Jabeln79
Taking care of a new rig...
So now that i dont have to rent gear anymore what are the little things that should be down to keep your rig safe..for use..
like how often to replace the closing loop.. and any other little things that i didnt have to do myself with a rental..that i might not be aware of..thanks
joe
Closing loop: change it when its starts to fray
Handles: good idea to do this at the start of the day or weekend: peel off from velcro to make sure the velcro hasnt "set" and is too dificult to peel if needed.
Clean the cutaway cables and undo the 3 rings to flex the risers regularly (every couple of months or at least every reserve pack)
any other tips?
Remi
Muff 914
Keep a spare main closing loop and rubber bands handy.
Spray it with Scotch guard before its first jump.
Minimize exposure to direct sunlight.
Lay it on a packing mat when packing.
Pack on clean carpet.
Transport it to the DZ in a gear bag. Hint, any old suitcase or backpack will do as long as it keeps your rig clean and dry.
Speaking of clean and dry, store your rig in a cool, dry, dark closet.
Try to limit the amount of direct UV to the canopy and your rig. Sun light not only fades colors but it breaks down the poly chains that are in the synthetic fibers. Every time you find you've laid your canopy in the sun. Put a dollar in a piggy bank! Your container will fade too try to do your dirt dives in the shade. Stand in the shade of the wing if your waiting on the load to fill. Little habits you make yourself build now will have a long term payoff! Keep your gear like new ALWAYS. The "well I'll get to it later" is how new rigs look old quick. Even 3 years from now if you do this it will look new. Never forget how much you paid for it and treat it with respect, it does save your life. If you ever suspect a piece that has wear, FIX it then! I have a 13 year old Vector that looks as good as the day it was made, and 6 other rigs that are in perfect shape. My instructors and up jumper friends gave me hell early in my training and it stuck. Now I'm reaping the rewards of having some of the nicest equipment at our DZ.
Ps. DON'T DRAG YOUR RIG WHEN PACKING!
jumpervali
