Aviatrr 0 #1 August 13, 2001 A friend of mine asked me if he should get standard mini risers or triple risers for his new canopy.....and I have no idea what triple risers are for.. I can't say I've even seen a set of 'em.. Anybody use 'em? Mike Quote Share this post Link to post Share on other sites
Kris 0 #2 August 13, 2001 Mike,If I'm correct, triple-risers are used on very-high-performance canopies or with extreme wing-loadings. The idea is that by taking the toggles off of the rear risers and allowing them to rest more to the side it decreases deformity in the canopy during agressive flight.It's basically in the same tool-box as stowing your slider behind your head to reduce drag and loosening the chest-stap after opening to allow the canopy to spread out a little further. Kris Quote Share this post Link to post Share on other sites
skymedic 0 #3 August 13, 2001 Hey mike,alot of the instructors at Skydive U have em and also the regular instructors at Sebastian have em. talk to Patrick Osbourne, Anne, or Jerry...they all have em.like Kris said, they let the canopy expand just that little bit more to give better flight. The guys also said something about helping with front risering also...not sure about this though.MarcBecause I fly, I envy no man on earth Quote Share this post Link to post Share on other sites
freeflyfree 0 #4 August 14, 2001 I have triple risers and I got them because they offered me with softer toggle pressure (I got my shoulder dislocated once and it came out to say "Hi" during a hookturn two years ago...) ;) jejeje Quote Share this post Link to post Share on other sites
Aviatrr 0 #5 August 14, 2001 Hmm.. I'll have to look a bit closer at 'em.. I'll be loading either a Crossfire or a Cobalt at about 1.5-1.6, depending on my final choice.. Anything to make life easier/riser pressures lighter is a good thing in my mind.. Then again, I'm a lazy bastard.. Mike Quote Share this post Link to post Share on other sites
riggerrob 644 #6 August 15, 2001 Triple risers are used by the top canopy pilots to reduce friction on steering lines and allow the tail to spread a bit wider. Spreading the tail improves stability and slightly flattens the glide. Triple risers were originally developed by accuracy competitors back when parachutes were square.Now they are being revived by top blade running competitors for the same reasons.Since triple risers require an extra minute to pack, you should only spend the extra money after you have tried all the other tricks: pulling the slider down to your shoulders, loosening your chest strap and spending a few hundred jumps learning all the corners of your canopy's performance envelope. Quote Share this post Link to post Share on other sites
SkymonkeyONE 4 #7 August 15, 2001 Oddly, I am in the minority of Pro swoop competitors that actually use trips. I like them for all of the reasons listed so far in this post: lower toggle pressure, increased "feel", flatter tail, etc. None of the members of The Extreme Team (team Icarus) use trips and all four of them out-swoop me right now. It is all a matter of personal preference, but I simply prefer them as I am now very used to jumping them.ChuckTeam Atair Quote Share this post Link to post Share on other sites
