skreamer 1 #1 November 8, 2001 I'm obviously not referring to the first four stows, but the ones on the side. Is it safe to double the bungies on the side stows? I've heard lots of conflicting opinions, so I thought I'd just post here and get a few more. Seriously though, I'd welcome some input from any experienced jumpers/packers/riggers. Can I double the bungies, or should I shorten the bungies by looping them around a couple of times?Thanks in advance for any knowledgeable input.Will Quote Share this post Link to post Share on other sites
PhreeZone 20 #2 November 8, 2001 Are you talking about rubber bands or bungie cord?A rainy day at the DZ is better then a Sunny day at work Quote Share this post Link to post Share on other sites
Aviatrr 0 #4 November 8, 2001 I ALWAYS double wrap rubber bands on Spectra, Vectran, or HMA line.....even on locking stows.. With Spectra or Vectran, I use large bands and double wrap.. With HMA, it seems that small bands, double wrapped, will be necessary on the locking stows.. Mike Quote Share this post Link to post Share on other sites
jumpervali 2 #5 November 8, 2001 If your using rubber bands then it's OK to double them. NOTE: The line groups need it if your using the large/long ones AFTER the cascades. If your worried about that use small/short ones for the ones after the first four stows for the bag flap. If using normal rubber bands you will only be breaking more band by putting 2 wraps on them, but it's alot better than getting line dump.jumpervali Quote Share this post Link to post Share on other sites
Kirils 1 #6 November 8, 2001 I am playing devil's advocate and say NEVER double stow your bands. If things are too loose, get a smaller rubber band.Skydiving is not a static excercise with discrete predictability... Quote Share this post Link to post Share on other sites
BenW 0 #7 November 9, 2001 I've gotta agree with Kirils here. Get the right sized bands and single loop them. If you need to double them, they're too long....Anyway Will, with the spaghetti hoops you call stows, you might as well just not bother using bands at all, and just chuck 'em into the container... B. Quote Share this post Link to post Share on other sites
FallingMarc 0 #8 November 9, 2001 Question--why is doubling rubber bands a bad thing? Don't they just break if the lines don't slip out?Marc Quote Share this post Link to post Share on other sites
skymedic 0 #9 November 9, 2001 They should break...I double mine and have not had a problem...but I am now thinking of going with tube stows to kinda keep the replacing of rubber down..MarcBecause I fly, I envy no man on earth Quote Share this post Link to post Share on other sites
Jimbo 0 #10 November 9, 2001 It shouldn't be a problem. With an ample supply of packers at the DZ I've been pretty lazy lately, letting them do it. But on the rare occasion that I do pack I double the locking stows and triple everything else. Never had a problem.-Jim Quote Share this post Link to post Share on other sites
alan 1 #11 November 10, 2001 Try spraying your rubber bands with a good food grade silicone lubricant. Rub it in until it dries. Your rubber bands will have a much longer life. A few re-applications will extend it even more.alan Quote Share this post Link to post Share on other sites
skreamer 1 #12 November 10, 2001 Thanks for that Alan, what is your opinion on doubling rubber bands? Is it OK to do it? What are the chances that doubled (or tripled) rubber bands could cause bag lock?Will Quote Share this post Link to post Share on other sites
Kirils 1 #13 November 10, 2001 There is one small problem with doubling up the rubberband:Double stows have more variability when it comes to the force required to pull free and it can affect the fluidity in the line stretch. A single band release is much more consistent. You can verify this by checking the release force with a riggers hand pull scale. Skydiving is not a static excercise with discrete predictability... Quote Share this post Link to post Share on other sites
skymedic 0 #14 November 10, 2001 Alan, where can I pick up some of this lube at?and what would be there commercial name of it?MarcBecause I fly, I envy no man on earth Quote Share this post Link to post Share on other sites
skreamer 1 #15 November 11, 2001 Hey, Marc, exactly what sort of lube are we talking about here??? Quote Share this post Link to post Share on other sites
E150 0 #16 November 12, 2001 I have to double my bands, they are way too loose if you dont. The lines would fall out. Quote Share this post Link to post Share on other sites
skymedic 0 #17 November 12, 2001 How did I know the Kreamer would make a smart ass comment like that....oh and I dont need that kinda lubricant, I get em wet enough MarcBecause I fly, I envy no man on earth Quote Share this post Link to post Share on other sites
RemiAndKaren 0 #18 November 12, 2001 Quotewith all the right movesbaaaaaaaaaarrrrrrrrrrrrfffffffffffffffffffff besides, slicone lube taste funny... allegedlyRemiMuff 914 Quote Share this post Link to post Share on other sites
alan 1 #19 November 12, 2001 QuoteThanks for that Alan, what is your opinion on doubling rubber bands? Is it OK to do it? What are the chances that doubled (or tripled) rubber bands could cause bag lock?I have never had any problem when doubling rubber bands, although I seldom do it any more because it is just too much extra work. I use the small bands on all but the locking stows, where I use the bigger ones for ease of use. All of my rigs have either Spectra microline or Vectran. If I pack for someone else and they have the big rubberbands, it is usually because the rig has big Dacron lines and then I double the stows. I have never triple stowed anything and have never seen the need to. If they are that loose, then I would replace the bands with smaller ones. The stows are tight enough if you can pick up your d-bag by the lines and they do not slide out of the stows. I think there is very little chance that a double stowed band could cause bag lock, with proper stows. Excessively long loops in your stows have the potential to cause bag lock.alan Quote Share this post Link to post Share on other sites
alan 1 #20 November 12, 2001 QuoteAlan, where can I pick up some of this lube at?and what would be there commercial name of it?Try a hardware store or one of the big home supply places like Fleetfarm, Home Depot, etc.. There are several brands available. The one I have in front of me now is called LPS Heavy-Duty Silicone Lubricant. Manufactured by LPS Laboratories, Inc. Tucker, GA 30085-5052 (1-800-241-8334)alan Quote Share this post Link to post Share on other sites
skymedic 0 #21 November 13, 2001 Thank you very much..MarcBecause I fly, I envy no man on earth Quote Share this post Link to post Share on other sites
