amir1967 0 #1 January 21, 2002 What wingload on stiletto 120 will be equal to 1.4 on Stiletto 170 ( no I don't mean 1.4 that's too easy) What wingload will give the same preformance, response, diving and turn speedAM67 Quote Share this post Link to post Share on other sites
PhreeZone 20 #2 January 21, 2002 Well, no matter the same wingloading, no 2 sizes of the smae make of canopy perform the same. Larger ones have longer lines and dive longer and steeper. Smaller ones are way more twitchy, turn faster and don't dive near as long at the same loading due to thier shorter lines. Best guess.... like 1.3~1.35... but thats just a guess.I want to touch the sky, I want to fly so high ~ Sonique Quote Share this post Link to post Share on other sites
fonz 0 #3 January 22, 2002 You're really asking two different questions!QuoteWhat wingload on stiletto 120 will be equal to 1.4 on Stiletto 170Sounds like you're either poor (to put it mildly) at math or just plain lazy.However, here goes:L is for wingload in pounds per square footW is for the suspended weight in poundsA is for the area of the canopy (*) in square feetThe formula is: L=W/AFirst, consider the Stiletto 170.The only unknown variable is the weight. Isolating W from the formula for wingloading yields W=L*A.L = 1.4 psf and A = 170 sqf hence W = 238 lbs.Then, consider the Stiletto 120.For the sake of simplicity, let's assume that the suspended weight remains the same. Then just fill in the formula:W = 238 lbs and A = 120 sqf hence L = 1.98 psf.Or, alternatively, you could sayFor the Stiletto 170: L(170)=W/170For the Stiletto 120: L(120)=W/120Then isolate W from the first formula: W=170*L(170)And substitute that into the second formula:L(120)=170*L(170)/120=1.42*L(170) hence L(120) = 1.98 psf(this way you don't need to explicitly calculate the weight first)Conclusion: you'll be loading the 120 at 1.98:1, which is very agressive and quite a difference compared to your current wingload.QuoteWhat wingload will give the same preformance, response, diving and turn speedThat's a totally different thing. Note Phreezone's reply. I couldn't tell since I don't jump an elliptical. I'm just a stupid novice. All I can do is point out that wingload is only one of many factors influencing the performance of a canopy.(*): I'd rather write "the canopy's area" instead of "the area of the canopy", but I've once been taught that the former is really ugly (i.e. bad style) English when a lifeless object (as opposed to a person) is involved.Alphonshttp://www.liacs.nl/~avwerven/skydive Quote Share this post Link to post Share on other sites
PhreeZone 20 #4 January 22, 2002 I'm backwards here... A larger canopy dives shallower then a smaller canopy. The shorter lines allowyou toswing out furtherand hold it longer.I want to touch the sky, I want to fly so high ~ Sonique Quote Share this post Link to post Share on other sites
amir1967 0 #5 January 22, 2002 I'm not stupid , my English may not be perfect but with math I don't have any problems .just as Freezone understood my and had reply .So don't be a smart ass ( meer nuker) thank's Amir AM67 Quote Share this post Link to post Share on other sites
fonz 0 #6 January 23, 2002 QuoteI'm not stupidI never said that. Got long toes, eh?Alphonshttp://www.liacs.nl/~avwerven/skydive Quote Share this post Link to post Share on other sites
