Mabee 0 #1 March 12, 2002 Hi everyone,I'm looking for information on the Pilot Chute Assist (static line) deployment system, and I'm not coming across anything online. Any suggestions where to look?Thanks,Adam Quote Share this post Link to post Share on other sites
PhreeZone 20 #2 March 12, 2002 Look for info on IAD (Instructor Assisted Deployed) or look ofr static line specific info. Both deployment methods involve similar but unique training.Cause I don't wanna come back down from this cloud... ~ Bush Quote Share this post Link to post Share on other sites
billvon 3,120 #3 March 12, 2002 PCA is not much different, training and usage wise, than direct bag. You have to cover PC-in-tow during the FJC, but that's probably something people should do anyway. There are also slightly different what-to-do-if-container-opens-on-step procedures.-bill von Quote Share this post Link to post Share on other sites
riggerrob 643 #4 March 13, 2002 Let's get our terimology straight here.IAD refers to "Instructor Assisted Deployment", where the instructor tosses the student's pilotchute as the student falls away from the airplane."Pilotchute Assist" refers to an older form of static-line. A static-line configured for PCA has a piece of Velcro on the end that mates to another piece of Velcro on the base of the pilotchute. Like all other static-lines, the PCA is clipped to a hardpoint in the airplane. As the student falls away, the static-line first pulls the pin, then pulls the pilotchute into the wind. When the pilotchute grabs air, the Velcro releases. Then the static-line remains attached to the airplane while the jumper continues falling away. Some PCA are configured with soft pilotchutes and some are configured with spring-loaded pilotchutes.I don't like PCA because it gives the student too much time to interfer with main deployment. Quote Share this post Link to post Share on other sites
Mabee 0 #5 March 14, 2002 Thanks, Rob. That's what I had understood.When you say that PCA gives the student too much time to interfere with the deployment, how is this different from IAD? I would expect the two deployment sequences to be quite similar, if not indistinguishable. Quote Share this post Link to post Share on other sites
alan 1 #6 March 14, 2002 My guess is that Rob was comparing PCA to Direct Bag when he said it gives the student too much time to interfere. Also for FJC, you have to cover the PC over malfunction where the PC goes over the nose instead of trailing behind. I think Para-Gear and/or PPM would have some photos/diagrams/descriptions of the S/L PAC.alan Quote Share this post Link to post Share on other sites
billvon 3,120 #7 March 14, 2002 >When you say that PCA gives the student too much time to interfere with the deployment, how is this different from IAD? In PCA, you have to reach the end of the static line before deployment begins, thus giving the student another half second or so to interfere with deployment. On the other hand, the assist velcro/breakline helps ensure the PC ends up in clean air, although that's not too much of an issue with a competent IAD instructor.PCA compared to deployment bag gives the student a lot more ability to interfere with deployment, since most students are strong enough to grab and hang onto the PC (or get it wrapped around themselves.) Since your entire body weight is used to deploy in direct bag, and the SL/bag does not separate until the canopy is out of the bag, you have a somewhat better guarantee of a good canopy.-bill von Quote Share this post Link to post Share on other sites
Kris 0 #8 March 15, 2002 QuoteIn PCA, you have to reach the end of the static line before deployment begins, thus giving the student another half second or so to interfere with deployment. On the other hand, the assist velcro/breakline helps ensure the PC ends up in clean air, although that's not too much of an issue with a competent IAD instructor.I haven't had to try it yet on one of my IAD students but I was also told that if the student leaves the stut extremely unstable that with IAD you can "short-line" them easier. Hold on to the PC until it pulls the pin and then toss it.Any yay's or nay's on this method? I haven't had to use it yet but there were a couple of instances where I almost did. Kris Quote Share this post Link to post Share on other sites
riggerrob 643 #9 March 15, 2002 bill von and Kris are correct.With PCA assist, the static-line, pilotchute, bag and lines are dragged over the student's shoulder, making them easy to grab. Most paniced students have enough muscle to hang onto a pilotchute, sleeve, or d-bag. They do not have enough muscle to hang onto a direct bag.Since the whole PCA set up is longer, it gives the student an extra half-second to backloop off the step and interfer with deployment.A major advantage of IAD is that the piltochute deploys straight behind the student, making it impossible for all but the clumbsiest of students to grab it.Kris, was correct. If you have the world's clumbsiest IAD student on your load, then you hang onto the pilotchute until the d-bag is beyond his reach.None of these three systems is perfect, but I believe that IAD offers the fewest opportunities for human error. Quote Share this post Link to post Share on other sites
billvon 3,120 #10 March 15, 2002 >With PCA assist, the static-line, pilotchute, bag and lines are dragged over the student's shoulder, making them easy to grab.Did you find this to be the case? When we used it, it seemed like the assist velcro would separate shortly after the PC deployed, resulting in the bag deploying behind him rather than over his shoulder. Maybe we had weak velcro.>None of these three systems is perfect, but I believe that IAD offers the fewest opportunities for human error.I think it involves the most opportunities for human error, since there's a lot more to do on the step, and it takes both hands and a little bit of handling skill to not pull the pin prematurely (for example.) With direct bag, once the SL is connected, deployment is nearly guaranteed - if you can just get him to let go, that is.Done correctly, however, I think IAD gives you the cleanest deployment, everything else being equal.-bill von Quote Share this post Link to post Share on other sites
HeatherB 0 #11 March 18, 2002 >Done correctly, however, I think IAD gives you the cleanest deployment, everything else being equal.Agreed! Here's a short story since we're talking about deployments:I had a bit of a mal on my first IAD. (I had done two tandems and was starting our student program). I was in our C-185, getting out at 4 or 4.5 grand, I forget which. I climbed out onto the strut, gave the ready set go, let go....and found myself in freefall with my pilot chute wrapped around my left arm.I unwrapped the puppy and threw it and had a nice normal deployment, but that could have gotten nasty. Turns out my instructor threw the PC a bit, rather then letting it get dragged out of his hand and also I had dearched some off the strut. Nice introduction to the sport huh? I landed and said I was never jumping again. Yeahhhh....right :)Blue Skies,Heatherhttp://www.skydivewings.com Quote Share this post Link to post Share on other sites
Remster 30 #12 March 18, 2002 QuoteTurns out my instructor threw the PC a bit, rather then letting it get dragged out of his hand and also I had dearched some off the strut. havent done a IAD in a few years now, but as I remember, you are supposed to throw it downwards in a line of flight kinda way, not let it be dragged from you...RemsterMuff 914 Quote Share this post Link to post Share on other sites
SkyMissy 0 #13 March 18, 2002 Correct.I'm not the man they think I am at home, no;I'm a rocket man.Sky World Quote Share this post Link to post Share on other sites
HeatherB 0 #14 March 18, 2002 >havent done a IAD in a few years now, but as I remember, you are supposed to throw it downwards in a line of flight kinda way, not let it be dragged from you...Hmm...well, maybe I had heard them wrong. Maybe he didn't throw it in the proper direction? Or maybe he threw it too early? Does it sound like either of those mistakes would lead to that kind of situation? I ought to ask my old instructors about that jump again. I wish there was video of it!The bridle had wrapped around a few times, I had red lines on my arm for a week or so. I also logged 5 seconds of freefall for that jump. I felt I deserved it :)I did my third IAD with him with no problems. We were both nervous that time!Blue skies,Heatherhttp://www.skydivewings.com Quote Share this post Link to post Share on other sites
