spootch 0
..."Quote"... I slip a B-12 snap (fancy steel hook with an expensive name) onto my molar strap ...
Do you have a pic of this? ]
It is pictured in Sandy Reid's 2005 FAA Parachute Rigging Manual.
Custom made for me By Rob
I was onced asked why I didn't use a paddle to pull up with while I was closing a rig. I politely raised BOTH middle fingers an said "thats why"
don't need a molar strap with the deWolf Pack. long bar, knee plate and 1 shot bag is all you need to bag the canopy. pretty easy to keep track of three tools, especially when you'll need them all later.
MB4252 TDS699
killing threads since 2001
RIGGER 0
There is no need for that tool in the rigging / packing work.
Riggers should be able to keep the reserve in order without it & I would say it will NOT keep the reserve as should.
Use only what is really needed - too much "assist tools" might create issues.
Be Smart & Safe!!!
Unstable 9
Quotehere is no need for that tool in the rigging / packing work.
I agree - I have one and have gone from not using it, to using it, then back to not again. The only time I've found it helpful was a slippery Raven-MZ, but after playing with it, I figured it out just fine..
**edited for Spelling only.**
jaffo 0
I'm sure it's not the only time it has happened.
This was about 10 yrs ago.
Ryder
Muff Brother# 2706 Dudeist Skydiver# 121.5
pchapman 280
(There are many ways to pack a Racer so I suppose someone will use a restraining cord. But the top grommet is rather close to the top of the bag, so having a cord through that isn't like having it through the grommet of a 1 pin rig.)
Anyway, for the Racer I find the strap helps keep the canopy controlled. It's harder to leave the molar strap the rig, if one also always uses it to compress the pilot chute before flipping the container.
jdathome 0
I keep a rubber band around my strap to keep it rolled up in my kit. When I use the molar strap during a reserve repack, I put the rubber band around my wrist. When the molar strap comes out, the rubber band is taken off my wrist and back on the rolled up strap. The band on my wrist is a little tight and uncomfortable, on purpose. Very unlikely I would forget to remove the strap using this reminder.
Anyone else have any tips for counting your tools?
riggerrob 644
"Quote... I heard of people, years ago, who used to tie the top of their lines together to keep things neat. The only trouble was that some people would forget about this and create a streamer malfunction. ...
Yes!
A - forgotten - tie strap was mentioned in the first (circa 1969) fatality report in CSPA's AIM files.
Fortunately the modern version involves tying the freebag bridle around the lines - just below the reserve slider.
I defy you to forget the freebag bridle inside a freebag.
Similarly, the key to remembering to remove tools is using the same tool at multiple stages of closing, so that it HAS to be OUTSIDE, late in the closing process.
For example, if you use your molar strap (B-12 Snap etc.) in the last stages of closing a reserve container, it is almost impossible to forget it inside.
Chuck
