Anvilbrother 0 #26 January 13, 2013 His hands were right there, could have pulled risers or grabbed toggles. I would like to see how long it would have took to calm down if he flared. Postes r made from an iPad or iPhone. Spelling and gramhair mistakes guaranteed move along, Quote Share this post Link to post Share on other sites
coticj 0 #27 January 13, 2013 I was pulling on the risers, nothing happened, and as I didn't know what is wrong I decided to chop it. But I do know of a case on the same canopy when the guy flared and the canopy then started flying normally...http://www.prostipad.si Quote Share this post Link to post Share on other sites
Anvilbrother 0 #28 January 13, 2013 Sry in that video I never saw an attempt at a riser or toggle flare. My bad.. Postes r made from an iPad or iPhone. Spelling and gramhair mistakes guaranteed move along, Quote Share this post Link to post Share on other sites
ChrisD 0 #29 January 13, 2013 Quote Sry in that video I never saw an attempt at a riser or toggle flare. My bad.. From the students perspective, this is the Safety and Training forum Great job in the vid BTW!! CBut what do I know, "I only have one tandem jump." Quote Share this post Link to post Share on other sites
phoenixlpr 0 #30 January 14, 2013 I got about this with Cobalt135 when brakes were not set. Quote Share this post Link to post Share on other sites
davelepka 4 #31 January 14, 2013 QuoteHis hands were right there, could have pulled risers or grabbed toggles. I would like to see how long it would have took to calm down if he flared. While this might be true, and a controlability check does include a left turn/right turn/flare, it's a little different when you have a small, high performance canopy that is not behaving. Could you mess with it and see what happens? Sure, but you could also be losing altitude at an alarming rate and getting tossed around like a rag doll. Part of jumping a high performance canopy 'should' be a higher degree of reliability in terms of packing, equipment maintenance, and body positioning on opening. All of these will reduce the odds of a malfunction, but when one does happen, sometimes the 'procedures' have to be a little different than on a more docile canopy. Quote Share this post Link to post Share on other sites
tan 0 #32 January 29, 2013 Thanks John! I've been wondering about that for the longest time, and no one has been able to give me a good answer on "why we need to stow our brakes during packing". The previous answers were usually about hard openings or etc.. Just for technicality though, does setting the brakes help with cell inflation by pulling the top skin back to open the nose, or by changing the effective angle of attack of the wing, thereby preventing the canopy from flying forward too much and closing the nose with the top skin? That also brings another incident to mind.. I was visiting a DZ and jumping a rental Test-235 (could never figure out which manufacturer made a series named "Test" either..), and that particular canopy had horribly long snivels (softest openings ever though..). 7 seconds of snivel on the first 2 jumps, 11 seconds on the third. Was only in the saddle at 1,700 on that third jump; really should have stayed more altitude aware, and chopped it by 2k. Thing is, I know it wasn't brake fire coz I always set my own brakes immediately after landing, and I know it wasn't the packer coz I had the same guy for the next 10+ jumps (on a different rig of course), and it was a high speed streamer, so it didn't look like a slider lock either. But it did look a lot like the video posted by coticj, so all things considered, are there any other factors which could cause such a reluctance towards canopy cell inflation? Thanks again! Quote Share this post Link to post Share on other sites
JohnSherman 1 #33 January 29, 2013 Quotedoes setting the brakes help with cell inflation by pulling the top skin back to open the nose, or by changing the effective angle of attack of the wing, thereby preventing the canopy from flying forward too much and closing the nose with the top skin? Kinda - Sort of. Yes, it does. More importantly it applies big brakes by pulling down the tail which prevents the canopy from surging forward. When the Strato Star first came out it had ropes and rings reefing. This was a system where the outside edge had rings attached with a draw string running through it which was attached to the pilot chute. The pilot chute drag worked the draw string like a pack of tobaco. This system did not require brakes as the draw string held the tail down. We renamed the brakes to "Surge Inhibitors" and continued to use them as we were doing 10 way and we wanted to open without surging into each other. When I designed the Firebolt we found that because of the unique planform we had "end cell closure " on the center cells even with brakes set. We then tried to brake the center cells. It worked but the opening were to prompt with that configuration. We found a better solution with the double brake lines which you see today. BTW: Just because you set the brakes doesn't mean they didn't fail. There are toggles out there which will self release from the inertia of lifting the risers out of the pack. Quote Share this post Link to post Share on other sites
CReW 0 #34 February 1, 2013 I never understood why everybody doesn't jump Racer Risers with Snap toggles. Totally eliminate the worry of premature break release. I jump them on all my rigs, Javelin, Wings, Racers. I made 60 jumps in a row without setting my brakes, no problem. A little slower than normal but very orderly. I don't recommend that but have considered it with my Firebolt. Quote Share this post Link to post Share on other sites
faulknerwn 38 #35 February 1, 2013 I agree on the Racer risers. They are bulletproof. I experimented 10 or so years ago with not setting the brakes on my CRW canopy to see if it opened softer. Despite being a tail-pocket canopy, the openings were slow with line twists every time. I got tired of kicking and went back to stowing my brakes. As far as Firebolts - they open s slow I wouldn't want to slow them down anymore!!!! Quote Share this post Link to post Share on other sites
