bart Quote Share this post Link to post Share on other sites
councilman24 37 #4 April 30, 2002 Regardless of the niceties of the alteration legality, it should be pull tested to 600 lbs if it has a RSL. In my rigging history (20 years) ripcords are one of the TSO components that can be mixed and matched. Years ago several companies other than the manufacturers offered custom, made to order, replacement ripcords. Some of the older orphaned rigs didn't have factory replacements available. I seem to remember Strong used to make ripcords to order, I think ParaGear used to offer them but they may have had someone else make them. Obviously back then we thought that you could get the RC from someone else. But I would expect it to have an approved quality control and testing plan. Action air used to (and may still) offer a ripcord tester, but it relyed on the pin and end ball swage to put pressure on the RC. Terry Quote Share this post Link to post Share on other sites
KellyF 16 #5 April 30, 2002 According to Advisory Circular 105-2c, Part 11 on page 186 of the 2001 Skydiver's Information Manual: "A. The assembly or mating of approved parachute components from different manufacturers may be made by a certificated appropriately rated parachute rigger or parachute loft in accordance with the parachute manufacturer's instructions and without further authorization by the manufacturer or the FAA.B. Assembled parachute components must be compatible. Each component of the resulting assembly must function properly and may not interfere with the operation of other components." Quote Share this post Link to post Share on other sites
polarbear 1 #6 April 30, 2002 I stand corrected. I would guess the soft handle would still need to pass the TSO specs. Quote Share this post Link to post Share on other sites
kwmontreal 0 #7 April 30, 2002 By definition of approved components, the handel would have to be TSO'd. Jump SafeKent Quote Share this post Link to post Share on other sites
riggermick 7 #8 May 1, 2002 If the rig is manufactured under TSO c23d the ripcord will have to c23d markings on it in order to be legal. If the rig was built under c23b then any approved handle built to the same specifications can be substituted. Having said that, an approved manufacturer will still have to make the handle for you as drawings will need to be on file with the local MIDO. Best advice is to check with the manufacturer.Mick Cottle. Quote Share this post Link to post Share on other sites
riggerrob 643 #9 May 1, 2002 riggermick,Glad to see you posting on this forum.How are you doing these days?Rob WarnerPitt Meadows, BC, Canada Quote Share this post Link to post Share on other sites
riggermick 7 #10 May 1, 2002 Hey Rob,I'm doing fine. Did you not get the message I sent you a couple of weeks ago? E mail me your direct e mail adderss. riggermick@earthlink.netMick. Quote Share this post Link to post Share on other sites
MrHixxx 0 #11 May 1, 2002 Poster: skydiverekSubject: Re: reserve soft loops What would be an advantage of having soft loop reserve (and cutaway) handle?Bart I prefer the loop over a pillow for leverage, since I jump highly loaded ellipticals and my hands are a little numb from tendonitis. I just want to be able to hook a thumb and make it happen as opposed to the grab peel and pull thing.On the reserve it is a profile issue over the metal handle.-Jon"Sous ma tub, Dr. Suess ma tub" Quote Share this post Link to post Share on other sites
