skydive4play 0 #1 August 27, 2001 When faced with a bad spot and you have a long ways to the DZ. Which is the best way to get the most glide from you canopy going to the DZ. (1) Slightly pull on your brakes and glide in. (2) Slightly pull on your rear risers and glide in.??????????????? Quote Share this post Link to post Share on other sites
Slowfaller 0 #2 August 27, 2001 I'm no expert ( 32 jumps ) and I could be wrong but what I have done is if I'm w/ the wind I leave my brakes stowed and keep the riser pulled down to get the most hang time. If I'm against the wind I would Pull my legs up and put the slider behind my head. Maybe a little front riser action to gain speed. If I'm wrong please somebody clarify.CHris"..and your hands and knees felt cold and wet on the grass beneth." - modest mouse Quote Share this post Link to post Share on other sites
PhreeZone 20 #3 August 27, 2001 The most efficient glide rate for most canopies is:Slider pulled behind your head,Chest strap slightly loose,Rear risers slightly pulled (1/3 way) and seperated to the outsides of the canopy.This all changes based on wingloading and wind speed and lots of factors but those are the easiest things to control.Do I HAVE to do another raft dive??? Quote Share this post Link to post Share on other sites quade 4 #4 August 27, 2001 A lot would depend on the wind conditions.In no wind, your best glide will probably be with the brakes unstowed and slight rear riser. You'd need to experiment with this considerably to actually find the best glide ratio. Holding rear risers for a long period of time, however, can be tiring. You may find that 1/4 brakes does "almost" as well, but is a lot easier to hold for a long time. Certainly worth experimenting with the next time the opportunity presents itself during your regular jumps.In wind and upwind of your target, you may not actually want the best glide speed, but rather what's known as minimum sink speed. It's a speed that you might try to fly that is slightly slower than "best glide" but will give you more time aloft. The concept here is that you can let the wind help you get back to your target for a longer period of time.In wind and downwind of your target, you may want to fly slightly faster than best glide. Conditions may actually call for a little front riser to make your target. The concept on this one is to give yourself less time aloft to get pushed back by the wind.In any case, you'll want to minimize your drag if at all possible. Pull your legs up and curl into a ball making as little frontal area as you can. This too can be tiring if held for more than a few minutes.In ALL cases remember it's FAR better to land off safely, than to risk flying into buildings, powerlines, barbed wire just so that you can get back to the DZ.Paulfuturecam.com/skydive.html Quote Share this post Link to post Share on other sites PhillyKev 0 #5 August 27, 2001 Here's how you determine best glide for your canopy:Look out in the distance at the spot that is not moving....that's where you're headed. If it's closer then the dz, you're not going to make it at your current glide.Do this first with brakes all the way up, then go down to quarter brakes and find the new spot that is not moving. If that is further away then the last one, you increased your glide. If it's closer you decreased. If pulling the brakes 1/4 increased, pull down a couple more inches and check again. Keep doing that until you no longer increase the distance to the target...that's your best glide.The same can be done with brakes stowed and manipulating rear risers. Bottom line is if you can find a glide that puts that immobile target at least as far away as your dz, start looking for another place to land.cielos azules y cerveza fría-Kevin Quote Share this post Link to post Share on other sites billvon 3,120 #6 August 27, 2001 >The most efficient glide rate for most canopies is:>Slider pulled behind your head,>Chest strap slightly loose,>Rear risers slightly pulled (1/3 way) and seperated to the outsides of the canopy.Agreed. Some further points:Picking your legs up as much as possible will help.Body steer instead of using toggles.When upwind, generally more rear riser/brake will help improve your glide distance over the ground.When downwind, generally your canopy's natural glide speed is the best way to get maximum distance over the ground.If possible aim to fly over plowed fields/highways/ridges with the wind hitting the upslope. I've made it back from a few bad spots doing tandems by using thermals.-bill von Quote Share this post Link to post Share on other sites PhreeZone 20 #7 August 27, 2001 QuoteI've made it back from a few bad spots doing tandems by using thermals.Hey! Thats cheating Do I HAVE to do another raft dive??? Quote Share this post Link to post Share on other sites apoil 0 #8 August 28, 2001 QuoteLook out in the distance at the spot that is not moving....that's where you're headed. If it's closer then the dz, you're not going to make it at your current glide.Hopefully this doesn't actually need to be said, but fixating on that spot can lead to a) not realizing that your path to that spot might involve you being too low to clear trees/powerlines/fencesb) not having time to turn back into the wind once you get there.Follow the example of the Fabulous Furry Freak Brothers, and make your decisions high.- Saut A. Poil Quote Share this post Link to post Share on other sites Iflyme 0 #9 August 28, 2001 QuoteFollow the example of the Fabulous Furry Freak Brothers, and make your decisions high. ... and don't forget to feed Fat Freddy's Cat Quote Share this post Link to post Share on other sites Kelly 0 #10 September 25, 2001 bill von,ha! i used that one about 12 or so jumps ago. Those damned thermals that had been bumping me around for the 2 weeks prior and also had been annoying/scaring the hell out of me actually got me back to the dz with enough time to set up for a safe final and do a couple of S turns to burn off some Alti... now i dont mind the thermals. Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0 Go To Topic Listing