CReW 0 #36 February 2, 2013 The takeaway here is, if you never want to worry again about you're brakes firing when you don't want them to, get yourself some Racer Risers with Snap Toggles. Whenever I get a new rig the first thing I do is order a set. If you've never used them you don't know what you're missing. See Ya Soon Win. Quote Share this post Link to post Share on other sites
sundevil777 102 #37 February 2, 2013 How big is the hole that has to be made for the snap?People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
Deyan 36 #38 February 2, 2013 QuoteHow big is the hole that has to be made for the snap? I don't know about the Jump Shack risers, but on the PdF risers with snaps there's no hole on the Ty 17 webbing. The snap is placed on Ty 3 tape and the tape is sewn on the riser. One more thing. If you want to place the snap on the Ty 17 webbing, you don't have to punch a hole. You can work your way through the webbing without any damage."My belief is that once the doctor whacks you on the butt, all guarantees are off" Jerry Baumchen Quote Share this post Link to post Share on other sites
JohnSherman 1 #39 February 2, 2013 QuoteHow big is the hole that has to be made for the snap? No hole. The snap is attached via an appliqued tab like Deyan says. This tab keeps the release pull direction to straight down. Quote Share this post Link to post Share on other sites
IanHarrop 43 #40 February 2, 2013 cool... I checked the Jumpshack site and I could find pics of the toggles, but I couldn't find pics of the risers. Would love to see pics. I think this is a great idea and I'd love to learn more"Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy Quote Share this post Link to post Share on other sites
CReW 0 #41 February 5, 2013 But not a new idea, I've been jumping them for give or take 20 years. OK Ian, It was just a matter of remembering where I put the picture. Racer Risers 3.0 Quote Share this post Link to post Share on other sites
RMURRAY 1 #42 February 9, 2013 the racer snap toggles are bulletproof. I pack lots of other peoples rigs and can see why some have toggles issues....totally preventable. Quote Share this post Link to post Share on other sites
uberchris 0 #43 February 9, 2013 QuoteBut not a new idea, I've been jumping them for give or take 20 years. OK Ian, It was just a matter of remembering where I put the picture. Racer Risers 3.0 i LOVE this. here i have been brainstorming ideas while reading this whole discussion for a toggle/riser with a snap or even thinking about routing some yellow cutaway cable through the top and bottom of the toggle keepers (just a stupid idea) and these risers are available. SOLD, im ordering a set right now for my new container. thanks everyone for the useful information on this whole thread, i always bring these things up to friends at my DZ after reading because everyone gives their own input and thats how us newbs learn stuffgravity brings me down......... Quote Share this post Link to post Share on other sites
sundevil777 102 #44 February 9, 2013 QuoteQuoteBut not a new idea, I've been jumping them for give or take 20 years. OK Ian, It was just a matter of remembering where I put the picture. Racer Risers 3.0 i LOVE this. here i have been brainstorming ideas while reading this whole discussion for a toggle/riser with a snap or even thinking about routing some yellow cutaway cable through the top and bottom of the toggle keepers (just a stupid idea) and these risers are available. SOLD, im ordering a set right now for my new container. thanks everyone for the useful information on this whole thread, i always bring these things up to friends at my DZ after reading because everyone gives their own input and thats how us newbs learn stuff I think 3M Dual Lock would be another alternative. Both sides of it are identical and are a "mushroom cap" type of shape that will not snag spectra lines. It is very durable and doesn't take much at all to be secure. Some versions of it should allow sewing through it.People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
CReW 0 #45 February 10, 2013 New kind of Velcro? I hadn't seen that. Wouldn't want it on my risers but bet I could find a use for it. Quote Share this post Link to post Share on other sites
sundevil777 102 #46 February 10, 2013 Why wouldn't you want it on your riser?People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
FastRon 0 #47 February 10, 2013 We use dual lock on water ski bindings. Comes in two 'strengths; 250 and 400. Has a LOT of holding power. It does not snag or grab at various materials like the hook portion of Velcro does. It also doesn't 'fuzz' like Velcro. It has a somewhat limited service life... We replace it after about 5 separations of bindings from the ski. Quote Share this post Link to post Share on other sites
uberchris 0 #48 February 11, 2013 we use it at work for all types of purposes. its not sharp at all, but its got excellent holding power.gravity brings me down......... Quote Share this post Link to post Share on other sites
Andy9o8 3 #49 February 11, 2013 Quote We use dual lock on water ski bindings. Comes in two 'strengths; 250 and 400. Has a LOT of holding power. It does not snag or grab at various materials like the hook portion of Velcro does. It also doesn't 'fuzz' like Velcro. It has a somewhat limited service life... We replace it after about 5 separations of bindings from the ski. Great; that would get me about 90 minutes on the slope. Quote Share this post Link to post Share on other sites
JohnSherman 1 #50 February 12, 2013 QuoteI think 3M Dual Lock would be another alternative. Both sides of it are identical and are a "mushroom cap" type of shape that will not snag spectra lines. We were introduced to 3M Dual Lock about 35 years ago when I worked for Chrysler. We used it to hold on door trim panels. To stiff for toggles or to sew. Glue on mostly. We tried to find an application in parachuting for it but no luck. Quote Share this post Link to post Share on other sites
