3fLiEr 0 #1 December 18, 2001 After my friend was speaking with Airtec about when I can expect to recieve my Cypres back with its new cutter - they informed her of the following:-Due to the body position on dumping and line strectch the change in air pressure around you can fool the cypres slightly causing it to fire 1 or 2 hundred feet higher than the stated 750ft......... thus if you low pullers are dumping at 1000ft it is possible that as you snivel through sub-1000 your cypres can fire............. so if your thinking that as long you are under canopy by 750 you will be OK......... think again.........So basically - dont pull low with an AAD............ its dangerous.......... Have fun people.......bsbd"In a world where we are slaves to gravity I am pleased to be a freedom fighter" Quote Share this post Link to post Share on other sites
SkydiveMonkey 0 #2 December 18, 2001 If you're that low you probably should be going for the reserve anyway. I like my women like I like my coffee - hot and with a spoon in Quote Share this post Link to post Share on other sites 3fLiEr 0 #3 December 18, 2001 "If you're that low you probably should be going for the reserve anyway"Yeah easier said than done - check out the muscle memory post - when you are that low - you just dump out - its automatic - easy to say on the ground go for reserve - you wait to you see that groundrush at 800ft......... you just dump.......... no thought about it......... you gotta be very switched on to go for your reserve in that situation - unless you make the plan to go for your reserve before hand .......... but thats just crazzzzzzzzzy........... ;opbsbd"In a world where we are slaves to gravity I am pleased to be a freedom fighter" Quote Share this post Link to post Share on other sites weid14 0 #4 December 18, 2001 yeah, saw a video the other day of a guy who filmed a deployment flipped on his belly, looked at his alti (way, way in the red) and dumped his main, as soon as the main started to inflate there's a nice reserve behind it. He was low enough you could clearly read the sign on the building below him... he landed in that parking lot. Of course then there's Frankie from the Ranch.... Quote Share this post Link to post Share on other sites Aviatrr 0 #5 December 18, 2001 Quote Due to the body position on dumping and line strectch the change in air pressure around you can fool the cypres slightly causing it to fire 1 or 2 hundred feet higher than the stated 750ft......... thus if you low pullers are dumping at 1000ft it is possible that as you snivel through sub-1000 your cypres can fire............. so if your thinking that as long you are under canopy by 750 you will be OK......... think again......... As far as I can recall, the CYPRES manual actually says that it can fire up to 300ft higher than 750.. If you're using a piece of equipment, RTFM first..Mike Quote Share this post Link to post Share on other sites johnny1488 1 #6 December 18, 2001 QuoteOf course then there's Frankie from the Ranch....WOW that was one of the nastiest landings I've ever seen. Slider all the way up when you hit the state troopers front lawn. One lucky jumper.Johnny Quote Share this post Link to post Share on other sites Brokeneagle 0 #7 December 19, 2001 "if you're that low you probably should be going for the reserve anyway"Nothing in life is foolproof- even a Cypres...I agree muscle memory is ingrained in training, but if you're flying a canopy type that consistantly takes 1000 or so ft to open (like a Spectre), and you notice you're at or below 1000 ft, I would think you would get that reserve out without even considering your main; on any type of low-pull situation, for a snivel-prone/slow opening main, reserve is the only option, unless you want to end up in the hospital or obituaries. Just my .02...Brokeneagle.Brokeneagle. I'm really very gentle, no matter what my kung-fu teacher says... Quote Share this post Link to post Share on other sites Geoff 0 #8 December 19, 2001 QuoteI would think you would get that reserve out without even considering your main'should' - definitely.....'would' .... I dunno....In the 'muscle memory' thread I started under safety and training, nobody could cite even a single example of someone using their reserve when suddenly realising they were low.Do you know an example of that ever actually happening?Geoff Quote Share this post Link to post Share on other sites 3fLiEr 0 #9 December 19, 2001 "but if you're flying a canopy type that consistantly takes 1000 or so ft to open (like a Spectre), and you notice you're at or below 1000 ft, I would think you would get that reserve out without even considering your main" I normally pack my canopy to snivel and open in around 600ft.... I dumped my main out at around 750 - 700ft........ I did not for one second think about how I had packed it and whether i would get a snivel ............. you just dont......... luckily that day it opened quite quickly.......... Nice!bsbd"In a world where we are slaves to gravity I am pleased to be a freedom fighter" Quote Share this post Link to post Share on other sites Brokeneagle 0 #10 December 19, 2001 "Do you know of an example of that actually happening?"No Geoff, I do not- I can only hope that the logic/knowlege that my slow-opening canopy is useless in low situations would move my hands to the silver if I was caught low... Brokeneagle. I'm really very gentle, no matter what my kung-fu teacher says... Quote Share this post Link to post Share on other sites in2falling 0 #11 December 25, 2001 What the hell where you doing dumping that low? Quote Share this post Link to post Share on other sites skyhawk 2 #12 December 25, 2001 didn't mean to stray from the thread, skyhawk ill forgive you this time :-)1 i dont think you should be at that height except in an emergancy 2. while i know to pull the reserve if im at 1000 ft sadly i prob wont be thinking ill just be trying to get somthing in the air and my first thought will be my main same thing if a dog jumps in front of u driving you know you are just ment to hit it and hope 4 the best but most people will still lock up there brakes and swerve comparing the 2 i think that it is not muscle memory instead it is instinct your body doesnt have time to think it finds the simplist way of self/other ppl (dog) preservation and does it Click Me Quote Share this post Link to post Share on other sites rgoper 0 #13 December 25, 2001 "Yeah easier said than done - check out the muscle memory post - when you are that low - you just dump out - its automatic - easy to say on the ground go for reserve - you wait to you see that "GROUNDRUSH" at 800ft......... you just dump.......... no thought about it......... you gotta be very switched on to go for your reserve in that situation - unless you make the plan to go for your reserve before hand .......... but thats just crazzzzzzzzzy........... ;op"it troubles me that you utilize the word "groundrush" in your posts. be careful, it can mean various things to young individuals in our sport. low pulling is dangerous, that's a proven fact, there's really no excuse for it. you can "justify" it all you want, but you can't say, and be truthful with yourself that it's safe.Merry Christmas:Richard"Gravity Is My Friend" Quote Share this post Link to post Share on other sites dkearns 0 #14 December 25, 2001 And every boby knows that 3flier has a low pull death wish even if he thinks he does'nt. And 3spatter don't argue cause you know you do or you wouldn't have been grounded a thousand times this year.Geers. Quote Share this post Link to post Share on other sites mikefarmer 0 #15 December 26, 2001 Quotelow pulling is dangerous, that's a proven fact, there's really no excuse for it. I'm no low pull artist, contrary to my cute little quote below; but I do believe that the above statement could be made about skydiving in general. Jumping serves most of us no transportational purpose, it only exists for the "thrill" or "rush." It is also an individual sport, and while I would do nothing to wreck the sport for my fellow jumpers by acting in a silly manner, everyone makes his/her own decision about how safe they want to play it. I personally like to freefly (eek-the reserve might blow), shoot video (we have all heard deadly accounts of snags), and occasionally swoop my little canopy. Point being, before the "Mainstreaming" of skydiving, we were "Daredevils" who jumped for the thrill of the fear. Again DON'T BE STUPID and hurt yourself, but be careful about telling other jumpers what's best for them. I am not advocating pulling low, swooping, or anything except personal freedom!! I LOVE YOU GUYS!!"It's better to be dead and cool than alive and uncool."-Marlboro Man Quote Share this post Link to post Share on other sites freeflir29 0 #16 December 26, 2001 "groundrush" In truth it's not necessarily a bad thing. I have noticed a bit of "ground rush" at relatively high altitudes. I even noticed a little bit of it last weekend while Head down and passing through 5,000 ft. I hadn't looked at my alti yet....noticed my jump partner looking at his and noticed the gound coming up. I knew it was about time to leave and before I could even look my Time out went off at 4500. My normal break off alti. I also ended up pulling a little high one day. For some reason I didn't trust my alti and got Ground rush at like 3500 ft. I would have sworn I was lower than that but it sure looked high once I was open. My alti said 2900. I'm normally riding in the saddle at around 2500. I have no idea what made me get the rush on that jump. Maybe it was seeing an airplane below and to the right. I probably would have missed it but I decided to be safe and track. "I got some beers....Let's Drink em!!!"Clay Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
