skymama
Wide vs. Narrow Leg Pads
I have wide leg pads on my new Vector 3. They are comfortable under the saddle, but when I'm walking around with the rig on, they are a little bulky. Has anyone made the switch from wide to narrow, and what was the difference that you found?
Andrea
I'm high as a kite
I just might
Stop and check you out.
I actually thought about doing the same thing, I remember my reflex that had narrow leg pads being comfortable walking around on the ground and my new wider ones on my mirage when walking kept rubbing me in well all the right spots.
When they were fixing the backpad on my mirage I jumped my reflex a few times and although there was no rubbing on the ground, under canopy they sucked. I ended up deciding to stick with the wider legstraps and thinking thoughts of the skyvan. :D
I jumped a few different rigs as a student- Wider pads suck on the ground but I just leave'em loose- and snug 'em up just before getting on the plane- Wider is better under canopy for sure- I jumped one rig- pulled nice and snug and still had some nice bruises - Partly from being narrow and part from being pretty bagged out as a student rig-
I had some narrow leg straps (on an older container)that were down right painful to jump. I cut some long pieces of rigid foam and stuck these under the stap covers. It's now very comfortable. Make sure this foam is very firm and about a 1/2 inch thick. It may not work on some rigs.
My last tires old rig had narrow leg pads without any foam. Man are they painfull compaired to my new Mirage rig. Stick with the wide pads and live with the minor discomfort of the wider pads while on the ground. Its really a very small percentage of time when you look at it.
Jump Safe
Kent
Wide ass = wide leg pads
Narrow ass = narrow leg pads
If you have a muscular ass and perfectly harness geometry, you don't need any pads.
My theory is that most of your weight presses on the inboard edge of the leg pads, so the answer is to round the inboard edge of the leg pads, like the floating pads that were standard on Talon 2, Telesis 2 and Genera. These rub as you walk to the airplane, but their rounded edges don't pinch.
No point in tightening leg straps until just before you board the plane.
People with really soft thighs need even more padding, so the solution is to use thicker padding, like the 1/2" thick blue foam used for camping mattresses.
