wmw999 2,621 #1 May 8, 2013 real message here demo:one two three and maybe it's intentional Wendy P.There is nothing more dangerous than breaking a basic safety rule and getting away with it. It removes fear of the consequences and builds false confidence. (tbrown) Quote Share this post Link to post Share on other sites
Meso 38 #2 May 8, 2013 Not intentional ;) Thanks for the heads up, will work at getting the styling there right. Quote Share this post Link to post Share on other sites
theonlyski 8 #3 May 8, 2013 What's odd is that HH's post is fine. http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=4482417#4482417"I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
Meso 38 #4 May 8, 2013 Ah, I see what's going on... Tag issues again. Basically, the OP post looks like this [.li][.li][.li] There are two problems with that... First, we highly encourage closing ALL tags. So when you make an [.li] tag, for example - make sure to close off each [.li] to look like this. [.li]text[./li][.li]text[./li] But most importantly, using list items without specifying a list, is incomplete HTML and that is causing it to break. When you plan on using list items ([.li]) You NEED to put them within a list type, in the case of the forums, within an unordered list. So where the OP looks like this. Quote[.li]Text[.li]text[.li]text What it should look like is this: Quote[.ul][.li]Text[./li] [.li]Text[./li][./ul] Users should note the [.ul] and [./ul] that must be placed between any [.li] tags :) OP: Once you edit your post to reflect like above, it should be sorted :) Quote Share this post Link to post Share on other sites
BeteNoire 0 #5 May 8, 2013 Most people don't understand html commands, and aren't going to be able to follow those rules. The posters might do better just doing a simple cut-and-paste using a dot symbol from Word. To get those from Word, click "insert", "symbol", and then select what you want. Copy the dot from Word to a text file. Then copy the dot from the text file to here. Save that text file for future reference. Quote Share this post Link to post Share on other sites
